Fog lights WON'T turn off... Now Highbeams wont come on!!!! - JeepForum.com
post #1 of 9 Old 01-06-2012, 11:54 PM Thread Starter
chris4jeep
So i found a write up on here.(not sure by who) but it was detailed on how to fix a issue with the fog lights not turning off. well i followed the procedure and it worked for the fog lights.
NOW, when i put it all back together the highbeams stay on and wont turn off... I have managed to somehow get it to where they are off but wont come on. wondering if i should try to fix this or just go buy a whole new control cluster?
30A&MUD4ME
chris4jeep is offline
post #2 of 9 Old 01-07-2012, 07:23 AM
greene69
It may be the turn signal / light switch unit on the steering column. Pull the cover off and check to see if the plug has gotten hot.
It's better to be dead and cool than alive and uncool.
Nothing like a permanent reminder of a temporary feeling. I have a few.
4.0 auto, 8.8 rear with detroit locker, 4.10's and 33x 12.50's
greene69 is offline
post #3 of 9 Old 01-07-2012, 09:54 AM Thread Starter
chris4jeep
i have already done that idk if i broke something when pulling it apart the turn singnal to fix the fog lights or if i didnt put back together right. I have looked at the diagram and pictures i took and it looks like i put it together just fine.
30A&MUD4ME
post #4 of 9 Old 01-07-2012, 10:59 AM
1999TJRED85000
Is the ground for the lights hooked up to where the + should be on the relay or switch? This might cause the problem. It would turn the fog lights on, and defeat the high beams.
F U
1999TJRED85000 is offline
post #5 of 9 Old 01-07-2012, 02:01 PM
Necko2529
Necko2529's Avatar
Your multifunction switch, the unit that operates lights and fog lamps, is probably fried, the wires inside get got and short out. At least that's my experience with those. More than twice already on a same Jeep.
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #6 of 9 Old 01-07-2012, 04:37 PM Thread Starter
chris4jeep
Should i buy a whole new switch cluster
30A&MUD4ME
post #7 of 9 Old 01-11-2012, 04:45 AM Thread Starter
chris4jeep
Where is a good place to buy the switch cluster????? I want to buy a whole one. not just one side.
30A&MUD4ME
post #8 of 9 Old 01-11-2012, 06:49 AM
lloydsmale
2015 JK Wrangler
buy each one seperate and its easy to just bolt them on.
2015willys 4 cyl tj 2017 silverado yamaha grizzly, Polaris rzr 04 z06 vette, 600/800 crossfire cat
lloydsmale is offline
post #9 of 9 Old 01-21-2013, 03:07 PM
Staggito
look on amazon. parts stores are cool and all but you can save some precious $ buying online
Bad *** JEEP!
Staggito is offline
control arm , fog lamp switch , gauge cluster , high beam
Highbeams wont turn off. Metatrox YJ Wrangler Technical Forum 14 05-27-2011 04:25 PM
interior lights wont turn off... jeepin-gheenoe TJ Wrangler Technical Forum 3 10-28-2010 10:28 PM
Inside lights turn off when highbeams are turned on... anyone else? Apollo12227 YJ Wrangler Technical Forum 11 09-30-2010 07:53 PM
stock fog lights wont turn on help!!!!!! 04wranglerX2 TJ Wrangler Technical Forum 12 01-11-2010 08:58 PM
Fog lights wont turn off. surfer TJ Wrangler Technical Forum 1 03-14-2007 11:48 AM
