Ford 9" from a 76 half ton - Page 2 - JeepForum.com
post #16 of 82 Old 07-13-2010, 01:04 PM
Chris98TJ
So let's say it is a 31 spline axle. Will that hold up to rough wheeling locked on 35s? Or should I go with 35 spline shafts?
If I go 35 spline, it'll just take longer to get this under my Jeep as I will have to build it slowly as I save up money to do this.
yes, i have the 8.8 with the 31 spline shafts and they hold up well and i pound on it. the shaft sizes are very similar b/w these 2 axles
35 spline is for when you get into BIG meat 35's are still small. id say 38's are getting into the big category. but then if you ran alloy 31 spline you could run bigger
98 tj sport Aussie locked front and rear 4.10's HPD30 8.8 super short sye cv shaft 4.5 lift johnny joint adj. control arms 36in TSL's gen right hi fenders header exhaust custom rockers Solid axle covers f/r the list goes on
Leading bullet sponge for JF Call of Duty crew
X BOX GT- CHRIS98TJ
Chris98TJ is offline
post #17 of 82 Old 07-13-2010, 06:45 PM Thread Starter
Apex
Recon death squad
Apex's Avatar
Ok so the stock shafts are good for my application for now...
my issue is I would like to step up to 35 spline shafts so that I can do an ARB one time and be done with it...can I simply swap to 35 spline non alloy factory replacement shafts for the time being? Something from superior or ten factory?
Or should I just save up and do the Currie hi9 3rd member with 4.10s and ARB, assembled for $1400?
So then I'd have about $1600 into a near bulletproof high pinion 9".
Apex is offline
post #18 of 82 Old 07-13-2010, 07:02 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Can you show me where you can get that for $1400?...
Knuckelhead is offline
post #19 of 82 Old 07-13-2010, 07:04 PM Thread Starter
Apex
Recon death squad
Apex's Avatar
just the center section..hold on let me see if I can reproduce this.
Apex is offline
post #20 of 82 Old 07-13-2010, 07:08 PM
flatlander757
Don't get the Currie Hi9... it uses freaking 8.8 gears.
IMO I'd pass on it... aftermarket parts and housings and everything are so cheap you're better off just spending a bit extra and buying a nice housing to start and a Moser or Strange center section(if it's a rear application). Or the $2000 TRUE Hi9.
Look at www.ruffstuffspecialties.com at their fabricated Ford 9" housings. Call Dan and talk to him about it, he's a very nice guy and knows a lot. If you call now I'm willing to bet he will pick up.
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline
post #21 of 82 Old 07-13-2010, 07:09 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
you are on the right track with a hi9 center section. the 9"s have THE lowest hanging pinion of all the axles. but hi9s are 3-4 times the price of a regular 9" third member.
the big question now is: what to run up front to match the width and strength of your rear 9"?
Mail crawling.
MisfitSeven is offline
post #22 of 82 Old 07-13-2010, 07:10 PM
DBLJ
DBLJ's Avatar
31 spline is childs play for the 37's you want. Get 35 spline if you really want to build it from the start. Get some lower gearing too. Currie runs 8.8 gears in their hi9. Not good. They also run on the coast side of the gears.
DBLJ is offline
post #23 of 82 Old 07-13-2010, 07:15 PM
JunkJeep228
1994 XJ Cherokee
The ford 9 is over hyped. The only thing good about it is the aftermarked availability of parts, which you will need if you plan on doing anything serious with it. Race cars use them because of the ease of access to the internals. Ford 9"= expensive and heavy. Chevy 12 bolt= equaly strong and cheap. But buy it anyway for 75$, u can turn around and sell it for way more.
"Wheel it, Break it, Build it better." Words to live by.
JunkJeep228 is offline
post #24 of 82 Old 07-13-2010, 07:17 PM
flatlander757
Exactly.
Apex... read this before you think about putting a Currie HP 9" in the rear:
currie high pinions - Pirate4x4.Com Bulletin Board
Currently Jeepless.
post #25 of 82 Old 07-13-2010, 07:20 PM
JunkJeep228
1994 XJ Cherokee
Well, what am i saying, the only ones i've ever seen break were behind 600+ hp motors on the strip and totaly stock. Plenty strong enough for wheelin.
post #26 of 82 Old 07-13-2010, 07:40 PM
Knuckelhead
AFSOC Retired
For 35" tires, the Currie HP will work just fine. Shave the axle and it has 3/4" more clearance than a d35...
post #27 of 82 Old 07-13-2010, 07:42 PM
DBLJ
DBLJ's Avatar
He has plans for 37's so then its a crapshoot.
DBLJ is offline
post #28 of 82 Old 07-13-2010, 07:45 PM Thread Starter
Apex
Recon death squad
Apex's Avatar
I would like to eventually run 37s on this axle.
And I lied it looks like a CHP 9" third with a Detroit is about $1600...
Apex is offline
post #29 of 82 Old 07-13-2010, 07:46 PM Thread Starter
Apex
Recon death squad
Apex's Avatar
Originally Posted by flatlander757 View Post
Exactly.
Reading away...I'll be right back.
Apex is offline
post #30 of 82 Old 07-13-2010, 08:00 PM
Knuckelhead
AFSOC Retired
And how much with the ARB?...
ford 9 , 9" , tj , wrangler , swap , installation , half ton
jeep passenger half door "pops" open randomly? ogclew YJ Wrangler Technical Forum 10 12-02-2009 09:20 AM
Got the vanco brakes installed, painted half door panels, and got hit by a ford WILLY348 TJ Wrangler Technical Forum 14 01-30-2009 07:37 AM
Weird "Spitting" noise from back half of my Jeep RAAB3485 TJ Wrangler Technical Forum 8 08-29-2006 07:30 PM
can you "adjust" half door hinges? hmk_21 YJ Wrangler Technical Forum 7 02-11-2005 12:28 PM
