Fog Lights on without switch on & won't turn off - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Fog Lights on without switch on & won't turn off
Poly Door Hinge BushingsStainless Steel Door Hinge PinsNew Knuckles Skid Plate at JeepHut
Unread 12-20-2010, 07:25 PM   #31
joe440
The fog/driving light problem is a common problem with Chrysler products. The same Multi Function Switch (MFS) is used on several Chrysler products including my 04 SRT4 (turbo neon). I tried changing relays, looking for bad wiring, I bought a new MFS and that fixed the problem.
joe440 is offline   Reply With Quote
Unread 12-20-2010, 08:25 PM   #32
blkfreedom03
The MFS I got from Autozone came in a Duralast box but was very Chrysler down to the latest part number and the Pentastar logo on the switch. They were the only place to even have a switch in stock for fogs. Everywhere else was useless.
Present: '03 Wrangler Freedom Ed. 4.0/NV3550 - Dynomax cat-back, 30" BFG ATs, black steelies..
Past: '94 ZJ Laredo 5.2/46RH
Black Jeep Society
blkfreedom03 is offline   Reply With Quote
Unread 12-21-2010, 02:45 PM   #33
BlueFlame
The vast majority of parts such as this come from the same factory the OEM got it from (the automakers make very few of their own parts.)
BlueFlame is offline   Reply With Quote
Unread 12-21-2010, 05:15 PM   #34
F9K9
SEMPER FI
F9K9's Avatar
Originally Posted by jr03 View Post
When my fog lights started turning on by themselves I sprayed the switch with electronic contact cleaner. Worked switch on/off multiple times and after couple days problem has never come back. That was a few months ago if you've just started having problem this might work, if switch is already damaged then it'll need replaced
Where exactly did your spray the cleaner? You definitely might be on to something here.
For those who have fought for it, FREEDOM has a taste that the protected will never know."
'03 Rubicon w/a few changes.
F9K9 is offline   Reply With Quote
Unread 12-21-2010, 05:49 PM   #35
jr03
I sprayed up into steering column where turn signal lever comes out. If I remember right you can look up in there and see part of the switch and part of it that moves with push pull of fog light button. I used a electronic contact cleaner that had some kind of protective anti oxidation lube in it. I had nothing to lose trying it and so far it's worked for me
jr03 is offline   Reply With Quote
Unread 12-23-2010, 03:02 PM   #36
thejafe
Well, my new switch from autozone came in and it looks pretty identical to the what's on the Jeep now. While installing the new switch my FSM indicates that the negative battery terminal should be disconnected and isolated to prevent "ACCIDENTAL AIR- BAG DEPLOYMENT AND POSSIBLE PERSONAL INJURY." I wonder how necessary that actually is... but better safe than sorry I guess.
Will try and install the new switch tomorrow and I'll follow up with some pics.
thejafe is offline   Reply With Quote
Unread 12-23-2010, 03:23 PM   #37
Cmdrfluff
If you cant get some good pics of the wiring to the switch. I am looking to identify the "orange and white" wire that was mentioned above.
Cmdrfluff is offline   Reply With Quote
Unread 12-23-2010, 06:25 PM   #38
BlueFlame
Originally Posted by thejafe View Post
FSM indicates that the negative battery terminal should be disconnected and isolated to prevent "ACCIDENTAL AIR- BAG DEPLOYMENT AND POSSIBLE PERSONAL INJURY." I wonder how necessary that actually is... but better safe than sorry I guess..
Actually, that particular warning is No Joke. It's very necessary. Airbags can be deployed quite easily by messing with the associated harnesses, and it
can
kill
you.
Unread 12-23-2010, 07:09 PM   #39
thejafe
Originally Posted by BlueFlame View Post
and it
can
kill
you.
Well if I can help it I'd rather not have the airbag take my head off. Like I said... better safe than sorry
Unread 12-24-2010, 08:47 PM   #40
thejafe
Ok, created a new thread with pics from my install here :
http://www.jeepforum.com/forum/f9/sw...-pics-1145043/
Unread 03-16-2011, 03:05 PM   #41
sumday
having the same problem and pulled the fuse for now...autozone sells the switch for $120 but are out of stock
sumday is offline   Reply With Quote
Unread 03-16-2011, 03:17 PM   #42
spdcat01TJ
http://www.autozone.com/
Lists the multifunction switch with fog lamps for $51.99. Says it ship within 2 days.
If guns kill people, then pencils misspell words, cars make people drive drunk, and spoons made Rosie O' Donnell fat!
NRA Member
'01 TJ Sahara, 3" BB front, 2.25" BB rear, 1.25 JKS BL, 1" MML, Skyjacker Hydro shocks,33/12.50x15 BFG TA/KO All Terrains homemade disco's, Hi-Lift, CB, GPS
spdcat01TJ is offline   Reply With Quote
Unread 05-25-2011, 03:15 PM   #43
willysrevenge
Originally Posted by vosevichs View Post
1. I bought a fuse tap from Napa. The taps from autozone were only rated at 10 amps. I tapped into theload side of the Acc/ cig liter fuse (20 amp).
2. Pull the fuse and use a test lamp or meter. One terminal will have 12v the other terminal nothing. Put the tap into the terminal with no voltage with the fuse. Your circuit will be protected by that fuse now.
3. Then I ran a 16 gage wire (rated at 22amps, 18 gage wire is only rated for 15 amps) to a 25 amp toggle switch, then to the white with orange trace wire.
4. My switch has a indicator lite on it so i had to run a ground wire from the switch to a screw in the dash beside the steering wheel.
5. I mounted the switch in the dash pioece thats right around the steering collumn.
Buy any style of a 20amp switch that you prefer. The Stock style is nice, but it's mounted down by the shifter. I didn't care for that. I got one with a green indicator because the dash indicator was green. Mounted it in the dash panel right by the multi-switch.
I have since pulled the fog lamp relay and installed a jumper wire so they'll stay on with the hi-beams.
is this write up valid for the 05 as well...i think they may have made some changes between 04 and 05
willysrevenge is offline   Reply With Quote
Unread 06-07-2011, 08:49 PM   #44
BrianBFD
Here, hold my beer...
BrianBFD's Avatar
The multi switch is around 50.00 at autozone,advanced, and usually has to be ordered. I call the Jeep dealer, they were 98.00 and on back order. A 1,000 orders were in front of me.
To bypass the multi switch. The fog lights are the white w/ orange trace wire on the multi switch.
When I switch on the fog lites the dash indicator lites up, and when you hit the hi beams they go out. That fog lamp relay only shuts the lites off when you hit the hi beams. The fog lites run through the normally closed set of contacts in that relay. There is no other relay for the fog lites. So make sure you tap off of the load side of a 20amp fuse and use a 20amp or better switch.
I followed these instructions and the white with orange trace is to my parking/running lights, it also killed my dash lights. Now that I have this repaired and these lights working again any ideas on which wire is the correct one for my 05 Rubicon????
I could sure use a little help with this.
Originally Posted by No-Doors View Post
...I will be tied up the 13th and 14th...
Originally Posted by AKABOB View Post
I am aroused.
BrianBFD is offline   Reply With Quote
Unread 06-07-2011, 09:22 PM   #45
UnlimitedNJ
Here's some help, buy the switch and fix it right. Problem solved.
Why don't you go back to your home on whore island?!
UnlimitedNJ is offline   Reply With Quote
