Forget death wobble, this is was a death vibrate to hell - JeepForum.com
post #1 of 7 Old 05-18-2011, 04:30 PM Thread Starter
flabombero
i have a 97 Wrangle 4 cy with 31x10.5x15 tires and a 2 inch booster lift. Its been this way for last 4 years. Today as i was driving around 50 mph, I hit a railroad tracks that I hit every day on my way home. The next thing I know, the jeep is vibrating to hell and i barely could hold on to the steering wheel. It did this all the way till I slowed down to 10mph and thats with me braking as hard as I could. My wife was behind me and saw the whole thing and told me all 4 tires looked like they were about to fall off. Never had a wobble or any vibrations. What in the world could have caused this? I don't want to drive it again till I figure this out.
flabombero is offline
post #2 of 7 Old 05-18-2011, 04:31 PM
greene69
I know it sounds dumb but i would check my lug nuts first.
It's better to be dead and cool than alive and uncool.
Nothing like a permanent reminder of a temporary feeling. I have a few.
4.0 auto, 8.8 rear with detroit locker, 4.10's and 33x 12.50's
greene69 is offline
post #3 of 7 Old 05-18-2011, 04:34 PM Thread Starter
flabombero
Did that already. And afterwards it drove just fine.
post #4 of 7 Old 05-18-2011, 04:36 PM
05TurboS2K
I thought that's what we called DW.
My wife was behind me driving too and said the same thing. The wheel shook so hard it bruised my thumb as I gripped it to try to calm it the first time. Lesson learned and one from wheeling old rigs I should have known better.
I'm thinking the tracks were enough to set off DW for you. Same way potholes do for many others. When mine was bad after a week or two even a small section change of concrete on the freeway could ignite it.
05TurboS2K is offline
post #5 of 7 Old 05-18-2011, 04:37 PM
Tmoore03
2011 JK Wrangler
Hope you get it all figured out.
2011 JKU Sport Cosmo Blue
Tmoore03 is offline
post #6 of 7 Old 05-18-2011, 04:42 PM Thread Starter
flabombero
i guess it is a DW. I assumed it was just the vibration at certain speed was the DW. Now that I have read up on DW, thats exactly what happened. So what would be the first thing to replace or do? balance tires?
post #7 of 7 Old 05-18-2011, 05:07 PM
05TurboS2K
^ Need to go through some details first.
Could be loose components, could be balance too, a long list of things. In the end it's a combination of circumstances that makes it occur and ALWAYS suspension components unable to handle the axle properly is the problem. Though we can't always easily solve that in some cases so I generally lean towards a moderate fix of what can be done. No band-aid fixes like a steering stabilizer though.
The first thing I'd do is have a look at your suspension components and steering components and see if something is blatantly loose. For example your track bar where it mounts to the axle is a definite spot to check. I'd grab a prybar of sorts and see if some bushings are obviously worn and have play in them.
For steering you can park against a curb as I did and have the wife or friend give quick (but low strength) jerks of the steering wheel back and fourth while you look/listen/feel for play in the steering components. There's a "dry steering test" you could search on here which will do a great job of this.
Balancing your tires is what "cured" it for me. Though it may not fix yours it sure as heck won't hurt. Though first the free things like tightening up loose components makes the most sense. If you can't find anything to be loose nor any bushings worn I'd go balance the tires. In my case I got this far and it was cured and been fine the last year or more.
Don't replace components having no idea if they're worn or not though.
Death Wobble From Hell - Standing Still??? MFortie TJ Wrangler Technical Forum 7 06-29-2010 02:07 PM
Death Wobble From Hell!!! Help. WKENDWARIOR69 TJ Wrangler Technical Forum 92 01-30-2010 03:53 PM
DEATH to the death wobble....wooohooo jeeperscreep04 TJ Wrangler Technical Forum 6 09-19-2009 02:31 PM
Death Wobble HELL!!!! njvixen JK Wrangler Technical Forum 17 04-08-2009 12:08 PM
is it death wobble or death steer frank_frank139 TJ Wrangler Technical Forum 4 03-06-2007 12:56 PM
