Front air shocks swap?? - JeepForum.com
post #1 of 7 Old 05-28-2009, 03:20 PM Thread Starter
ffdfireman18
Does anyone know a part number for an air shock that will bolt right on the front of a 97 Wrangler? I know I've seen it done, and have tried to cross referance shock numbers, but I haven't had any luck.
ffdfireman18 is offline
post #2 of 7 Old 05-28-2009, 03:32 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Are you speaking of an air shock that would adjust the ride height?I don't think I have ever seen one on the front of a DD.
GOLENJEEPTJ is offline
post #3 of 7 Old 05-28-2009, 04:44 PM
tjthorson
tjthorson's Avatar
2014 JK Wrangler
You really are not supposed to use them on the front. I recommend (and use myself) air bags in the front coils for when I plow with my Jeep. AirLift part #80702 fit perfectly in the front TJ coils and run about $80 shipped. You can set the bump stop length so that the airlift bags only get used when you load up the suspension. An airshock can affect ride quality much more.... But - if you insist - i copied these directions from a guy on a plow site that I have bantered over the years with on the airbag vs airshock debate. He swears by the air shocks. His spelling and grammar are pretty lousy - but he at least knows his stuff on the air shocks....
Air shocks can add about 1,000# of lift to the F end. depends on how much air pressure you put in them. Pump them up for the plow let some air out when you take the plow off. You can even use them to help hook up the plow... if you drive up to mount the plow and your jeep is to low then pump up the shocks until the jeep matches the plow mount.
I've done this about 5 times already. I'll give you the links and with a Little time and pencil and paper you can figure out what you need.
1) Look up the shock for your application. (your current shock) and write it down http://catalog.tenneco.com/monroe/eCatalog.do
2) Go hear and find your shock (Use the serch put your number in the serch box) write down the compressed length, extended length, top mount style and bottom mount style. go up to page 2 and familiarize yourself with the mounting styles. your bottom mount is XP4.http://www.monroe.com/catalog/docume...engthSheet.pdf
3) go down to "Air Shocks" ( use the search) Find an air shock that matches as close to yours as possible. in your case it looks like the MA763 is close, it has a bottom mount XP5 The bottom mount is 1/16 biger.. at worst a litle filing) Order the shocks or cross reference to Gabrial Hi-jacker
Good luck!
Todd Thorson
2013 Jeep Wrangler Sport Orange Crush
Orange Crush Jeep Club Member #50
2013 Jeep Wrangler Unlimited Gecko Green (Wife's DD)
Gecko Green Jeep Club Member #1
2005 Yellow Unlimited Rubicon (sold)
My Band! ->
tjthorson is offline
post #4 of 7 Old 05-28-2009, 04:53 PM
GOLENJEEPTJ
Once again, what is the purpose of wanting to put air shocks on the front of you TJ?
post #5 of 7 Old 05-28-2009, 05:24 PM
BarneyJEEP
air shocks?
http://www.swayaway.com/RockCrawling_2.php
or
air shocks?
http://www.amazon.com/gp/product/B001AMEE40
which type you talkin about?
BarneyJEEP is offline
post #6 of 7 Old 05-28-2009, 08:02 PM Thread Starter
ffdfireman18
I also run a Snowbear plow in the winter. I thought the shocks might be a cheaper way. The price for those Air lift bags seem very resonable. I think i might look into that method. I have seem the shock formula on the plowsite before, but I think I might do the bags.
post #7 of 7 Old 05-28-2009, 09:04 PM
GOLENJEEPTJ
Finally..... we know what your reasoning is!
rc 2.2 front shocks but hard compression=rough ride in front restorod TJ Wrangler Technical Forum 16 04-18-2010 05:12 PM
XJ front shocks fit on TJ? flexsaharatj TJ Wrangler Technical Forum 2 05-06-2009 09:53 PM
Need New Springs - swap out shocks too? GilpinTJ TJ Wrangler Technical Forum 6 02-26-2009 01:28 PM
TJ Shocks...having trouble with front shocks! pjleslie03 TJ Wrangler Technical Forum 16 11-10-2008 12:54 PM
Perfect shocks for SOA/Axle swap. Swampwalker3 YJ Wrangler Technical Forum 6 02-12-2008 01:47 AM
