Ford 9" from a 76 half ton - Page 3 - JeepForum.com
post #31 of 82 Old 07-13-2010, 08:06 PM Thread Starter
Apex
Recon death squad
Apex's Avatar
Reading away...I'll be right back.
Ok, scrap the CHP idea.
Staying LP with this 9".
Apex is offline
post #32 of 82 Old 07-13-2010, 08:07 PM Thread Starter
Apex
Recon death squad
Apex's Avatar
Originally Posted by Knuckelhead View Post
And how much with the ARB?...
Almost 2k for the same exact thing with ARB instead of detroit. Touche sir.
What specs can you give me on your 9"? If I was trying to build something similar what would I need to do to run 35 spline shafts? Simply a 35 spline carrier?
Apex is offline
post #33 of 82 Old 07-13-2010, 08:09 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
i think the 35 spline carriers use bigger bearings.
Mail crawling.
MisfitSeven is offline
post #34 of 82 Old 07-13-2010, 08:10 PM Thread Starter
Apex
Recon death squad
Apex's Avatar
Anyone regear a 9" on their own? I mean if the 3rd member carries the gears, then I could regear it on my work bench, right?
I feel like such a novice right now lol I am getting myself in over my head. I like it.
Apex is offline
post #35 of 82 Old 07-13-2010, 08:12 PM
flatlander757
Whatever you do, don't get a 35 spline ARB...
Is the 9" ARB going to be right soon? - Pirate4x4.Com Bulletin Board
This isn't as big of a deal, from the sounds of it but I don't know how hard you are on your Jeep.
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline
post #36 of 82 Old 07-13-2010, 08:13 PM Thread Starter
Apex
Recon death squad
Apex's Avatar
They do, something like 3.062" bearings or something...would that require a new 3rd member housing?
I have read every single link posted in this thread and all I have learned is:
1. a Currie Hi Pinion is pretty much as good as my super35
2. an LP 9" is plenty strong even with 31 spline stock axles (35" tire)
3. I need 35 spline axles to run 37s+
Apex is offline
post #37 of 82 Old 07-13-2010, 08:14 PM Thread Starter
Apex
Recon death squad
Apex's Avatar
You are such a killjoy...I am all set-up to run an ARB (compressor, air lines, switches)
I'm not opposed to running a detroit... I'd prefer an ARB since I don't compete, dig, or use cutting brakes, I think I will be ok.
Apex is offline
post #38 of 82 Old 07-13-2010, 08:36 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Large end bearing tube housing.
I have the Currie HP 9", 35 spline shafts, ARB and have been running it for 5 years on 35" tires without any problems.
I did the research and this is what fit my needs...
Knuckelhead is offline
post #39 of 82 Old 07-13-2010, 09:03 PM Thread Starter
Apex
Recon death squad
Apex's Avatar
Ok knuckel, so would I indeed need a new housing?
I'm going to look at and possibly pick this thing up tomorrow. So with that said, I will know more about this axle then...if it is indeed a 31 spline shaft, what size bearing does that mean it uses?
Apex is offline
post #40 of 82 Old 07-13-2010, 09:04 PM Thread Starter
Apex
Recon death squad
Apex's Avatar
Of all the info give in this thread, and all of the links posted...not one gives much info about how to actually build this thing and the PBB search function kind of sucks.
Apex is offline
post #41 of 82 Old 07-13-2010, 09:08 PM
wrangler1988
Ive been thru this debate before and for the time and effort u can get a spider 9 housing for what $400 and itll be much stronger or by the time u purchase brake parts and everything else u might as well by a currie Rock Jock rear hp60 and be done.
wrangler1988 is offline
post #42 of 82 Old 07-13-2010, 09:21 PM Thread Starter
Apex
Recon death squad
Apex's Avatar
I don't want a d60.
I've done enough to keep my pig as light as possible, tossing in the heaviest axle possible in order to run 35s and eventually move to 37s is kind of pointless.
I can get this axle for $75
I really think I'm going to use this as an opportunity to learn how to set up gears.
I can get a bracket kit for $225.
I'll really be into it for the cost of an ARB...that's really about it. Factor in selling my super35 and I'm pretty much into a ford 9" for about $5-600.
Apex is offline
post #43 of 82 Old 07-14-2010, 12:02 AM Thread Starter
Apex
Recon death squad
Apex's Avatar
Ok, my brain is getting fried...here are my pre-bedtime questions.
Will the stock 3rd member work with 35 spline shafts? Or do I need something like a currie/moser/strange 3rd? (I think I know the answer, but I've read so much stuff I'm going into overload)
What would be the largest tire you would run on the 31 spline axles? (I may just regear it to 4.11 and run it stock until I can offload the super35 and d30 and buy a big bearing 3rd member and 35 spline ARB and shafts)
Apex is offline
post #44 of 82 Old 07-14-2010, 12:07 AM
MisfitSeven
MAiL Crawler.
the biggest tire i will run on my 9" in my CJ will be 37"s. i bought a 9" cut to 56", 31 spline, but also chromo shafts.
well... when i finish it, i should say.
Mail crawling.
post #45 of 82 Old 07-14-2010, 08:08 AM
Chris98TJ
i guy i wheel with has a 9" with 31 spline cromos with 39.5 swampers on it. just for comparison
98 tj sport Aussie locked front and rear 4.10's HPD30 8.8 super short sye cv shaft 4.5 lift johnny joint adj. control arms 36in TSL's gen right hi fenders header exhaust custom rockers Solid axle covers f/r the list goes on
Leading bullet sponge for JF Call of Duty crew
X BOX GT- CHRIS98TJ
Chris98TJ is offline
ford 9 , 9" , tj , wrangler , swap , installation , half ton
jeep passenger half door "pops" open randomly? ogclew YJ Wrangler Technical Forum 10 12-02-2009 09:20 AM
Got the vanco brakes installed, painted half door panels, and got hit by a ford WILLY348 TJ Wrangler Technical Forum 14 01-30-2009 07:37 AM
Weird "Spitting" noise from back half of my Jeep RAAB3485 TJ Wrangler Technical Forum 8 08-29-2006 07:30 PM
can you "adjust" half door hinges? hmk_21 YJ Wrangler Technical Forum 7 02-11-2005 12:28 PM
