Ford 8.8 backing plate--removal? - JeepForum.com
post #1 of 4 Old 11-29-2009, 10:01 PM Thread Starter
dkeith
I'm in the middle of my 8.8 swap and have new disk backing plates with the drum brake components built on that I ordered from Currie. Now my question is, how do I take off the old backing plates? I've searched but couldn't find the answer. Thanks.
dkeith is offline
post #2 of 4 Old 11-30-2009, 01:34 AM
Jeepster83
remove all of the drum brake stuff and unbolt the backing plate. youll have to have the axles removed to get them off though unless you cut them. but youll have to have them removed to install the new stuff anyway.
Being right has nothing to do with arrogance. It's only perceived that way by those that are wrong.
WyoTech West Sacramento - Graduated 8/19/2011
Back into my Jeep... finally.
Jeepster83 is offline
post #3 of 4 Old 11-30-2009, 07:10 AM Thread Starter
dkeith
Is there a write up on axle removal?
dkeith is offline
post #4 of 4 Old 11-30-2009, 08:26 AM
Jeepsr4me19
1976 CJ5
Axle is simple.
Just pop the diff cover.
remove the cross pin retaining bolt.
Remove cross pin.
push in on the axle shafts at the lug area. Spin a little. Then look in the diff and remove the C clips.
Once they are removed pull axle out.
If your explorer axle had disk brakes there will be a smaller set of drum brakes.
To remove those take the little clips off the pointy metal spears(they look like spears to me).
Then the bottom spring and adjuster.
Then pry the shoes off. Those top 2 springs are a pain, I just left them on and removed them as a
set.
The backing plate is held on with 4 bolts that are simple once all the stuff is out of way.
Jeepsr4me19 is offline
Windshield hinge backing plate 850GLT TJ Wrangler Technical Forum 1 06-08-2008 06:36 AM
Backing plate question..... Dudewayne TJ Wrangler Technical Forum 3 08-19-2007 02:27 PM
91 Rotor Backing Plate dynamic098 YJ Wrangler Technical Forum 7 04-15-2007 11:23 PM
Backing Plate how to remove Brindle19 YJ Wrangler Technical Forum 3 11-23-2005 09:54 PM
painting drum brake backing plate kaybone TJ Wrangler Technical Forum 3 01-09-2005 03:01 PM
