Fluids...what are you all running?
| Great deals on Mickey Thompson Tires @ Jeephut.com | RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com | Poison Spyder Brawler Rockers! |
#1 | |
I am looking to make a day of changing all the fluids in the jeep (coolant, front and rear diff oil, Engine oil, trans Fluid, etc.) What are you all using? I am not sure when or if any of the front or rear diff or trans fluid and coolant have ever been changed in my jeep, it has low miles at 40k and rarely gets driven but I just wanted a good weekend day project.
I am currently using the Mobil 1 for oil changes, this is what I have been running since I owned the jeep at 36K or for about a year. I am interested to know what is being used and what effects have been noticed since the switch. Thanks, Kevin
#2 |
Wahoowa
Engine oil: Mobil 1
Tranny: Mopar Nv3550 fluid Transfer Case: Valvoline full synthetic ATF 4 Diffs: Valvoline 80w90 Coolant: Prestone Haven't noticed anything really.
White 01 TJ Sport 4.0 NV3550 |
#3 |
Northman
At present
engine...Castrol 5wt.-30 tranny... stock ( I have 8k miles) diffs....Royal Purple 75-135 coolant.. Prestone Next change out will be all Schaeffer products.
Uncle Willy, The InnKeeper #3 06 Rubicon locked and loaded.... |
#4 |
I use
Engine: valvoline synthetic Diffs: Royal Purple For the transmission and Transfer case I am going to get the fluids from the dealer and do those changes this weekend. |
#5 |
Engine: Mobile Clean 5000 10w30
Tranny: Mopar ATF+4 xfer case: Mopar ATF+4
2005 LJ- Mostly stock/ DD 2000 TJ- Slowly Rebuilding 1976 CJ7- 304/TH400 | 3" suspension | Warn 9.5ti | |
#6 |
Brake fluid: DOT 4
Gear lube: GL5 Engine oil: 10W-30 Coolant: green Power steering: power steering fluid AX-15 transmission: GL4 NP231 TC: ATF-4 Battery: distilled water Washer fluid: blue Blinker fluid: none |
#7 |
Have you had any problems with your blinkers?
2012 JK Sport 3.6L 5 Speed Auto |
#8 |
#9 |
thanks for the legit responses, no thanks for the bs response... I was wondering if everyone went with the factory recommended trans and transfercase fluid, thats what i have always been told to do. Ill be busy this weekend.
#10 |
pennzoil sycromesh for the manual trans. whatever they recommend for the TC....+3 or something...don't remember.
#11 |
Haulin' Groceries
Engine Castrol GTX Synthetic 10w-30
Coolant Honestly i just use the 50/50 mix that autozone has on sale Diffs (Rubicon) Mobil 1 75w-130 Edit: Rear diff with 4 oz of limited slip addative
Black wont get you back, but Chrome WILL get you home. 1990 XJ Part Outhttp://www.jeepforum.com/forum/f149/90-xj-part-out-2-door-ax15-1301969/ 1978 CJ5Being built 1996 4 Door XJ My DD - Now Parting out |
#12 | |
I must apologize, I did list one fake fluid just for a little fun.... hope you didn't get upset. |
#13 |
#14 |
you just seemed to give a mocking answer i was just looking for ideas on what to use, opinions on fluids are like that of everything, they are opinions and no one will ever completly agree. I wasnt looking start an argument, just more for guidence on what is good to use, i heard as far as replacing trans and transfercase fluids as well as diff fluids to use the factory suggested stuff...who knows ill just go with my original plan, royal purple in the diffs and mobil in the engine factory spec for trans and transfer case...etc.
#15 |
![]() Still want know. BTW Changed my blinker fluid. Now they work like a champ,but my muffler bearing is squeaking.
A person once told me i was driving beyond the capabilities of my vehicle - obviously they never seen the capabilities of a jeep! This space saved for info: |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
