#1 | |
Fluid Capacity
Hey, was hoping someone could help me with some easy questions that I couldn't find in the owner's manual.
1) how much fluid goes into a Dana 44 and a Dana 35 2) How much tranny fluid into the 6spd manual and what does everyone recommend since I'm towing a trailer most of the year It's for a 2005 Unlimited THANKS!
2005 Unlimited 6spd. "I don't mind a little body damage, it's paying for parts that bothers me..." "If an ATV can go in there, so can my Jeep." |
#2 |
Kind of confused why you want to know about a D44 and D35 but here is a write up on how to change your diff fluid with a D30 and D44. Have Fun!!!
http://4x4xplor.com/diff-service.html
'97 Tj Sport, 4.6L Stroker, 5-Speed, 4-in suspension lift, 35" TrXus M/t's, Dana30/Ford 8.8 w/ Aussie Locker, Teraflex ExtremeShort SYE, custom front and rear bumpers, Flowmaster Off-road Series, and a bunch of other goodies........MoPar or No-Car!!! |
#3 | |
“This isn’t the Old West, because the New West has never arrived. It’s just the West, like Wyatt Earp died yesterday.” ─ Michael Martin Murphey talking about the Eastern Sierra during an interview in 1996. |
#4 |
The D30 (I assume you made a typo) should hold 2.5 pints and the 44 holds 4 pints, however when filling them up you should just fill them up until the fluid starts coming out of the drain hole. When it starts coming out you have the correct amount.
It's still good to know the amount they will hold so you can make sure you have enough, my rule of thumb is with a D30 and either D44 or D35 in the rear 1 gallon will do both diffs. Don't know anything about the 6spd.. |
#5 |
Thanks for the info on the diffs. I meant to say Dana 30 so thanks for being on top of things for me. I know how to change them. Anyone out there have any info on the 6spd and a recommendation on what to put in because I remember there being a discrepancy about snychromesh and redline, etc in the 5spd.
#6 |
Lifted/Locked/Rolled/Sunk
Straight from DCSNet:
SPECIFICATIONS - FLUID CAPACITIES DESCRIPTION SPECIFICATION FUEL TANK 19 U.S. Gallons (71.9 Liters)**** ENGINE OIL Engine Oil - with Filter - 2.4L 4.75 L (5.0 qts.) Engine Oil - with Filter - 4.0L 5.7 L (6.0 qts.) ENGINE COOLANT Cooling System - 2.4 L 8.5 L (9.0 qts.) Cooling System - 4.0 L 9.9 L (10.5 qts.) POWER STEERING SYSTEM Power steering fluid capacities are dependent on engine/chassis options as well as steering gear/cooler options. Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an auxiliary cooler, these capacities may vary. Refer to 19, Steering for proper fill and bleed procedures. AUTOMATIC TRANSMISSION Service Fill - 42RLE 3.8 L (8.0 pts) Overhaul Fill - 42RLE 8.3 L (17.6 pts.)♦ ♦Dry fill capacity. Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an auxiliary cooler, these figures may vary. (Refer to 21 - TRANSMISSION/AUTOMATIC - 42RLE/FLUID - STANDARD PROCEDURE) TRANSFER CASE NV231 1.0 L (2.2 pts.) NV241 2.0 L (4.2 pts.) MANUAL TRANSMISSION NSG 370 Approximate dry fill or fill to bottom edge of the fill plug hole. 1.5 L (3.17 pts.) FRONT AXLE ± .03 L (1 oz.) 181 FBI (Model 30) 1.2 L (2.5 pts.) 216 RBI (Model 44) 1.89 L (4.0 pts.) REAR AXLE ± .03 L (1 oz.) 194 RBI (Model 35) 1.66 L (3.5 pts.)* 216 RBI (Model 44) 1.89 L (4.0 pts.)* * With Trac-lok add 118 ml (4.0 oz.) of Limited Slip Additive. ****Nominal refill capacities are shown. A variation may be observed from vehicle to vehicle due to manufacturing tolerance and refill procedure.
I need a 35" tire for spare. PM me if you have something. My Hummer Hole video SIRA 4x4 club I'll be Savvy someday!
#7 |
For the NSG370 6-speed manual trans... straight fron DCSNet:
MANUAL TRANSMISSION NOTE: DaimlerChrysler recommends using Mopar® lubricants or lubricants of equal quality. NSG370 - Mopar® Manual Transmission Lubricant MS-9224 The discrepancy was with the old AX-5 or AX-15 trans... According to Stu: http://www.stu-offroad.com/misc/maint.htm
#8 |
First, I love you for all the information
Second, what does "NSG370 - Mopar® Manual Transmission Lubricant MS-9224" convert to in terms of gear oil or doesn't it? If I were to go into the store to buy fluid, what should I be looking for other than that it meets the above Mopar spec? I want to put in something really good since I'm always hauling a trailer and want this transmission to last damn near forever. Looking for a recommendation and I know everyone loves to give their opinion on here ![]()
#9 |
6 spd
Transmission info reference "Straight from DCS net".
What is DCS net? |
#10 | |
its a wonder that no one here has given this info from within this site. oh wait. someone did.
http://www.jeepforum.com/wiki/index.php/Fluids_-_Lubricants searching will net you wondrous results.
Currently seeking employment in the automotive field or fabrication. PM me for resume and list of qualifications. |
#11 |
Dcs?
I have all the info I need about fluid types and level.
The search is what got me to this thread since it doesn't appear to be currently active. I was just curious about the term "DCS net", and what it is or means. That was my question. Thanks |
#12 |
Go to Jeep.com and download your owners manual.
#13 |
Jeepster83, your link lists the amount for an NFG, I mean, NSG 370, but not the type or what is equivalent. I read somwhere that Redline Oil MTL is a, better than original, substitute.
2005 Jeep TJ Rocky Mountain Edition |
#14 |
Actually, I should have said DealerConnect. It's one of the online dealer tools. I always mix it up with DCSnet from our other car line.
#15 | |
Wanna Go Along?
Visit my website SyntheticLubeStore.com Dealer # 1468345 or email me gabe@syntheticlubestore.com Go to Amsoil's Online Store Use the application guide to see what you need Request more information about Amsoil & a Free Catalog |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
