Ford 9" or 8.8" swap? - JeepForum.com
post #1 of 10 Old 07-05-2010, 10:13 PM Thread Starter
alex_c
So here's the deal.
I wanna run 33" tires, but I have 3.07 gears and a 30/35 combo.
I need lower gearing!
I have a line on a 9" from an EB with 3.55 gears for $350. From what I understand, this is an excellent axle.
My original build plan called for 4.10 gears from an 8.8 out of a late model explorer...but I don't think 3.55 gears would be that bad with 33" tires. Obviously the option to re-gear later would be there, if I want to go with 4.56 or 4.88 gears.
So all you guys with 3.55 gears and 33 tires, how is it? I know that's a common ratio for an XJ, and it would be nice to get an HP D30 with that gearing for a cheap match.
I need some advice!! What are the pros/cons of the 8.8" and the 9" respectively. I know the 9" is beefier and have two pinion bearings, and the 8.8" uses c-clips, but not a whole lot more about these axles.
I already have the brackets, I just need some axles
alex_c is offline
post #2 of 10 Old 07-05-2010, 10:19 PM
bruteboy
the 9 inch will have a 5 on 5.5 bolt pattern for the wheels
the 8.8 has 5 on 4.5 and will match your front
bruteboy is offline
post #3 of 10 Old 07-05-2010, 10:23 PM Thread Starter
alex_c
oh yeah, I forgot about that. I was wondering if the EB 9" was 5.5.
alex_c is offline
post #4 of 10 Old 07-05-2010, 10:24 PM
EugeneTheTJ
Tar Heel
EugeneTheTJ's Avatar
you can also run a much bigger tire on a 9"
9" can also be cut to the same WMS as stock. 8.8" is narrower
2016 TJ of the Year
Founder,
EugeneTheTJ is offline
post #5 of 10 Old 07-05-2010, 10:26 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
my buddy just put 2" springs and 33" BFG KM1s on his '89 YJ with 3.55 gears. its fine to drive, the power is there even with the carburetor.
but 4.10s would be optimum, even if you decided to go to 35s later on.
Mail crawling.
MisfitSeven is offline
post #6 of 10 Old 07-05-2010, 10:28 PM
EugeneTheTJ
Tar Heel
horrible advice. If you are planning on 35s I would get 4.56 or 4.88 gears.
2016 TJ of the Year
Founder,
post #7 of 10 Old 07-05-2010, 10:35 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
3.55 only works "ok" with 33" tires on the XJ because most XJs came with the 4-speed AW4 automatic transmission. An automatic transmission is much more forgiving of running the wrong (too high of a) ratio. 3.55 doesn't work well at all for 33" tires with a manual transmission.
Jerry Bransford is offline
post #8 of 10 Old 07-05-2010, 10:42 PM Thread Starter
alex_c
So it's well worth it to hold off and keep looking for an 8.8 with 4.10, discs, LSD, and proper wheel spacing.
alex_c is offline
post #9 of 10 Old 07-05-2010, 10:46 PM
KKiowaTJ
IMO get the 9". You can get a third member already set up with the gears you want on a spool or locker cheap. That and the 9" will hold bigger and has alot more potential. Good luck either way
MOPAR!
KKiowaTJ is offline
post #10 of 10 Old 07-05-2010, 11:45 PM Thread Starter
alex_c
yeah, I think it's going to be less overall hassle to run the 8.8
I don't think I'll go bigger than 35's any time in the near future.
alex_c is offline
ford , 9" , 8.8 , swap , advice , help
Ford 9" Swap w/PICS Apollo12227 YJ Wrangler Technical Forum 30 09-24-2010 04:07 PM
almost completed Ford 9" swap... Got a question Apollo12227 YJ Wrangler Technical Forum 6 02-26-2010 11:59 PM
Ford 9" Swap in a TJ SantaClos TJ Wrangler Technical Forum 23 03-13-2009 12:44 PM
Ford mustang 9" axle swap practicle? 9y5jwrangler YJ Wrangler Technical Forum 10 12-16-2008 06:58 PM
Boss Lady said "No go!" on my V8 swap anytime soon, but i can swap an auto tranny in! 97casteeltj TJ Wrangler Technical Forum 60 10-31-2008 11:32 AM
