Ford explorer sport trac axle swap - JeepForum.com
post #1 of 10 Old 12-28-2012, 07:30 PM Thread Starter
tlspidle
Hey guys I just ran across an 2001 Explorer Sport Trac with a d2 axle which would match my Wrangler 4.10 gears. Is it identical to the 95-2002 Explorer D2 axle in width and 31 spline that I have been looking for an axle swap? Or should I pass and wait for one off a true Explorer?
Thanks
tlspidle is offline
post #2 of 10 Old 12-29-2012, 08:52 AM
Ben
Does it have drum brakes?
It probably has the 28 spline axle shafts.
Ben is offline
post #3 of 10 Old 12-29-2012, 11:32 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Originally Posted by WKdeuce View Post
..It probably has the 28 spline axle shafts.
Why would you suspect that?
I'd think it has 31 spline shafts since its pretty much an Exploder, but I cannot say for sure.
Wheelin98TJ is offline
post #4 of 10 Old 12-29-2012, 11:42 AM
freeskier93
http://www.jeepsunlimited.com/forums...d.php?t=371713
Explorer SportTracs with production dates of August 19, 2002 through June 29, 2005 are equipped with 31-spline axles and rear disc brakes and are exactly what was in the previously listed 95-2001 Explorer.
freeskier93 is offline
post #5 of 10 Old 12-29-2012, 12:00 PM
Wheelin98TJ
JEEP FREAK
Info from another forum says 2001 Sport Trac will be 31 spline, drum brakes, and identical to the Explorer axle.
http://www.explorerforum.com/forums/...d.php?t=100932
I believe this is true, but I cannot confirm.
post #6 of 10 Old 12-29-2012, 04:39 PM
Ben
I should have noted that it was just a guess, based on this write up:
Which states:
Before Aug 19, 2002, the Sport Tracs were equipped with the smaller 28-spline 8.8 axle shafts and used drum brakes.
Your link says other wise. Only 1 way to tell. Crack it open and count the splines.
Ben is offline
post #7 of 10 Old 12-29-2012, 04:50 PM
freeskier93
Only 100% foolproof way is to count the splines before you buy.
post #8 of 10 Old 12-31-2012, 08:46 AM Thread Starter
tlspidle
What is the difference between 28 and 31 axle spline count if the ratio is still 4.10? Just a little stronger?
tlspidle is offline
post #9 of 10 Old 12-31-2012, 08:50 AM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
About 33% stronger to be exact.
Mail crawling.
MisfitSeven is offline
post #10 of 10 Old 12-31-2012, 09:18 AM Thread Starter
tlspidle
Good to know, I will hold out for a D2 from an Explorer then.
Thank you
tlspidle is offline
