Ford 8.8/HP30 swap and regear - Page 5 - JeepForum.com
post #61 of 67 Old 11-25-2012, 08:25 PM Thread Starter
freeskier93
Originally Posted by SHAKEnBLAKE View Post
Great thread man! I just bought a TJ with an 8.8 and it doesn't have the parking brake hooked up. What do I need to make that happen? Just a ZJ cable? Any specific parts needed on the 8.8 end of things?
All you need are the ZJ cables, nothing else. Bough mine from Rock Auto, was DORMAN Part # C660058. On Rock Auto they have pictures, just double check it's the correct ends before buying.
freeskier93 is offline
post #62 of 67 Old 01-08-2013, 10:55 AM
SHAKEnBLAKE
Thanks. Just ordered them. I was under my jeep the other day and realized that it didn't even have the bracket for the cables to attach to. Not sure why anyone took the time to remove it, but I got one from a part out.
Ohio4x4.com
SHAKEnBLAKE is offline
post #63 of 67 Old 01-09-2013, 01:58 PM
bronco2guy
Great build. I will be putting an 8.8 in rear of my Jeep also.
bronco2guy is offline
post #64 of 67 Old 03-02-2013, 11:03 PM Thread Starter
freeskier93
Totally forgot about this.
Everything got done before school started. From the last picture I was scrambling to get it done and don't have any more pics. Basically though I got new Nitro Chromoly shafts with Spicer joints installed and new Spicer ball joints. Got everything buttoned up and went wheeling with unlimited04. This was unfortunately my last wheeling trip of the year!
This is late August of last year. As of now that axles are doing great, not issues. Can't wait for summer to come and do some more wheeling.
post #65 of 67 Old 03-04-2013, 12:24 PM
Gordon-0
Great info
Subscribed!
Gordon-0 is offline
post #66 of 67 Old 03-28-2013, 02:25 PM Thread Starter
freeskier93
Update:
Changed the gear oil in both axles this morning! The gears look GREAT! Rear oil definitely need to be changed, it had turned into a nice metallic paste, and the front was a bit metallic. I think the obvious answer to that is the rear is the main drive axle where the front just spins not under load. I think I can call the gear install a 100% success.
post #67 of 67 Old 08-20-2014, 09:13 PM
Cuder
Great write-up. I just made a large order from ECGS and re-read your thread. I have a buddy that's going to weld my brackets and install the gears front and rear.
My Build Thread:
Cuder is offline
Ford 8.8 swap or regear question dougbrown YJ Wrangler Technical Forum 4 09-16-2011 06:43 PM
What lift is required for HP30/Ford 8.8 swap? 2GPS4ME TJ Wrangler Technical Forum 8 08-15-2010 11:29 PM
HP30 regear timpenny92 TJ Wrangler Technical Forum 1 06-21-2010 08:34 PM
hp30 swap questions globalnomad TJ Wrangler Technical Forum 9 02-14-2010 10:30 PM
REGEAR Question on Ford 8.8 daddoty YJ Wrangler Technical Forum 21 07-26-2006 01:02 AM
