Found this crack in my door. Will JB Weld do? - JeepForum.com
post #1 of 8 Old 07-08-2010, 09:45 AM Thread Starter
ChrisTJCO
I was getting out of my Jeep today and noticed this crack on the door. I don't know if it's new or from the previous owner, but it looks fairly fresh. I have door surrounds, which I thought would help avoid this - maybe not.
Anyway, will JB weld hold this for a while?
White-Out Jeep
Colorado Jeep Club Member #230
ChrisTJCO is offline
post #2 of 8 Old 07-08-2010, 09:54 AM
YouStupidBunny
2007 XK Commander
It might hold for a little bit, but check Craigslist for welders. You can probably find one there that will fill that crack for around $40 or less. Grind and rattle can it. All better!
YouStupidBunny is offline
post #3 of 8 Old 03-22-2011, 07:19 AM
TJeep_1999
2015 JK Wrangler
I thought about this, but it's pretty thin metal. If they don't know what they are doing they can warp the door and then you'll have real problems. Plus to weld it I would imagine you need to take everything off the door including the window or you run the risk of melting that as well. More trouble than it is worth IMHO. I'm still thinking JB weld and drill the ends of the crack. Anyone have any luck w/ this approach???
TJeep_1999 is offline
post #4 of 8 Old 03-22-2011, 07:21 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
a good welder can fix it forever, in about 10 minutes.
take the door off, take the plastic off and walk it into a small-time local welding shop.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #5 of 8 Old 03-22-2011, 07:33 AM
daveshan
Feeding the money pits
daveshan's Avatar
Find a friend with a small MIG welder. Pull the door panel off, roll the window up and protect it from spatter/heat and you'll be out the door in 10 minutes. Take the weld down with a flap disc and prime/paint.
I've used my Millermatic 135 for lots of body work, small stitch welds don't cause warping.
Dave Shannon
Durango, CO
Gone but not forgotten
'56CJ, '61 Wagon, '51 Pickup, '07 JK 4dr
daveshan is offline
post #6 of 8 Old 03-22-2011, 08:16 AM
JeffBowser
That's a common crack area. I've had one on my full drivers door for years now.
JeffBowser is offline
post #7 of 8 Old 03-22-2011, 09:16 AM Thread Starter
ChrisTJCO
Wow forgot about this thread - started this one a while ago. I think I'm going to try to weld it next week.
White-Out Jeep
post #8 of 8 Old 06-13-2011, 12:24 PM
TJeep_1999
2015 JK Wrangler
JB Weld will not hold. One failed attempt was enough for me. Lasted about 5 min. Had to get a body shop with a spot welder to fix it. I was told MIG welders get too hot and could be an issue w/ the thin metal the door is made from. Good luck all!
door , crack , jb weld
Dangit. Just found a large crack in my ex. manifold. Repair ASAP? ChrisTJCO TJ Wrangler Technical Forum 21 06-22-2010 09:11 AM
TJ 3" crack in header??? JB weld??? WillCStars TJ Wrangler Technical Forum 45 10-20-2009 05:10 PM
Common Full Hard Door Crack? provinT13 YJ Wrangler Technical Forum 44 04-09-2009 10:46 PM
Open Door Alarm On Crack Sand-Wedgie JK Wrangler Technical Forum 2 05-24-2008 01:50 PM
Found a crack in my transfer case jeepdrvr101 YJ Wrangler Technical Forum 3 03-25-2007 09:16 PM
