Fog lights WON'T turn off... Now Highbeams wont come on!!!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Fog lights WON'T turn off... Now Highbeams wont come on!!!!
ANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete The Jeep Forum Discount is ON!The Original 3/8" Ruffstuff Diff Cover!
Unread 01-06-2012, 11:54 PM   #1
chris4jeep
So i found a write up on here.(not sure by who) but it was detailed on how to fix a issue with the fog lights not turning off. well i followed the procedure and it worked for the fog lights.
NOW, when i put it all back together the highbeams stay on and wont turn off... I have managed to somehow get it to where they are off but wont come on. wondering if i should try to fix this or just go buy a whole new control cluster?
30A&MUD4ME
chris4jeep is offline   Reply With Quote Quick reply to this message
Unread 01-07-2012, 07:23 AM   #2
greene69
greene69's Avatar
It may be the turn signal / light switch unit on the steering column. Pull the cover off and check to see if the plug has gotten hot.
It's better to be dead and cool than alive and uncool.
Nothing like a permanent reminder of a temporary feeling. I have a few.
4.0 auto, 8.8 rear with detroit locker, 4.10's and 33x 12.50's
greene69 is offline   Reply With Quote Quick reply to this message
Unread 01-07-2012, 09:54 AM   #3
chris4jeep
i have already done that idk if i broke something when pulling it apart the turn singnal to fix the fog lights or if i didnt put back together right. I have looked at the diagram and pictures i took and it looks like i put it together just fine.
30A&MUD4ME
Unread 01-07-2012, 10:59 AM   #4
1999TJRED85000
Is the ground for the lights hooked up to where the + should be on the relay or switch? This might cause the problem. It would turn the fog lights on, and defeat the high beams.
F U
1999TJRED85000 is offline   Reply With Quote Quick reply to this message
Unread 01-07-2012, 02:01 PM   #5
Necko2529
Necko2529's Avatar
Your multifunction switch, the unit that operates lights and fog lamps, is probably fried, the wires inside get got and short out. At least that's my experience with those. More than twice already on a same Jeep.
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline   Reply With Quote Quick reply to this message
Unread 01-07-2012, 04:37 PM   #6
chris4jeep
Should i buy a whole new switch cluster
30A&MUD4ME
Unread 01-11-2012, 04:45 AM   #7
chris4jeep
Where is a good place to buy the switch cluster????? I want to buy a whole one. not just one side.
30A&MUD4ME
Unread 01-11-2012, 06:49 AM   #8
lloydsmale
buy each one seperate and its easy to just bolt them on.
my off road toys are a 2000 yellow 4 cyl with a 2 inch lift and 31 bfgs. A 2006 silverado club cab 4x4 with a 310 hp, K&N intake, borla exaust, computer reprogramed by westers, 285/17 bfg mud terrains. A yamaha grizzly, A yamaha raptor and a yamaha warrior, honda big red, 2009 polaris rzr
lloydsmale is offline   Reply With Quote Quick reply to this message
Unread 01-21-2013, 03:07 PM   #9
Staggito
look on amazon. parts stores are cool and all but you can save some precious $ buying online
Bad *** JEEP!
Staggito is offline   Reply With Quote Quick reply to this message
control arm , fog lamp switch , gauge cluster , high beam
