fluid capacities - JeepForum.com
post #1 of 8 Old 12-13-2006, 06:32 PM Thread Starter
bfr
bfr's Avatar
fluid capacities
how much atf+4 will I need for the 241 t-case, and how much gear oil for the front and rear differentials?
bfr is offline
post #2 of 8 Old 12-13-2006, 07:01 PM
SecondTJ
SecondTJ's Avatar
TJs have the 231 transfer case...
either way, they take about 1-1.25qts, so buy 2 qts and you'll have plenty.
The front diff will take 2 quarts.
and the rear depends, D35 or D44? Either way it will take just over 2 quarts, so buy 3 for it.
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #3 of 8 Old 12-14-2006, 08:16 AM Thread Starter
bfr
bfr's Avatar
Originally Posted by SecondTJ
TJs have the 231 transfer case....
Some do not
bfr is offline
post #4 of 8 Old 12-14-2006, 08:59 AM
TJBoomer
Stu Olson Linky... "Common Maintenance Information".
http://www.stu-offroad.com/misc/maint.htm
TJBoomer
TJBoomer is offline
post #5 of 8 Old 12-14-2006, 09:47 AM Thread Starter
bfr
bfr's Avatar
thank you!
bfr is offline
post #6 of 8 Old 12-14-2006, 11:01 AM
SecondTJ
SecondTJ's Avatar
Originally Posted by bfr
Some do not
with the exception of the Rubi, but only differnece is the 4:1 low range. otherwise all tjs have the 231,
SecondTJ is offline
post #7 of 8 Old 12-14-2006, 11:36 AM
92blazn
92blazn's Avatar
2010 JK Wrangler
I just put in as much as it will take AKA or till it pours back out the over flow hole and then screw the bolt back in.....easy way
2004 TJ (SOLD), 2010 4 Door 4x4 JK , 99 TJ , 99 WJ
Originally Posted by The Mean Fish
I'm not actually going for the wheeling, I just want to watch Ed drive his Jeep. :o
92blazn is offline
post #8 of 8 Old 12-14-2006, 12:44 PM
SecondTJ
SecondTJ's Avatar
yes thats how to fill it, but he needs to know how many to buy. if he buys 1 and it doesnt fill it up, its not like he can just go back out and get another, at least i wouldnt drive on it if the fluid was that low
SecondTJ is offline
TJ fluid capacities wyldejackyl TJ Wrangler Technical Forum 5 11-07-2012 10:56 AM
FAQ - Fluid Capacities Wheelin98TJ TJ Wrangler Technical Forum 1 01-11-2008 04:51 PM
FAQ - Fluid Capacities Wheelin98TJ TJ Wrangler Technical Forum 0 05-02-2007 08:07 PM
fluid capacities wraithyjeep YJ Wrangler Technical Forum 1 05-08-2006 04:05 PM
87 YJ fluid capacities Buzzard YJ Wrangler Technical Forum 3 12-09-2001 09:50 AM
