Front axle u-joints, what brand? - Page 2 - JeepForum.com
post #16 of 22 Old 06-03-2011, 03:02 PM
freeskier93
Good grief I am so confused by my bookmarks, nevermind.
Spicer 760 is the way to go.
freeskier93 is offline
post #17 of 22 Old 06-03-2011, 03:11 PM
TravisHeim
Originally Posted by mystangt
So how do i check? Wheels off? On the ground, on stands? Im just not sure...
Wheels can be on and vehicle on ground. Just reach in there and grab the ears of the axle shaft and try to move them.
Sent from my PC36100 using JeepForum
TravisHeim is offline
post #18 of 22 Old 06-03-2011, 03:38 PM
sublimemaze
spicer 5-760x u joints for $24.99 at iron rock offroad: http://www.ironrockoffroad.com/Merch...Category_Code=
sublimemaze is offline
post #19 of 22 Old 06-03-2011, 08:02 PM Thread Starter
mystangt
I checked my axle u-joints and they have no play at all.
The Jeep was on the ground with the wheels straight and i tried to move the yolk as hard as i possibly could but nope. They did NOT move the least bit.
I also re-greased all the joints and no changes.
The wheel is still jerky as it starightens out.
What do you guys think? Bad u-joint?
I have no idea what else it may be. I cant picture it being anything but the u-joints but they are solid...no shaking
mystangt is offline
post #20 of 22 Old 06-03-2011, 08:17 PM
BYuen
BYuen's Avatar
Go ahead and change out the u-joints. Sometimes they won't have any play in them but will seized up. If the problem still persists after you change the joints, then you know you have to look elsewhere.
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is offline
post #21 of 22 Old 06-03-2011, 09:22 PM
solarpower
get a friend.
Have that friend drive (roll Jeep slowly using the engine actually) your vehicle forwards then backwards with wheels at full turn while you watch the joints and shafts/yokes.
there could be many reasons your wheel is jerky when straightening out, and you should be able to get a real good look while your friend moves it around.
they will need to turn the wheels all the way in both directions.
I drove almost a year including numerous wheeling trips before I found the hairline crack in a cap on one of my spicer 5-760x.
I personally have done more u-joints than I care to remember on Jeeps. I only buy spicers for my own Jeeps but have to re-re-do (not typo) one on the rear of my t-case this weekend..and I think the spicer box I had said china on it so I may look into a high quality AMERICAN MADE u-joint in the future.
04 TJ "U" package
06 XK Commaddy 4.7
solarpower is offline
post #22 of 22 Old 06-03-2011, 09:53 PM
tjsean0308
quote for truth, just replaced mine for the same reason, I got five years out of the Napa non greasable ones. went for the presicion greasable through the cap ones from Napa this time. Completely cleared up my jerking wheel. There was no play in the joints but once I was able to move the joint around by hand they felt like all the rollers were square. and were very rusty inside.
tjsean0308 is offline
5-760 , spicer , u-joint
What u joints for front axle? ZeroGravity YJ Wrangler Technical Forum 5 03-18-2009 10:03 AM
Front Axle U-Joints Chuckwsu_82 TJ Wrangler Technical Forum 2 04-22-2008 11:23 AM
Front axle U-Joints @#!*&$#$ jgowen YJ Wrangler Technical Forum 8 03-06-2008 03:35 PM
front axle u-joints..... jeepin1995 YJ Wrangler Technical Forum 12 10-30-2006 08:41 AM
Front Axle U-joints YJ crashx10 YJ Wrangler Technical Forum 7 04-09-2006 09:01 AM
