Fog Light Wiring Diagram - JeepForum.com
post #1 of 7 Old 12-17-2008, 06:46 PM Thread Starter
rebelkid17
I just orderd some 130w kc slimlites from quadratec and am going to wire it to a seperate switch all together.
Could somebody show me a wiring diagram for the lights and what kind of relay do i need to use.
thanks
1997 Jeep Wrangler TJ 4in. rough country lift, 33in. BFG All-Terrains, Unidean CB radio with PA, Sony head unit and speakers all around pushing 200w, Warn rock crawler bumper front and rear with tire carrier, 2 KC 130w driving lights.
rebelkid17 is offline
post #2 of 7 Old 12-18-2008, 03:02 PM
BlueFlame
BlueFlame's Avatar
They should come with a harness and instructions.
BlueFlame is offline
post #3 of 7 Old 12-18-2008, 03:04 PM
keithrj
I've got the same lights. I just ran direct power from an in-cab switch I installed into the lower portion of the driver's side dash. They've worked beautifully for over 2yrs now.
keithrj is offline
post #4 of 7 Old 12-18-2008, 03:14 PM
badassjeep04
its pretty simple stuff, make sure you use an inline fuse though... ask me how i know
badassjeep04 is offline
post #5 of 7 Old 12-18-2008, 03:26 PM
keithrj
+1 I forgot to mention that.
Fuze blocks are great, too. And hide behind dash easily enough.
2006 Jeep Wrangler Rubicon Unlimited
Safari Snorkel w/ K&N Airfilter, Centerforce Dual Friction Clutch, NGK Iridium Plugs, 5 130W KC Slimlites
2 1970s Sansui Concert Speakers powered by a 300W amp running off a 4GB Zen MP3 player.
keithrj is offline
post #6 of 7 Old 12-18-2008, 03:44 PM
badassjeep04
it will save you an insurance claim, thats for sure..
post #7 of 7 Old 12-18-2008, 05:06 PM
Jeepsr4me19
1976 CJ5
I like using relays. One small wire to a in cab switch. then a heavy gauge wire from a power source though the relay then on to the lights.
Jeepsr4me19 is offline
Brake Light Wiring Diagram wooterjeep TJ Wrangler Technical Forum 3 04-22-2011 01:56 AM
94YJ Rear Brake Light Wiring Diagram PaulGarch94YJ YJ Wrangler Technical Forum 2 01-14-2009 09:12 AM
need wiring diagram majkowskid TJ Wrangler Technical Forum 4 07-18-2008 08:04 AM
Parking Light Wiring Diagram nckm126 TJ Wrangler Technical Forum 1 12-25-2006 01:52 AM
Need Wiring Diagram Krisfyr TJ Wrangler Technical Forum 3 06-06-2006 01:03 PM
