Ford 4.6L vs 5.0L V8 swap - JeepForum.com
post #1 of 106 Old 12-24-2007, 06:39 AM Thread Starter
spiderman637
After doing numerous little things to my 4.0L I have decided that it is time to stop playing with an engine that was never intended to be a performance engine and swap something else in with a few more cylinders and a lot more potential. I am really interested in swapping in a newer modular Ford V8, but haven't been able to find any info on a swap. I know I can get an adapter to bolt a 5.0L to my AX15, but I think the 4.6L would be a more efficient motor and is probably lighter as well. Of course, the 4.6L Jeep stroker is another option, but as odd as it sounds I think the V8 would get better mileage due to A) it not having to work as hard and B) it being a newer more efficient engine. I am currently running 4.56 gears with 35" BFG All Terrains and the 4.0L has a header, full exhaust, TB spacer, MSD 6AL, Super Conductor wires and Blaster 3 coil and Bosch Platinum +4's.
Friends help you move, good friends help you move bodies
spiderman637 is offline
post #2 of 106 Old 12-24-2007, 07:10 AM
tjthorson
tjthorson's Avatar
2014 JK Wrangler
JMO, but I'll let you in on a little secret. The Jeep itself was never intended to be a performance vehicle either, let alone the 4.0.
With your 35's - why not just go 4.88 or 5.13s and call it a day. Take the extra money you saved on the swap and you can pick up a nice Mustang to beat on the track with.
Todd Thorson
2013 Jeep Wrangler Sport Orange Crush
Orange Crush Jeep Club Member #50
2013 Jeep Wrangler Unlimited Gecko Green (Wife's DD)
Gecko Green Jeep Club Member #1
2005 Yellow Unlimited Rubicon (sold)
My Band! ->
tjthorson is offline
post #3 of 106 Old 12-24-2007, 07:19 AM
RKBA
One advantage of the older Mustang 5.0 engine swap is that it is flat out easy. I don't think you have any emissions inspection issues in TN, so the older (pre-92) engine shouldn't cause you any trouble. I LOVE injected 302s, but quite frankly they aren't that strong of an engine. They are light, easy to cool, and have a world of aftermarket support. With a pair of shorty headers and some Flowmaster mufflers a Mustang 5.0 is one of the sexiest sounding stock engines of all time.
The 4.6 Fords are less commonly swapped than the Gen III GM stuff nowadays so there is a bit less aftermarket support for it. I believe the overall width of the modular Ford engines make them less attractive. If you need an OBDII era EFI, I would look at GM instead of Ford. (I can't believe I just said that, ugh, Garbage Motors......)
I wouldn't count out a stroker Jeep inline 6. The overall cost start to finish would probably be less, all your accessories and gauges will work, and the HP/TQ numbers are definitely in the small V8 category. Add in the "stealth factor" and it seems like a good choice.
2002 TJ SE
2006 LJ
2007 Rockwood Freedom 2280
RKBA is offline
post #4 of 106 Old 12-24-2007, 08:14 AM
bruker
I might be wrong but from what I read on some Mustang forums I believe the 4.6 is actually a bit larger (in size not displacement) than the 5.0.
Sure a spoonful of Draino will clean you out, but it will also leave you feeling kind of hollow inside....
bruker is offline
post #5 of 106 Old 12-24-2007, 08:29 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Regearing from 4.56 to 4.88 is not worth the time and cost.
Regearing to 5.13 would require a front axle swap.
What Jeeps are intended to be is irrelevant. We modify them as we see fit.
Would you tell someone who is asking about swapping out their stock street tires to go buy a 4 wheeler that already has aggressive tires on it?
Wheelin98TJ is offline
post #6 of 106 Old 12-24-2007, 11:04 AM
hoseclamp
hoseclamp's Avatar
I considered a motor swap,kept it stealth with a stroker in case emissions or registration play a part one day.
I'd look for a alum block GM 6.0L light duty truck motor from a wrecker, cheap and plentiful. With headers, intake, exhaust, 340 flywheel and over 400lbs torque would be reasonable, and thanks to advance adapters it will bolt in with some of their parts list.
One day I'll do an auto tranny and a big block, a Brute kit, but not yet. Can't do everything at once..........
'04 Rube
JEEPS ARE NOT CARS, STOP CALLING YOUR JEEP A CAR!!!!!!!!
hoseclamp is offline
post #7 of 106 Old 12-24-2007, 11:37 AM
Jeeples
Jeeples's Avatar
You're biggest issue with going with the 4.6 V-8 is the width of the motor. With DOHC's that sucker has a wide and large cylinder head assembly, which might not clear the inner fender's of your Jeep.
Also, you are wanting more power, and let's face it, Ford has never really been able to get any decent numbers out of the 4.6 unless they've put a blower on it. Hell, to this day, even the 4.6 in the new Mustang puts down less power to the wheels then the first iteration of the GM LS1, which is damn near 10 years old now.
If you want a Ford motor, go with the 302, or better yet, yank a 351 Windsor out of a Fullsize Bronco (5.8 V-8) and toss that in. They respond very well to modifications and are the same size dimensionally as the 302, but give you more of the low end grunt you want off road.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #8 of 106 Old 12-24-2007, 12:03 PM
BlueFlame
BlueFlame's Avatar
Originally Posted by Jeeples
You're biggest issue with going with the 4.6 V-8 is the width of the motor. With DOHC's that sucker has a wide and large cylinder head assembly, which might not clear the inner fender's of your Jeep..
It looks close but it should fit.
The overall width of my 06 Mustang engine bay between the shock towers is 35", but the engine doesn't even fill it. The two tabs in the picture are 30" apart, and the 4.6 is a couple inches less than that. The width of my TJ engine bay is 30". Snug fit but should be doable. Headers is another story.
I personally would do a small block Chevy. If budget allows, check out the ZZ383 - put fuel injection on it and it would be an awesome jeep motor! Best bang for the buck crate motor would be the RamJet 350.
BlueFlame is offline
post #9 of 106 Old 12-24-2007, 04:46 PM
slo9fo5oh
Coming from a mustang builder, I would put a small block FORD in any day. As a matter of fact in the future, I will. Naturally it will be a stroker. 331+ of good ole push rod power. The SOHC 4.6's are kinda wide but not as wide as the 3 valve in the pic above. You can buy an intake to carb the OHC motor, I beleive Edelbrok carries it now. But as mentioned above, the "stock" 302 didnt have alot of HP, but it did pretty decent on the trq. but a new H/C/I combo will net you over 300 easy on a stock bottom end.
slo9fo5oh is offline
post #10 of 106 Old 12-24-2007, 04:55 PM
Lawdodge
Lawdodge's Avatar
Just throwing in my two cents here. Have you looked into a 5.7L Hemi swap? There are a few guys around here that have done it. The motor only weighs 55 pounds more than the 4.0L so you don't need to do anything to your front end to support it. I know of a few shops that sell pre-fab exhaust and radiators for the swap. I found a few Hemi's on Ebay with the 5 speed auto trans and full wiring for around 2500 or so. I don't remember the magazine that did the story, but one of the fourwheeler mags did the Hemi swap in the "Teal-J" jeep. They have a 5 or so page write up on it and photos of the swap. You can even send your factory under the hood wiring in and have it "rebuilt" to plug right in to the new motor with factory conections.
Most of the people that I know that have done the swap, swear by it.
Here is the link to the Fourwheeler write up on the Hemi TJ.
http://www.fourwheeler.com/projectbu...wap/index.html
Mine - 2004 Unlimited Red 5.7L HEMI, NV241 4:1, RE 5.5" Long Arm, 35's on Champion Beadlocks, MetalCloak fenders and front bumper, Hanson rear bumper, 4.88's, ARB's, Alloy 33 spline D44 shafts, HP44 hybrid front w/ WJ outers, D44 rear ... and to much more .
RED JEEP CLUB #436
Lawdodge is offline
post #11 of 106 Old 12-24-2007, 05:13 PM
slo9fo5oh
[QUOTE[/URL]
[/QUOTE]
That just looks like it should have been a factory option, imagine that in a Rubi!!!!
post #12 of 106 Old 12-24-2007, 05:36 PM Thread Starter
spiderman637
Wow! That's a lot of input for less than a day's time since I posted. Thanks everyone for your advice and here's what I'm thinking. First off, I'd love to do the Hemi swap and I read the article on Teal-J, but I think that's a little out of my price range. Second and I know this will get a lot of hate, but I just can't stomach the idea of a SBC in any of my vehicles. I have a '95 4.6L in a Thunderbird (I also have PI heads and Intake for it to bump it up to about 260hp) so I guess measuring for the engine bays would be a good idea. I thought about a 5.4L or also a 5.8L, but the 5.8L at least, is about 100lbs heavier and I can get the same power out of a 347 stroker. Another advantage of the 4.6L, if it will fit is that the explorers have aluminum blocks, which would make them lighter still. As far as regearing again, I really don't want to go any taller because my first gear is already close to a granny gear and my rpms are pretty high on the hwy. Right now it's looking like the 302 would be the way to go. Cheap easy power, efi and according to what you guys are telling me, it'll fit better, too. I'll keep everybody posted on any developments and thanks again for your input!
post #13 of 106 Old 12-24-2007, 05:38 PM
nitecop
If you really go the 5.0 route make sure you get a HO stang version. THe regular 5.0 with single exh was only rated @ 155-160HP and 245-260TQ.
They are great little big bvore engines that will fit where other V8s only wish they could.
The 4.6 engines have a power band that is at a higher rpm and not so great for 4x4s combine that with the fact they are MUCH wider than 5.0 V8.
If mine I go with a big vlave, different cam, and a stroker crank for the same power as a 5.0 with the reliability of a inline Six.
Jim
USW, OAPSE Union member
99 TJ Sahara 4.0 5-Sp FUV + farm worker
Project f-Xj F150/XJ Ford eXtreme jeep combo
06 6 Speed LJ my daily driver.
Colorado Jeep club memeber #505
nitecop is offline
post #14 of 106 Old 12-24-2007, 05:48 PM
BlueFlame
BlueFlame's Avatar
Not a fan of the Hemi (other than it's cool to say I got a Hemi in there) because it makes poor low end power, and is the biggest gas hog on the road today.
They have their uses though...
post #15 of 106 Old 12-24-2007, 06:47 PM
Zice
Zice's Avatar
what do the 4.6 strokers sound like? Like a 4.0?
I would absolutely get a rise in my pants if I could make my jeep sound like a 4.6 or 5.0 stang without dropping one of those motors in
Life Is Good.
Zice is offline
Ford 8.8 swap XJesterX TJ Wrangler Technical Forum 30 12-28-2009 09:46 PM
Ford 8.8 Swap ? DaSham58 YJ Wrangler Technical Forum 8 05-06-2007 08:39 PM
Ford V8 Swap shane_atv TJ Wrangler Technical Forum 5 12-08-2006 11:50 AM
Ford V8 Swap shane_atv TJ Wrangler Technical Forum 7 11-30-2006 05:29 AM
Ford 351 swap into 95 YJ iamthedemoman YJ Wrangler Technical Forum 1 05-08-2006 04:31 PM
