Front Axle Locker sensor issue - JeepForum.com
post #1 of 4 Old 10-17-2011, 12:51 PM Thread Starter
brunkhorse
Hey All
I have an 2005 Rubicon with the stock lockers. The front axle lock light keeps blinking on my dash even though my axle is locked. I verified this by putting the jeep on stands. I'm assuming this is just a sensor problem but it's annoying me. Don't have much experience with differentials. WHere is this sensor located? Do I need to pull my cover to access it? Does anyone have a part number for it if I do need to replace it? Also I do have the bypass mod installed if that makes a difference.
Thanks
brunkhorse is offline
post #2 of 4 Old 10-17-2011, 01:25 PM
ken white
The sensor supplies a ground signal to the EMIC, so disconnect the plug at the axle and perform a continuity check between the pins, or just short the plug end and see if the light goes steady.
Unfortunately, the plunger switch replacement requires the locker to be removed if its bad. I have an extra switch if yours is bad.
ken white is offline
post #3 of 4 Old 10-17-2011, 10:21 PM
joe108
The design engineer on that switch should be shot, it would have been nice if the switch could just be replaced without cracking open the entire dif.
joe108 is offline
post #4 of 4 Old 10-19-2011, 11:05 AM Thread Starter
brunkhorse
It annoys me but I don't know if its worth it to have to pull all of that just to change it. Where did you purchase the sensor from?
front axle , locker
Rubi front locker sensor 02RedWS6TA TJ Wrangler Technical Forum 2 10-15-2013 11:23 PM
'03 Rubi Front Locker Issue - Blinking TJorDie TJ Wrangler Technical Forum 5 07-16-2011 05:23 PM
front axle sensor jleal_21 YJ Wrangler Technical Forum 2 01-05-2011 09:49 PM
Front pipe 02 sensor issue klittl06 YJ Wrangler Technical Forum 3 06-20-2010 03:43 PM
Anyone put a JK Dana 44 into a TJ? Front locker wiring issue... BRICKTOP2 TJ Wrangler Technical Forum 3 12-19-2009 06:05 PM
