Flowmaster on TJ - JeepForum.com
post #1 of 11 Old 07-03-2010, 01:33 AM Thread Starter
SugarBear
1969 CJ5
Flowmaster on TJ
Ok, my dad gave me his Flowmaster, with a 4" input and output on it. Now, my thing is, I'm not sure what size pipe is stock on the muffler of a TJ. I think it is 2.5"? Is that correct? If so, where can I get an adapter to fit a 4" muffler to my pipe?
Thanks!
SugarBear is offline
post #2 of 11 Old 07-03-2010, 02:07 AM
TheBoogieman
Disturbed.
TheBoogieman's Avatar
2.25" and Advance auto or Autozone have adapters.It's better to get the right size muffler.
TheBoogieman is offline
post #3 of 11 Old 07-03-2010, 05:38 AM
Hemi08
I thought if you increase the exhaust pipe size too much, it decreases backpressure which in turn decreases horsepower..like the "fart can" on imports.
Sweet Home Alabama......All Summer Long-Kid Rock
Hemi08 is offline
post #4 of 11 Old 07-03-2010, 05:56 AM
Demp
ideally you want the right size muffler, otherwise there are resizing adapters that can be welded in. The one for the 4inch might sound a little hollow on a jeep since its made bigger for the increased exhaust flow.
Demp is offline
post #5 of 11 Old 07-03-2010, 05:57 AM
little_Jeep
X 2....... for several reasons including size, noise, and backpressure.
If you wheel this Jeep, you don't want a real loud muffler as after a couple hours on the trail, you and everyone else will hate it.
little_Jeep is offline
post #6 of 11 Old 07-03-2010, 07:10 AM
Dryseals
1980 CJ7
Not back pressure, scavenging. You never want back pressure, back pressure is like adding a plug. But you do want scavenging.
You want the exhaust pulse to leave the piping in a functional manner, to help do it's work. To do it's work it needs to maintain it's velocity. Think of the single pulse running down the piping, like a truck going down the highway. It creates a vacuum behind it just like a truck would. That vacuum helps the next pulse move down the piping. Since the pulse has mass, the amount of vacuum it creates is dependent on it's size. The pulse wants to expand, if it expands, it slows down, if it slows down you loose the vacuum effect.
HP is upper RPM, torque is lower RPM. A larger exhaust will normally give you more upper end HP but sacrafice lower RPM torque. So it's a balance between the two. What do you want, torque or HP and design from there. Either way, you never want back pressure, think velocity.
Dryseals is offline
post #7 of 11 Old 07-03-2010, 07:31 AM
highlander4x4
Any exhaust shop should be able to adjust the piping and weld it in, but I would recommend getting the correct size.
My Flowmaster isn't all that loud.
highlander4x4 is offline
post #8 of 11 Old 07-03-2010, 07:42 AM
little_Jeep
Neither is mine, but I don't think you can say that about all of them.
post #9 of 11 Old 07-03-2010, 07:43 AM
little_Jeep
Post a link to all this... I'm old. It's been called backpressure for as long as I can remember
post #10 of 11 Old 07-03-2010, 08:37 AM
Dryseals
1980 CJ7
Wish I could, I'm old also and the term back pressure was always misused. I found an automotive engineering book (1960s) at the public library many years ago. It discussed exhaust systems very in depth. Calculations on pulse mass, heat volume etc etc. Everything down to the proper size and length of the header to obtain maximum scavenging for cam cycle valve over lap etc etc.
It was good enough that I bought a version for my self, which flooded in hurricane Ike. I've been looking for another copy since.
I've read a ton of articles on line since then, most just skim over the real details.
Do a search for exhaust scavenging. Most of it makes sense once you understand what's happening in the exhaust cycle. Then the same gas laws are applied to the intake cycle. Intake runner length does the same thing. Close the intake valve on the intake charge and what happens, the intake pulse bounces back up the intake runner, as it gets further away it creates a vacuum behind it and then retreats back down the runner. It'll bounce back and forth a few times before the energy is displaced. But if you open the intake valve at the right time, you get a ram charge from the extra energy.
I know your old enough to remember Oldsmobiles quad 4, they used this intake principal to gain extra power. All this energy can be put to use in improving performance, just remember "heat" is the real energy in the exhaust.
Dryseals is offline
post #11 of 11 Old 12-16-2012, 09:35 AM
SKINUM
I've got a 2.5" muffler and my plan is to cut the stock pipe. Do I need 2.25 OD or ID for the reducer?
Edit***** Looks like it's 2.50 O.D. and 2.25 I.D. for the reducer.
SKINUM is offline
exhaust , muffler , flowmaster
Flowmaster? DRTYWHP TJ Wrangler Technical Forum 26 12-04-2007 07:52 PM
Flowmaster on a 2.5l Kalesinajeep YJ Wrangler Technical Forum 7 11-07-2007 02:21 PM
Help! Which Flowmaster 40?? jeepnmike TJ Wrangler Technical Forum 4 10-24-2007 08:16 PM
flowmaster 40 or 50? or8008 TJ Wrangler Technical Forum 15 06-07-2005 07:34 AM
Flowmaster 483Fitter YJ Wrangler Technical Forum 16 07-16-2004 07:37 PM
