Frame Hole Plugs -Worth it ?? - JeepForum.com
post #1 of 19 Old 03-17-2008, 07:32 PM Thread Starter
Ajl9791
Are they worth it for 8 bucks ?
Ajl9791 is offline
post #2 of 19 Old 03-17-2008, 07:34 PM
JJs99TJ
theres a lot of holes in the frame, which ones are you specifically
talking about?
Originally Posted by rnemovr
oman, what happened in the wreck? i see it bent your bumper, did you hit a camel?
JJs99TJ is offline
post #3 of 19 Old 03-17-2008, 07:36 PM Thread Starter
Ajl9791
They sell four rubber plugs for they holes directly behind the wheel wells and other odd things .Some looks like it might work
http://stores.ebay.com/Upper-Bound_J...QQftidZ2QQtZkm
Ajl9791 is offline
post #4 of 19 Old 03-17-2008, 08:11 PM
WillysEdition04
The only people those plugs work for are the people that sell them. They aren't really functional, they just hide those "embarassing frame holes"
How many people have looked at your frame and said "wow, some frame holes ya got there! I plugged mine with some ebay caps years ago"
That's eight bucks I'll keep in my wallet.
04 TJ Willys Edition 41MB-04TJ ...SOLD
08 JK Unlimited
WillysEdition04 is offline
post #5 of 19 Old 03-17-2008, 08:16 PM Thread Starter
Ajl9791
very true .I didnt know if they would hinder rust spreading to the inside ... snake oil anyone?
Ajl9791 is offline
post #6 of 19 Old 03-17-2008, 08:18 PM
WillysEdition04
FYI i made the mistake of buying these from the same ebayer...
http://cgi.ebay.com/ebaymotors/2-Fol...8726QQtcZphoto
They 'look' great and work great until you have to remove them to take the doors off. better remember to screw them back in and not leave them sitting on your cowl or you'll get a mile down the road and see them fly right by you and bounce in the road. That's seven bucks I'll never get back.
Most of that stuff is just useless add ons
08 JK Unlimited
post #7 of 19 Old 03-17-2008, 08:29 PM
M2LJ
You gotta remember that they hold water and mud in as much as they keep it out. You might not want that, and I think the holes are there for a reason. Plus, there are many ways to enhance the true beauty of a Jeep! This ain't one of them!
Cheers! M2
M2LJ is offline
post #8 of 19 Old 03-17-2008, 08:32 PM
WillysEdition04
Cheers! M2
Very true. submerse the frame in any water and I'm sure it will leak past those plugs. But with them plugged, that water will never evaporate out.
08 JK Unlimited
post #9 of 19 Old 03-18-2008, 05:15 AM
V-8unlimited
I actually welded my holes up both inside and outside the frame. But, I started with a new frame, so rust shouldn't be in issue. There are 4 holes on the side, where the factory steps mount to, I also filled them in. I think I'm going to fill in the long slotted holes this weekend.
V-8unlimited is offline
post #10 of 19 Old 03-18-2008, 05:36 AM
Roughneck
Roughneck's Avatar
I also think that they would hold water in as much as out, thus preventing evaporation. I have had mud inside my frame but I flushed most/all out.
A buddy filled his entire frame with expanding foam until it came out all the holes. It looked like a Play-Do Fun Factory until he shaved it off.
I do like that e-Bayer's hardtop knobs though. Might give those a try.
cheers
2006 Rubicon Unlimited
Wranglers lead the way. I mean, Rangers lead the way!
Roughneck is offline
post #11 of 19 Old 03-18-2008, 08:32 AM
ROUGHSHOD
ROUGHSHOD's Avatar
If you really want to plug yer holes up, Lowes or Home Depot sells 'em...pretty much any size you might need.....for pennies.
ROUGHSHOD is offline
post #12 of 19 Old 03-18-2008, 08:46 AM
LoneJeeper
i wear foil underwear too
LoneJeeper's Avatar
2013 MJ Comanche
cheers
expanding foam in the frame.... hm.
also, instead of hardtop knobs, use eyebolts. you can reuse the rectangle nuts and have extra tie-down spots.
lj
ಠ_ಠ
LoneJeeper is offline
post #13 of 19 Old 03-18-2008, 08:58 AM
fromme
fromme's Avatar
1977 CJ7
Foam is porous, that would have the opposite and negative effect of what he was trying to accomplish because it will just hold water and fine dirt between the foam and the frame and not allow it to dry.
"The Wicked Flee When No Man Pursueth, But The Righteous Are Bold As A Lion."
fromme is offline
post #14 of 19 Old 03-18-2008, 11:35 AM
Nonya
!st thing i did to my TJ was drill drain holes in the bottom rail of the main frame section and block those redicules holes off with aluminum tape.Ever see the amount of crap the rear tire throws into those holes? and it can't drain back out?IWhen we were looking at used TJ's last year i found quite a few with under 75k miles that had frame damage because nothing can drain out of the frame.The owners didn't even know it were shocked when i showed them the condition of the frame.The salt here in the NE is bad in winter.
Nonya is offline
post #15 of 19 Old 03-18-2008, 01:34 PM
Slick101
i,m still trying to get the dirt and crap out of my frame, there only seems to be one drain hole on the bottom of each frame rail. I,m going to try to use a pressure washer and see if that works.
K&N pannel filter, got that far before i ran out of money
Slick101 is offline
rusted HOLE in my frame... vzippa5 TJ Wrangler Technical Forum 40 01-04-2016 07:53 PM
I NEED HELP! GAH! Frame Hole Question rastaangel TJ Wrangler Technical Forum 16 10-08-2009 09:35 PM
Frame hole plugs lturley YJ Wrangler Technical Forum 7 04-24-2008 01:19 PM
My mech put a hole in my frame.... durangoyj YJ Wrangler Technical Forum 8 11-17-2007 07:36 PM
Need to tap new spark plugs hole!! 98formulaLS1 YJ Wrangler Technical Forum 10 08-29-2006 04:17 PM
