Flush Mount Taillights - JeepForum.com
post #1 of 29 Old 02-20-2007, 10:47 PM Thread Starter
RLD831
RLD831's Avatar
Today I flush mounted my tailights, I'll post pics if anyone wants em, but my question is how have others fabbed up license plate lights. I was thinking maybe LEDs in the plastic holder for the plate or something like that. As far as the lights go, I love them flushed to the tub.
RLD831 is offline
post #2 of 29 Old 02-20-2007, 10:55 PM
GlassCurtain
This sounds like a cool mod. pics please!!
GlassCurtain is offline
post #3 of 29 Old 02-21-2007, 10:47 AM
BlueFlame
BlueFlame's Avatar
An option might be those license plate bolts that have leds in them. (Street rod stuff.)
Did you add side markers?
BlueFlame is offline
post #4 of 29 Old 02-21-2007, 10:59 AM
R. Potts
I have a set of street glow light bolts that I'm going to hopefully install soon.
Let's see the pictures!
08 JK Rubicon Unlimited
R. Potts is offline
post #5 of 29 Old 02-21-2007, 11:39 AM
keoki04
keoki04's Avatar
Let's see some pics!!!!
Current Ride:
97 TJ Sport 5spd
Check profile to see the mods!
Other mods to come...
Clicky
Clicky
keoki04 is offline
post #6 of 29 Old 02-21-2007, 11:55 AM
None
The people that make the Lite Dots has some sort of LED setup for your plate that seems to be better than the lite n bolts.
ive seen them mounted to the spare and that looks really cool! you get to ditch that plastic frame for the plate!
Post pics! Im about to do this (if my order ever gets shipped.)
Chris
None is offline
post #7 of 29 Old 02-21-2007, 12:25 PM Thread Starter
RLD831
RLD831's Avatar
I think I'm going to go with one of these. http://northridge4x4.com/proddetail....PLATELITE-PLUG I'll try to get pics tonight, I'm at school now. If not I'll have em early tomorrow.
RLD831 is offline
post #8 of 29 Old 02-21-2007, 12:50 PM
None
MAN thats awesome! I didnt know it was a third brake light also.
do you have to buy the mounting bracket separate? Also does this work with the stock setup??? It looks like it plugs into the hole in the spare, but what does that plug into?
If I were to get this, could I ditch the stock 3rd brake light?
None is offline
post #9 of 29 Old 02-21-2007, 06:24 PM Thread Starter
RLD831
RLD831's Avatar
It is the mounting bracket. The long piece at the bottom bolts into the two top licencse plate screws. I plan on wiring it custom to my running lights on the driver side to make it easy. I'm not too sure about using it as a third brake light, because I plan on leaving the plate in the stock location, so I won't be wiring it as a third brake light. Mine will be bolted to the plastic holder that comes with the Jeep.
RLD831 is offline
post #10 of 29 Old 02-21-2007, 09:45 PM
44 NSB
NSB Florida Jeep
44 NSB's Avatar
Couple photos of my flush mount LED's. I put in a single back-up light, removed my third brake light and connected it through it's wiring. You'r right about the Boltz lites they give off minimal light and look kind of cheesy when lit.
http://usera.imagecave.com/GMeyer/BackupLightLEDsBoltz/
1997 Red TJ
5 speed w/ NP 231, Nth 4.5" lift, AntiRocks front and rear, skids (tummy tucker, front dif, oil pan, GenRite fuel tank skid, RockJock D-60 4.88, Flex-a-lite fan, Flow Cooler pump, Rhino lined tub, American Eagle Alloys, SS LTB's 34" x 10.5 w/Staun beadlocks, Tuffy console, MileMarker Hydra 12000
44 NSB is offline
post #11 of 29 Old 02-21-2007, 11:49 PM
ChiliPalmer
This is Ames Mister...
ChiliPalmer's Avatar
If you look close you'll see that Bluesman (the Red Jeep) has removed his plastic plate holder and just bent the plate around the corner of the Jeep. Dogman has recently done this and now it's growing on me so I'll probably do it also! Either way, it's a good alternative to alternative mounting (pun intended). You could then get the LED bracket menioned earlier for this setup and I bet it would look good! I'm not sure if Bluesman did this (dogman did) but I recommended to put a small strip of foam tape behind the plate around the corner to keep it from rubbing the paint off right there when the wind blows it around while driving.
Click the pic for a larger view...
If you want to help the sport of offroading visit the
Forum!
Oh man Chili. I feel like a recovering addict that just had a bag of blow, a bottle of Jameson, and a sack dropped in his lap. You screwed me man!
ChiliPalmer is offline
post #12 of 29 Old 02-22-2007, 11:13 AM Thread Starter
RLD831
RLD831's Avatar
A little late, but here are the pics of my setup. I'm still waiting for the licensce plate light. Not sure if I like it better with or without the tire because of the flush lights. Being that it's a Jeep I don't have to decide, I can do either or both.
RLD831 is offline
post #13 of 29 Old 02-22-2007, 11:25 AM
pendleton
AEV has a light for your plate, too.
https://secure.aev-conversions.com/s..._Code=parts-tj
pendleton is offline
post #14 of 29 Old 02-27-2007, 10:57 AM
None
can I get a write up??
None is offline
post #15 of 29 Old 03-09-2007, 01:00 PM
Mondo
Mondo's Avatar
I HAVE ROUNDS. i NEED TO SEAL them i think
[/COLOR]Closest thing to a mid-life crisis
Randy Neill
Mondo is offline
flush mount taillights johnroot01 YJ Wrangler Technical Forum 0 09-14-2009 07:50 AM
Flush mount taillights jdietz92 YJ Wrangler Technical Forum 6 09-24-2008 05:31 PM
side markers w/ flush mount taillights crosscheck17 YJ Wrangler Technical Forum 25 06-12-2006 08:17 AM
Flush Mount Taillights 4cylYJ YJ Wrangler Technical Forum 21 08-20-2005 12:40 AM
Flush Taillights Tenn.Red TJ Wrangler Technical Forum 1 02-07-2004 09:53 PM
