ford 8.8 brackets for TJ - JeepForum.com
post #1 of 10 Old 01-09-2003, 11:16 PM Thread Starter
macb
macb's Avatar
has anybody seen ford 8.8 brackets for less than 200?
I am going to probably put in a super 35 kit next week - putting an 8.8 in the TJ is still to expensive. besides I can put in the super35 with detroit for 650 installed. the 8.8 is looking like a grand with all the hardware that you have to get.
3.5" Terraflex, 1" BL, Flat Belly Pan, Currie Steering, 35s, Cowl Intake, blah blah blah:
Bob Supplee:
or (405) 799-8977
Stu Olson's great jeep resource site:
macb is offline
post #2 of 10 Old 01-10-2003, 12:27 AM
igofshn
Locked @ both ends
igofshn's Avatar
I'd like to know where you get a Super 35 for $650 installed. The cheapest I found was $800 + install.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #3 of 10 Old 01-10-2003, 12:39 AM Thread Starter
macb
macb's Avatar
I have hooked up with a great little shop here local - he is a dealer for yukon and superior, others. He already had it and gave me a deal since I am getting all my work done there. The kit itself will have a 5 year warranty, full floating rear end, timkens, full detroit - all for 450 + 200 install. and it turns out he makes bumpers for other companies (names you would know) so I am going to put together a custom tube wraparound bumper and weld it up myself after he bends my tube. I am also getting a chromoloy tie rod with johny joints on it - $130 (installed). But I also get in and help where I can when my jeep is there so that may affect my price.
I want the 8.8 but everybody tells me I can step up to 33s with a super 35 no problem.
Bob Supplee:
or (405) 799-8977
macb is offline
post #4 of 10 Old 01-10-2003, 08:20 AM
igofshn
Locked @ both ends
igofshn's Avatar
I'm doing the super 35 with Detroit and gear change (4.10's) in a week. You will be able to go to 35's without a problem. I've talked personally with peple that have the kit and run 35's and have no problems. The 35 kit is not going to break. Yes the housing is not a 44 or 8.8 but the insides are going to be comparable. I know all the 8.8 fans are going to chime in but both axles are c clip and I didn't wnat to change to another c clip axle. I looke into a 44 from another TJ but it was too expensive. With gears lockers and axle 2k+ (rear only), I'm doing both axles with Detroits in both and gears for under 2k.
igofshn is offline
post #5 of 10 Old 01-10-2003, 10:15 AM
Deathdealer
Deathdealer's Avatar
A grand??? No. Close if you need to regear it and throw in a locker.
My axle cost me $300, M.O.R.E. has the brackets for $300 its 3.73 so it matches my front (yes you can find 4.10 for just a little bit more) ...but look at the benefits...
Axle Type------------------Dana 35---------Dana 44-----------8.8 Ford
Weight---------------------155lbs-----------167lbs-------------174lbs
Ring Gear Dia-------------7.56"-------------8.5"----------------8.8"
Ring Gear Bolts-----------(8) 3/8"----------(10) 3/8"---------(10) 7/16"
Pinion Diameter----------1.406" / 26-------1.375" / 30-------1.625" / 30
----------------------------Spline-------------Spline-------------Spline
Axle Diamter--------------1.160" / 27-------1.310" / 30---------1.320" / 31
Axle Strength (max ft.lbs) 4,161------------5,982----------------6,122
Tube Diameter-------------2.5"-------------2.75"-------------3.25"
Factory Discs Available------no--------------no---------------yes ('95+)
Comparison pictures between D35 and 8.8
Ford 8.8 Ring Gear on the left, Dana 35 on the right
Ford 8.8 Spider Gears and axle shaft on the right, Dana35 on the left WOW
-DD
Black '98 TJ 4.0 Sport, Teraflex 2.5", JKS 1" BL, Currie 1" MML, Dana 30/Ford 8.8, AA HD SYE, Teraflex QD, Teraflex Oil Pan Skid, Skid Row Steering Box Skid, Poorboy Front & Rear Bumpers (w/ Swingout), JCR Offroad Rocker Guards, Garvin Trail Rack, Borla Header, 305/70/16 BFG MT/KMs, -Go Bruins!
Black Jeep Club #666
Deathdealer is offline
post #6 of 10 Old 01-10-2003, 10:36 AM
igofshn
Locked @ both ends
igofshn's Avatar
You forget Detroit does away with spiders and carrier which is the main weak point of a 35.
igofshn is offline
post #7 of 10 Old 01-10-2003, 10:42 AM
Bob J
Bob J's Avatar
1984
and the super 35 also upgrades to 1.31" axle shafts.. I don't think that .01" will make much of a difference (not that I'm a fan of the super 35, I still think it's a cheap fix)
Also just to update your info, the D44 does come with Disc Brakes
1984 AMC Eagle
2006 TrailBlazer
Sig v.55
Bob J is offline
post #8 of 10 Old 01-10-2003, 10:46 AM Thread Starter
macb
macb's Avatar
for me it came down to $$
since I am getting my super35 so cheap (650-installed) it makes more sense...If I was paying 799 plus 300 install then an 8.8 would make more sense.
Bob Supplee:
or (405) 799-8977
macb is offline
post #9 of 10 Old 01-12-2003, 09:37 PM
The General
Also keep in mind, though the 8.8" is also a c-clip axle, if you get a 95 and older with disc brakes, the discs will retain the axle shaft in the event of breakage. This effectively eliminates the disadvantage of a c-clip.
The General is offline
post #10 of 10 Old 01-13-2003, 08:54 PM
crazyTJ
With an 8.8, you need a SYE, don't you. A guy I know installed one in his TJ, and the pumpkin is offset to one side about 1.25", just enough to make some pretty good vibes. Thats the reason I am not going 8.8, the addedd cost of the SYE. Just my usually unuseful thoughts.
Crazy
97 TJ 4 cyl/5 speed/4:88's,6+"of lift,37 Parnelli Jones on DC-1's,9"rear/Moser alloys,Dana30/Evolution alloys,lockers,cage, winch,4 to1 ,lots of other stuff!!!
Wife that hates my Jeep
crazyTJ is offline
Brackets from TJ D35 to Ford 8.8? bvjeep TJ Wrangler Technical Forum 28 12-09-2009 09:05 AM
8.8 swap-does it use Ford or Jeep sway bar brackets? jpony645 TJ Wrangler Technical Forum 6 10-20-2009 12:38 PM
Just swaped a Ford 8.8 used mad4wd brackets gzimnoch TJ Wrangler Technical Forum 0 03-18-2009 12:23 PM
Ford 8.8 Brackets.... JJs99TJ TJ Wrangler Technical Forum 12 12-09-2005 09:18 AM
Ford 8.8 Brackets for Jeep TJ? dfowler TJ Wrangler Technical Forum 19 09-28-2005 10:26 AM
