Ford 8.8 carrier weak link?!?! - JeepForum.com
post #1 of 12 Old 12-29-2009, 07:54 AM Thread Starter
dkeith
Hey, I have a Ford 8.8 LSD that I'm swapping on my 02 TJ. My mechanic has everything apart and discovered that the carrier bearing has worked itself loose and has grooved the inside of the carrier and was causing some slack. He checked around with another 4x4 mechanic and was told that he could drive a pin to tighten the bearing up but no guarantees how long it would hold. Not sure if I'm describing this well but my question is would I be better off replacing the carrier?
If so, I have no clue which one to go with as I don't want a fully locked because I will be using it as a dd. Thanks for any advice.
dkeith is offline
post #2 of 12 Old 12-29-2009, 08:00 AM
cfmiller58
how about a selectable? arb or ox, even though youve doubled the price of your build now, im sure youll want one later if youre putting an 8.8 in
Black Jeep Society
cfmiller58 is offline
post #3 of 12 Old 12-29-2009, 08:04 AM
mdm
Farm Wheeler
I'm not sure what you mechanic is trying to do with the "pin" but from the sounds of things I'd be replacing the carrier.
What was the reason you mechanic was inside the differential? Regear?
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #4 of 12 Old 12-29-2009, 01:49 PM
06WranglerX
Yes the carrier is the weak link if your using your rig hard off road, from what you described I would get a new carrier and not take the chance of a half *** fix. In fact I am kinda confused with the whole "pin" thing myself, seems in this case a new carrier should be ordered and put in to make sure nothing happens.
I see you said you dont wanna be fully locked as it is a DD, however, as an 8.8 owner who lives in NJ I am VERY happy with my Detroit, hasnt been bad in the snow or rain and you dont even notice its there until your making a tight turn in a parking lot, plus it eliminates the weak point just something to think about, good luck!
Originally Posted by lumpster View Post
he made it clear when he said he was. He didnt ask for a photo ID of you did he.
People need to be a little more trusting, Its not like we are on a convict and rapist forum.
Upon further reflection I've decided I've had enough of this BS and you are now on my ignore list.
06 Red Wrangler X 6 speed hard top
Ford 8.8 Detroit locked, 4 inches of lift, 33 inch BFG KM2's and some other stuff.
06WranglerX is offline
post #5 of 12 Old 12-29-2009, 05:18 PM Thread Starter
dkeith
Well, it started with having to remove the axle shafts to put new backing plates on (the things that hold the drum emergency brakes), then I asked him to go ahead and replace the axle bearings and check it all out. While he was taking it down, he noticed that things weren't tight where they should be...I can't recall specifically what wasn't right. Upon further inspection he discovered the bearing problem.
I don't know anything about lockers and I'm only going to be offroad 10 to 15% of the time. I may just go with another limited slip carrier, the lockers are pricey and I've already dumped a ton into this axle swap.
dkeith is offline
post #6 of 12 Old 12-29-2009, 05:40 PM Thread Starter
dkeith
I'm thinking about going with an Eaton E lock. Since I am not a hard core off roader and I really don't want to go through the trouble of getting an air compressor and all the plumbing. Anyone running one on a 8.8 that has any feedback?
dkeith is offline
post #7 of 12 Old 12-29-2009, 06:09 PM
06WranglerX
Wheeling98tj has had one in his 8.8 for a few years without any issues, however, I have not had any first hand experience. I would really consider your options here, if you dont wheel to much and the types of wheeling you do don't need a locker perhaps a lsd would be in your best interest for $$ atm.
post #8 of 12 Old 12-29-2009, 06:25 PM
UTWeezul
As for your locker, I have no clue what to tell you. Mine is a DD and I have a Detroit in my 8.8 and don't notice it being there at all.
But definitely replace the carrier if you decide to stay with the LSD. I've heard the LSD's can be rebuilt to "lock up" better than stock to help you out off road but not sacrifice much on road.
35" MTR Kevlars
TNT Phantom Fenders/PSC Comp Cut corners
HP30 and 8.8 w/ lockers
103" Wheelbase
UTWeezul is offline
post #9 of 12 Old 12-29-2009, 08:17 PM
Twizted
Twizted's Avatar
I bought an 8.8 after breaking my d35 about a year ago. I put on 35's and 2 days later I did a hard launch on pavement. It grenaded the gears, ring and pinion and spiders. I was confused and asked around on the mustang forums, a very nice and knowledgable member informed me that the weak link in an 8.8 was the stock carrier, it flexed under high torque situations and can cause what I did. He said it's common on mustangs producing over 600hp. He asked what motor I was running and was amused when I stated a stock 4.0 I6 in a Wrangler. I then clarifed the 35's and he learned from me almost as much as I learned from him. . That being said I went with a Detroit Tru-track F/R and regeared to 4.56's while it was apart. No more problems with hard launches! Tru-track is great too, very strong limited slip and every time I do tight turns in a parking lot the tires chirp, it locks up great and totally changed the obsticles and trails I can do. I would definately change out that carrier.
00' TJ 4.0 5spd: D30/8.8 w/Tru-Tracs F/R 4.56's, 5" lift on 35'sSOLD
Twizted is offline
post #10 of 12 Old 12-29-2009, 10:56 PM
CaleTJ99
I have the LSD in my 8.8 and on trails if i give it enough torque i can get both tires spinning. One day i'd like to put an e locker in it but for now it being my DD the LSD works great. Go to a junk yard pull a new one you'll be good to go
CaleTJ99 is offline
post #11 of 12 Old 12-30-2009, 06:43 AM
Twizted
Twizted's Avatar
Just to clarify and add more info, the 8.8 I bought was a LSD w/ 3.73's. Now it was out of a junkyard and we just changed the fluid so not sure the condition of everything but the stock carrier did flex and toasted everything inside except the shafts. It was very awkward putting it in gear and letting out the clutch with no results but the rpms rising.
Twizted is offline
post #12 of 12 Old 12-30-2009, 06:53 AM
mdm
Farm Wheeler
It's a good thing your guy opened it up. I can't find the reference now but seems like one of the sources I reviewed when researching the 8.8 axle said the carrier for the open 8.8 is quite a bit stronger than the one used with the LSD.
mdm is offline
Dana 30 Has A Weak Carrier? cyberunlimited2 TJ Wrangler Technical Forum 8 07-24-2008 08:56 AM
Rubicon weak link? cola8d8 JK Wrangler Technical Forum 7 01-17-2008 07:21 AM
Weak link on jeep? sycotik TJ Wrangler Technical Forum 3 05-23-2007 09:05 PM
8.8 weak carrier? BillR TJ Wrangler Technical Forum 6 10-30-2005 08:26 PM
Weak link Caka TJ Wrangler Technical Forum 2 02-13-2003 07:39 AM
