frame swap - JeepForum.com
post #1 of 3 Old 08-04-2010, 10:17 AM Thread Starter
herbiehind
frame swap
getting a very nice 4cyl. frame . i have a 6 . so another frame with a good front is in with the deal 6 cyl . this will allow a template to be made for mount location . question is ; can i then cut the 6 cyl. mounts off this frame and reuse? or are they not recoverable due to being burned in ? also if i cant reuse them does anyone know where to get new mounts (frame to motor) .?
thx for help .
herbiehind is offline
post #2 of 3 Old 08-04-2010, 07:43 PM
BlueFlame
BlueFlame's Avatar
The frame is the same 4 cyl or 6 cyl.
Far as I know the motor mounts bolt on.
So I don't understand the problem.
bump for ya
BlueFlame is offline
post #3 of 3 Old 08-05-2010, 07:23 AM Thread Starter
herbiehind
i believe the frame mounts for the motor mounts are different places on the 6 and 4 . these mounts will need to be removed and 6cyl. mounts put on . i have some 6cyl. mounts currently on frames but can they be re-used due to already having been burned in once ? thanks for reply
frame , swap , 6 cyl , 4 cyl , motor mount , tj , wrangler
yj frame swap?? jake89yj YJ Wrangler Technical Forum 2 05-02-2010 07:26 PM
swap wrangler frame with cj7 frame midgetdog YJ Wrangler Technical Forum 7 04-15-2009 10:58 AM
yj frame swap. scooter18155 YJ Wrangler Technical Forum 17 06-18-2008 08:58 PM
Frame swap YJames90 YJ Wrangler Technical Forum 3 07-12-2007 01:25 AM
Frame Swap? DevilDogJeep YJ Wrangler Technical Forum 4 12-15-2004 09:53 AM
