Ford 8.8 swap - JeepForum.com
post #1 of 5 Old 06-22-2010, 02:48 PM Thread Starter
Jacola11
Ford 8.8 swap
i just purchased an 8.8 axle with drum brakes and i have an idea what i need to do to have it swap it into my 99 tj for 35 inch tires
my list of what i know i need :
8.8 tj brackets
new brake lines
aussie locker
4.88 gears
adjustable upper control arms
can someone help me finish my list i would be very grateful because this is my first time venturing into axles and my knowledge on them is limited haha
thanks a bunch
Custom 3 link front f150 leaf swap rear.
103" wheelbase
Build thread: http://www.jeepforum.com/forum/f22/jasons-1999-tj-1217053-new/
Jacola11 is offline
post #2 of 5 Old 06-22-2010, 02:53 PM Thread Starter
Jacola11
oh and it is a 31 spline
103" wheelbase
Jacola11 is offline
post #3 of 5 Old 06-22-2010, 02:55 PM
JCWJEEP
2010 JK Wrangler
First you should use the search bar to find the numerous 8.8 swap threads on this forum. I think there's one near the bottom of page 1 of this forum too btw.
Second you should read this thread at least 3 times: 8.8 FACTS, OPINIONS & HOW-TO'S (F.A.Q.) - JeepsUnlimited.com Forums
I assure you that that thread has all of the info you will need.
If you need clarification or advice on anything then ask away.
But research first.
JC Whitney Jeep Team
JCWJEEP is offline
post #4 of 5 Old 06-22-2010, 02:56 PM
Chris98TJ
go to the junkyard and get some disc brakes
98 tj sport Aussie locked front and rear 4.10's HPD30 8.8 super short sye cv shaft 4.5 lift johnny joint adj. control arms 36in TSL's gen right hi fenders header exhaust custom rockers Solid axle covers f/r the list goes on
Leading bullet sponge for JF Call of Duty crew
X BOX GT- CHRIS98TJ
Chris98TJ is offline
post #5 of 5 Old 06-22-2010, 02:58 PM
JCWJEEP
2010 JK Wrangler
I also would recommend finding an 8.8 with disc brakes. They're just as common as 8.8's with drums and will only add about $60 to your total cost if you do the brake setup the way I describe here: http://www.jeepforum.com/forum/f9/fo...ml#post9668944
JCWJEEP is offline
ford 8.8 , 8.8 , swap
Ford 4.6L vs 5.0L V8 swap spiderman637 TJ Wrangler Technical Forum 105 06-22-2012 06:45 AM
ford 8.8 swap buZZBomb_ YJ Wrangler Technical Forum 1 09-17-2008 10:50 PM
Ford 8.8 swap millersjeeps TJ Wrangler Technical Forum 5 03-23-2008 07:44 AM
Ford 8.8 Swap ? DaSham58 YJ Wrangler Technical Forum 8 05-06-2007 08:39 PM
Ford 390 swap jesse187 YJ Wrangler Technical Forum 12 03-07-2007 03:28 PM
