Ford 9" from a 76 half ton - JeepForum.com
post #1 of 82 Old 07-13-2010, 10:40 AM Thread Starter
Apex
Recon death squad
Apex's Avatar
What should I know, what should I expect...I can get it for $75.
I need some info.
Apex is offline
post #2 of 82 Old 07-13-2010, 10:44 AM
Sundowner
Strong axle. Lots of options and parts. Full width. I'd buy it for that kind of money and then practice tearing down and rebuilding it, if nothing else.
Sundowner is offline
post #3 of 82 Old 07-13-2010, 10:51 AM Thread Starter
Apex
Recon death squad
Apex's Avatar
I've been wanting a 9", I know some basics but that's about it...
I think I'll be picking it up regardless. What I was hoping to find out is what spline shafts this thing might have...also how wide is it?
Apex is offline
post #4 of 82 Old 07-13-2010, 11:07 AM
Sundowner
Here's a bookmarked page I have. Lots of various info...as a truck rear, I think you'll likely have 31 spline shafts and a C7 housing. Don't quote me, though.
Ford nine inch differential cases +
post #5 of 82 Old 07-13-2010, 11:08 AM Thread Starter
Apex
Recon death squad
Apex's Avatar
Atleast it'll be good info for when I go look at it...Thank you.
Apex is offline
post #6 of 82 Old 07-13-2010, 11:10 AM
Sundowner
Sorry, if I'd known that you wanted esoteric specifics, I would have posted that link sooner. Hope it helps.
post #7 of 82 Old 07-13-2010, 11:11 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Should be ~60" wide, 28 or 31 spline and use big bearings.
REAR AXLE I.D. identification
Ford 9-Inch Rear axle lengths and information
The Ford 9-inch Rear End
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #8 of 82 Old 07-13-2010, 11:24 AM Thread Starter
Apex
Recon death squad
Apex's Avatar
And remind me how wide the TJ axles are again...
Apex is offline
post #9 of 82 Old 07-13-2010, 11:26 AM
Unlimited04
60"
the full size trucks/vans w/ 9'rs were mostly 60-65"...but i dont know where those breaks happened...i believe it was 78 or 77-ish got 65"...i'm not positive, and the sources i have show either/or it should be 5 on 5.5 i think....
65" is probably better actually...gives you the option run wheels with more backspacing and have the tires sitting about the same as you do now, or push them out even more for wider stance. JK's are 65".
Useful Write-Ups:
Funny:
post #10 of 82 Old 07-13-2010, 11:31 AM Thread Starter
Apex
Recon death squad
Apex's Avatar
60"
Lol the gears in my head are turning.
I think I'll pick this thing up regardless of the width and see what happens.
Apex is offline
post #11 of 82 Old 07-13-2010, 11:33 AM
DBLJ
DBLJ's Avatar
Do it. 9's are awesome.
DBLJ is offline
post #12 of 82 Old 07-13-2010, 11:40 AM Thread Starter
Apex
Recon death squad
Apex's Avatar
It'll be a process, but it'd set me up for 37s for sure.
Now I know it'll be 5.5" bolt pattern, but can't I just redrill the shafts and brake drums?
Apex is offline
post #13 of 82 Old 07-13-2010, 12:06 PM
DBLJ
DBLJ's Avatar
Get adapters? IIRC you have the 35 rear? A 9 will get you up to 40's with the right 3rd if you ever go that big.
DBLJ is offline
post #14 of 82 Old 07-13-2010, 12:14 PM Thread Starter
Apex
Recon death squad
Apex's Avatar
Yup, s35 kit. I'd like to build the 9" as my "last axle I'll ever need" type of build.
My long term plans don't have 42" tires in them.
Apex is offline
post #15 of 82 Old 07-13-2010, 12:42 PM Thread Starter
Apex
Recon death squad
Apex's Avatar
So let's say it is a 31 spline axle. Will that hold up to rough wheeling locked on 35s? Or should I go with 35 spline shafts?
If I go 35 spline, it'll just take longer to get this under my Jeep as I will have to build it slowly as I save up money to do this.
Apex is offline
ford 9 , 9" , tj , wrangler , swap , installation , half ton
jeep passenger half door "pops" open randomly? ogclew YJ Wrangler Technical Forum 10 12-02-2009 09:20 AM
Got the vanco brakes installed, painted half door panels, and got hit by a ford WILLY348 TJ Wrangler Technical Forum 14 01-30-2009 07:37 AM
Weird "Spitting" noise from back half of my Jeep RAAB3485 TJ Wrangler Technical Forum 8 08-29-2006 07:30 PM
can you "adjust" half door hinges? hmk_21 YJ Wrangler Technical Forum 7 02-11-2005 12:28 PM
