Frame basically snapped in half today...I have a lot of questions. - Page 2 - JeepForum.com
post #16 of 69 Old 07-31-2010, 02:19 PM
TeeJay00
Yes I would go with theducksguts on this... Try to get the newest frame you can find that would fit and don't forget to sand and repaint the new frame before the swap.
Good luck
TeeJay00 is offline
post #17 of 69 Old 07-31-2010, 02:28 PM
F9K9
F9K9's Avatar
Car-Part.com--Used Auto Parts Market is your friend. I see one for $650 listed in NJ and 5 that asks you to call for a price.
For those who have fought for it, FREEDOM has a taste that the protected will never know."
'03 Rubicon w/a few changes.
F9K9 is offline
post #18 of 69 Old 07-31-2010, 03:06 PM Thread Starter
jerseyjeep22
your my hero gotta make some calls, most are probably closed but ill call on monday if they are.
thats a big help man thanks
jerseyjeep22 is offline
post #19 of 69 Old 07-31-2010, 07:42 PM
G Beasley
I have a friend with a new 97 6 cylinder frame that was used for mock ups . He wants $800 for it and it is perfect . If you want his info pm me and I will send it to you . He is in VA Beach VA .
G Beasley is offline
post #20 of 69 Old 07-31-2010, 09:17 PM
herbiehind
you can buy new frames?
herbiehind is offline
post #21 of 69 Old 07-31-2010, 09:23 PM
G Beasley
This one was purchased from Chrysler to use for fabrication mock ups .
post #22 of 69 Old 07-31-2010, 09:31 PM
TheFog
So the important question is how to keep your TJ frame from rusting out like his did. What are the best options for protecting your frame long term aside from just fluid film, waxoyl and such ???
Eric
In memory of Samantha Sue 1998 to Dec-16-10 at 2:15PM. She may have had 4 legs and a tail but she was the best friend I ever had and helped me through some really tough times. I hope to see her again one day.
TheFog is offline
post #23 of 69 Old 07-31-2010, 09:37 PM
04_Sahara_Man
Originally Posted by jerseyjeep22 View Post
haha no oceans for me. And as for fixing it before this stage...there really isnt much I couldve done I bought it about 7 months ago knowing the frame had a rust problem. Everything was too far developed for painting the frame or anything to help.
So you bought it knowing it had major rust? I would have skipped that one and kept on looking for another jeep with better undercarrige and what not. Could have avoided all this.
Currently 04 Sahara: 3" BDS lift, 9500 BDS Monotubes, Flowmaster Super 44, Olympic Rocker Guards, 33" Duratracs, 15x8 Black Rock Blades.
Khaki Jeep Club Member
In Pennsylvania, fun is illegal
Xbox live GT - TheExecutive00
Tama, Paiste, DW, Zildjian, Vic Firth....yes I go boom boom!
04_Sahara_Man is offline
post #24 of 69 Old 07-31-2010, 10:19 PM
herbiehind
Eric
you use a scaler on it to bust the rust inside loose . then you blow it out with compr. air real good . then you wand some rust neutralizer in there for 20 min. keep it wet . then rinse it out . then wand por 15 in there real good . then while tacky spray more por in there . do 3 coats . por is fine if it's not hit by sunlight .
post #25 of 69 Old 08-01-2010, 12:16 AM
TheFog
My TJ doesn't have any rust in it's frame YET and I want to keep it that way
So just skip the to rise and then the POR15. Does the inside of the frame need to be really dry for the POR15 and if so whats the best way to dry it, just leave it overnight??
Also I know POR15 is some really thick stuff, how did you manage "wand" it inside the frame? Are you meaning a sprayer wand or just a stick with a POR15 soaked towel on the end of it?
As far as making it thinner has anyone tried heating it up maybe in a tank of boiling water to thin it out for application ?
Also if there is some rust that I don't know about is the POR15 going to stop it or just trap it in there and let it keep eating away at my frame?
As far as the outside of the frame is rust much of an issue there and should I also POR15 it or just use some fluid film or such a couple times a year?
Sorry for all the questions, I'm just not used to having to deal with a vehicle that is rust prone like the TJs seem to be.
Eric
TheFog is offline
post #26 of 69 Old 08-01-2010, 02:56 AM
theGiantPanda
Swap This...
theGiantPanda's Avatar
get a new frame... ive seen them as cheap as 250. find a buddy with a chain lift. the swap isnt hard, time consuming yes. i would plan on alot of headaches.... guess that youre going to have to fight alot of bolts. dunk the lowerhalf of the jeep in PB blaster..... or just just spray the crap out of every bolt on the whole under carriage periodically for a few days before you start.
Originally Posted by CCJ View Post
Jesus. This is what heaven on 4 wheels looks like.
Hospital? What, are you suffering from Overextended Jeepaphelia or something? :)
I've never been poor, only broke. Poor is a state of mind. Broke is a condition brought on by Jeep ownership and a heavy right foot.
2006 Unlimited Redicon Panda Edition
RRI Long Arm...14" Fox CO's Front and Rear...D60 KP Front and D60 FF Rear... 5.38s spooled...40" Maxxis Trepadors...
6.1 HEMI...Atlas 5.1
5.7 HEMI 400 hp TJ Build
6.1 HEMI Ultimate LJ Rubicon Build
2.5 to 4.0L swap and build up
4.0 to 2008 5.3L GM LS in the Taco'd TJ [frame off build].....
My new DD Build, lift, 4.0 motor swap, done in 6 days?....
the new shop...
conversion, parts and wiring systems
shop email....
LIKE US on facebook.....
adding more daily
redrockindustries.net
theGiantPanda is offline
post #27 of 69 Old 08-01-2010, 05:55 AM
aspjeepguy
2016 JK Wrangler
You can easily change the frame yourself. Get your camera ready and go very slow. I have seen some 4 cylinder ones go for $300.
Johnny
aspjeepguy is offline
post #28 of 69 Old 08-01-2010, 06:23 AM
kaybone
Geez, changing a frame out seems like you are basically rebuilding your Jeep from scratch. I mean, where do you begin axles or where? If anyone does this I sure hope they photograph and do a write-up. Now I am in fear of my own '99 snow-belt environment frame - yikes.
Gun Metal Blue Jeep Club Member #99
kaybone is offline
post #29 of 69 Old 08-01-2010, 06:23 AM
DINOCAVE
formerly CPT Jeep
DINOCAVE's Avatar
I'm with TheFog on this. Could you please post a more in-depth "how to" for this with a product link for the scaler?
Also, what if the frame already has mud in it? Will this get it all out?
DINOCAVE is offline
post #30 of 69 Old 08-01-2010, 06:30 AM
robncar
robncar's Avatar
If I was going to swap frames, I'd get a new frame. Or, one that didn't come from New Jersey (read: any place they salt roads, etc.). Why start with a frame that has rust to start with?
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
rust , frame , lca , control mount , mount , bracket , tj , wrangler
bolt snapped in half from the door where the strap is Mitchin TJ Wrangler Technical Forum 4 12-11-2009 10:17 PM
Hitch ball mount snapped in half! ziebartrob YJ Wrangler Technical Forum 8 10-01-2009 07:04 PM
Rear bumper, under the frame bolt snapped. vtx531 TJ Wrangler Technical Forum 7 08-10-2009 10:48 PM
Snapped some pictures today.. it was freezing Luke4554 TJ Wrangler Technical Forum 22 12-23-2008 01:00 PM
