Front axle OEM lower shock mount elimination? - JeepForum.com
post #1 of 11 Old 11-02-2009, 04:48 PM Thread Starter
toyrocs
I'm wanting to install longer front travel shocks on my 1998 tj that has a 1.75" BB. It has the Dana 30 HP out of a doner XJ.
I do NOT want to use the ford upper shock towers to raise the upper shock mount, use bump stop extensions or the aftermarket lower shock mount raising brackets. The point is to increase travel-- not just make it work!
I was thinking of cutting out all the metal structure for the lower shock mount ( cross pin area). Fabricate a new lower shock mount about 2"-2.5" lower than the orginal mount & weld to lower control arm bracket & axle tube. With the new shock mounts, also ensure clearance to remove/install the control arm bolts.
I'm running narrow 33" swampers with minimal rub on the plastic flares & just want to increase down travel & will be using some Rancho RS9000XL ( RS999168) .
Has anyone done this mod/or have any info or comments that may be useful?
I have searched for hours on this subject & found no info.
Thanks. Toyrocs
toyrocs is offline
post #2 of 11 Old 11-03-2009, 11:45 AM
Jakemd98
Choosy moms choose jeep.
Jakemd98's Avatar
are you really having that much issue with lack of down travel? When i ran my 2.25" BB i dropped coils at full droop. not sure why you would want more down travel than that.
Jake Davis
97 Jeep Wrangler
4.0, 5 speed AX-15, D44 & Ford 8.8 w/Detroit - 4.88, NP-231, OME 2.5" coils w/1.25" spacers on front, 1.25" JKS BL, 35X12.50R15 KM2 on 15x8 Eagle alloys, Banks Header, Banks Monster Exhaust, Brown Dog MML, Rhino Liner, Tuffy Glove Box, AtoZ Rockers, Optima Red Top Battery.
1998 GMC Yukon
Jakemd98 is offline
post #3 of 11 Old 11-03-2009, 11:54 AM
NotURMailman
^x2... I had to raise my lower shock mount and install bumpstops to properly utilize the 10" of travel in my shocks. Any more down travel (such as it was before I raised my lower shock mounts) and I would completely unload my springs. I set it to 5" up and 5" down and it works fine. (well... other than the tire still wanting to grab the fender when stuffed) and that's with 6" springs. The shocks weren't the limiting factor in my down travel to begin with, it was the LCA hitting the mount. After I notched and gusseted the mount I had to move the bottom of the shock up to use the down travel I had added and I need limiting straps to keep the axle from hangin by the shock. If I had 12 or 14" travel shocks, I could still not get any more down travel, as my springs would fall out...
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #4 of 11 Old 11-03-2009, 07:23 PM
nriver
2011 JK Wrangler
Something like this?
These are the Clayton CA mounts. Thinking it is similar to what you are thinking. If I were to use the stock CA mounts, I would re-enforce them with 3/16, 1/4 plate or somethings like that.
Also look at some of Mud8's posts on the subject of shock travel. He is in the greater Portland area as well.
Why do I post here?
nriver is offline
post #5 of 11 Old 11-04-2009, 09:57 AM Thread Starter
toyrocs
NRIVER, the pictures you posted are what I was thinking about. Currently I do have about 2" more down travel before the springs unload. This Dana 30 HP has been heavily modified & I would like to restrict mods to the axles.The plan was to go back to stock (replace front axle) if I ever sell it.
This TJ is my DD & will never have more than 33" tires as long as I'm the owner. I have a Toyota on 46" baja claws that is my off road (only) machine.
Toyrocs.
toyrocs is offline
post #6 of 11 Old 11-04-2009, 02:00 PM
Jakemd98
Jakemd98's Avatar
just to be sure... your sway bar is disconnected, right?
Jake Davis
97 Jeep Wrangler
1998 GMC Yukon
Jakemd98 is offline
post #7 of 11 Old 11-05-2009, 10:22 AM Thread Starter
toyrocs
Yes both roll bars have been removed. It would be extremely difficult to install a front bar ( or reinstall the oem bar) due to my redesign of the tie rod / drag link/ custom steering arm bracket on passenger knuckle/ panhard bar ( style & frame mount).
Toyrocs
toyrocs is offline
post #8 of 11 Old 11-05-2009, 08:08 PM
mudb8
want it rite or rite now?
mudb8's Avatar
is that what the knuckles and pitman I just reamed for 1 ton tre's are for?
what shocks and length are you running...
a pair of OME n66L shocks will give you 11" travel and will unseat 4" lift springs.
since you only have 1.75" bb spacers, you could run up to 9.5-10" travel only if they are relocated to also stay with stock bumpstops. I may still have the lower mounts I built for mine, I ended up taking the easy/er way out for making room for 13-14" travel shocks. if I can't find em I'll make another pair
stop by, I'll show you what I did on mine and one I have in the shop currently.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #9 of 11 Old 11-05-2009, 08:32 PM
Border Dave
Got Sand?
Border Dave's Avatar
If you only have 1.75 inch spacers with the factory springs, why not just install some Old Man Emu shocks (not the long travel versions)? They don't require any bumpstop extensions in the front axle and will extend 2 inches more than the factory shocks.
Border Dave is offline
post #10 of 11 Old 11-08-2009, 05:17 PM Thread Starter
toyrocs
With the sway bars removed ( this is my DD & occasional Wheeler) I wanted to slow down the instantanious roll during quick turning on the pavemant. The body "lean" angle is ok . The quickness of the roll is what i'm concerned about the most. I have purchased some RS9000XL shocks ( adjustable dampining) with 2.1" more travel than stock. This may help somewhat. I'll let you know how this handles on the street.
Thanks. Toyrocs
toyrocs is offline
post #11 of 11 Old 11-09-2009, 08:08 PM
mudb8
mudb8's Avatar
Thanks. Toyrocs
you'll need longer bumpstops or the shock mounts relocated for those... the collapsed length is also 2" longer than the stock shocks
mudb8 is offline
Front lower shock mount broke JakeE YJ Wrangler Technical Forum 4 12-14-2009 09:54 AM
2 Questions: Front Axle Bent & Rear Lower Shock bolt munroejp TJ Wrangler Technical Forum 26 11-20-2009 03:31 PM
How to fix rear lower shock mount? chrishag YJ Wrangler Technical Forum 9 09-11-2009 09:24 AM
Lift Kits L/F lower contol mount worn front axle cilbola TJ Wrangler Technical Forum 1 12-24-2008 01:53 AM
rear lower shock mount Bluebear YJ Wrangler Technical Forum 4 05-31-2008 10:09 PM
