Quantcast Floor Soaked after hard rain. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Floor Soaked after hard rain.
RUBICON EXPRESS Lift Kits and Accessories Available at BasSpartan Lockers FREE SHIPPING Excellent PricesFree Shipping on TIRES at KrawlOff-Road
Old 12-15-2008, 09:40 AM   #1
prjohnson
My 02 Wrangler has a soaked floor after a hard rain & I can't find where it's coming from.
I know it's water (Not the Heater Core)
I have a Hardtop, but it's not coming in from under the windows.
The Floor was so wet that I had to take the drain plugs out.
There's more water in the back floor (infront of the rear seates)
There's a lot of water on the front floors also.
All plugs are in & again....The sides below the windows aren't wet...
Anyone have a idea on where this water is coming from?
Thanks!
prjohnson is online now   Reply With Quote
Old 12-15-2008, 10:00 AM   #2
champelite210
There is a little square vent in front of your windshield. When water gets in this vent it drains through a tube out the bottom of you jeep. Over time it gets clogged and backs up into your jeep. Open your hood and look on the back firewall, It exits about even with the valve cover on the engine and hangs about 12" towards the ground. It's made of rubber and sorta looks like a bladder. just grab and squeeze it should open for the water drain.
1998 TJ, 4.0 HO, 5 speed, 3.5" RE Super Flex Adj SA lift, AA SYE, Currie steering, 4.88 Gears, 8.8 Rear with Eaton E-Locker, HP Dana 30 with Detroit locker and chromoly shafts, 36x12.5x15 TSL-SX, TNT Customs front 3.5 fenders, XRC rear crusher corners with 3.5 flare, A to Z rock sliders, PSC steering pump.
champelite210 is offline   Reply With Quote
Old 12-15-2008, 10:23 AM   #3
christrx450
Man this same thing has happened to me. I couldn't figure out where it was coming from so I back my jeep in on the driveway since the incline would allow more drainage and that helps but I will look into the rubber plug too.
christrx450 is offline   Reply With Quote
Old 12-15-2008, 11:58 AM   #4
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
When the drain in the hood cowl gets plugged,it also drains through the vent box located on the passenger side under the cowl.I siliconed mine and stopped the leak.
TheBoogieman is offline   Reply With Quote
Old 12-15-2008, 02:24 PM   #5
rnestved
God bless RTV sealant...and PB...and Duct tape. Am I missing anything??
rnestved is offline   Reply With Quote
Glock Forum
