Ford 8.8 rear axle swap question - JeepForum.com
post #1 of 4 Old 08-08-2010, 03:43 AM Thread Starter
tha_Toad
Does any one know what year explorer i can find the 8.8 axle with 3:73 gear ratio and limited slip diff in? i know the 93 has it but im lookin to see if i can find the year that has the disc brakes instead of the drum breaks.
Jeep Wrangler - a brick powered by a hamster and has the aerodynamics of a house.
tha_Toad is offline
post #2 of 4 Old 08-08-2010, 04:17 AM
alecmcmahon
Everything you need to know about 8.8s in a TJ
8.8 FACTS, OPINIONS & HOW-TO'S (F.A.Q.) - JeepsUnlimited.com Forums
alecmcmahon is offline
post #3 of 4 Old 08-08-2010, 06:15 AM
dbshea
that site helped me so much during my swap, take the time and read the whole thing
dbshea is offline
post #4 of 4 Old 08-08-2010, 06:58 AM
Osmosiz
1973 FSJ Wagoneer
x2, i have 3.73 gears for a 8.8 sitting around. if you need it, pay shipping and ill send em.
2000 XJ
will work for jeep parts
Osmosiz is offline
axle , swap , ford 8.8
Question Regarding Pinion Offset on Ford 8.8/Axle Swap misbehavin YJ Wrangler Technical Forum 12 02-27-2012 05:08 PM
Ford 8.8 axle swap... jeepjeep09 TJ Wrangler Technical Forum 5 12-30-2009 10:11 PM
Ford 8.8 rear axle swap...mounting info. Chewie4299 TJ Wrangler Technical Forum 27 11-30-2008 08:31 PM
Need your 2 cents on 8.8 ford rear axle swap. Dmax5er YJ Wrangler Technical Forum 13 08-31-2008 12:02 PM
Ford 8.8 axle swap jw98tj TJ Wrangler Technical Forum 2 07-23-2004 06:22 PM
