Found mystery part in bottom of transfer case... - JeepForum.com
post #1 of 10 Old 03-15-2014, 06:05 PM Thread Starter
Stinkbug
Stinkbug's Avatar
I cracked open my NP231J transfer case this afternoon to swap in a SS SYE. I found some part fragments in recess of the the bottom of the case under the oil pump pickup. It appears to be hard black plastic of some sort.
I addition I found a small amount of metal shavings on / around the filter. I am not sure if that is related.
The part fragment I have pictured below seems to be part of something circular. The inside diameter of the circle makes me thinks it may have come from the rod the holds the shift forks. I looked at the online exploded diagrams but I didn't finds anything... Thoughts?
Stinkbug is offline
post #2 of 10 Old 03-15-2014, 09:49 PM
robncar
robncar's Avatar
Shift fork would be my guess.
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #3 of 10 Old 03-15-2014, 10:46 PM Thread Starter
Stinkbug
Stinkbug's Avatar
That was one of my first thoughts but the radius is too tight... Looks kind of like a broken plastic washer.
Stinkbug is offline
post #4 of 10 Old 03-16-2014, 09:52 AM
robncar
robncar's Avatar
Well, shoot, how 'bout the shift mode fork or filter? You might have to tear it down and go through it. But, since you were going to install the SYE anyway, now might be the time. Novak has a master rebuild kit and instructions on how to do it...
http://www.novak-adapt.com/catalog/t..._231_parts.htm
robncar is offline
post #5 of 10 Old 03-16-2014, 06:03 PM Thread Starter
Stinkbug
Stinkbug's Avatar
Well I tore it all apart today and didn't find any other remnants of the part or anything that looked out of place.
I did notice that the case has been apart before, one of the heads on the bolts for the input shaft bearing retainer was stripped and the magnet that goes below the filter was missing. Maybe it was just FOD from the last time it was cracked open...
I will just rebuild it and call it good.
Stinkbug is offline
post #6 of 10 Old 03-16-2014, 09:17 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
If you need any case parts, let me know.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #7 of 10 Old 03-17-2014, 07:51 AM Thread Starter
Stinkbug
Stinkbug's Avatar
Thank you, I really appreciate that.
Stinkbug is offline
post #8 of 10 Old 03-31-2014, 07:17 PM Thread Starter
Stinkbug
Stinkbug's Avatar
It appears that there is a plastic washer of sorts that and both ends of the planetary gears. That was is a piece of one...
Now I have two new problems:
  1. Locating a new plastic piece
  2. Figuring out how to separate the planetary gear from the basket that holds them
I am thinking this part might not be serviceable. Maybe it has to to be replaced as a unit?
Any thoughts?
Stinkbug is offline
post #9 of 10 Old 03-31-2014, 07:40 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Any thoughts?
Thoughts? I have two, the first is that I probably have parts if you need them. Second is dig through this and see if any of it helps.
http://www.jeepforum.com/forum/f9/up...-231-a-573946/
I am Savvy
mrblaine is offline
post #10 of 10 Old 03-31-2014, 07:54 PM Thread Starter
Stinkbug
Stinkbug's Avatar
That is an excellent write up... I am planning on following it when I start to put this thing back together.
Stinkbug is offline
