Floor Plugs?? - JeepForum.com
post #1 of 5 Old 01-02-2003, 11:09 AM Thread Starter
jeepdan
jeepdan's Avatar
Floor Plugs??
What is the easiest way to take out my floor plugs?
Inside the jeep or under?
How many are there?
Thanks
1998 -TJ Black Sahara
4.0 I-6, D-44 Rear, 3.37 Gears, 5sp
Custom Exhaust (Borla Headers, Dynomax ST)
RE 2" BB w/ OME Shocks
Teraflex QD's
32x11.50x15 GY MTR's
Soft Bikini and Hard Spice,
Pioneer CD/MP3/WMA/XM
jeepdan is offline
post #2 of 5 Old 01-02-2003, 11:18 AM
macb
macb's Avatar
they are inside under the carpet, sometimes a small screw driver will help start em.
there are several locations - under the driver/pass feet, behind the driver seat, a few in the 'cargo' area. I added one behind the passenger seat since there isn't one and used the plugs from the rear which I removed when installing my trunk. behind the passenger seat is where I was finding a lot of water collecting but it had no where to go...nothing a 1/2 drill bit can't fix!
3.5" Terraflex, 1" BL, Flat Belly Pan, Currie Steering, 35s, Cowl Intake, blah blah blah:
Bob Supplee:
or (405) 799-8977
Stu Olson's great jeep resource site:
macb is offline
post #3 of 5 Old 01-02-2003, 12:29 PM
Scafone
Scafone's Avatar
I've been wondering for a long time why DC used those "sort of permanent" plugs in the spots of the floor that appears to be the obvious and best place for a drain hole, especially the ones in the rear passenger foot area. These are the oval plugs that are not rubber--they're sealed and painted, but they can be removed by bending the tabs and tapping them out from under the Jeep. There's one of these for each passenger foot area, along with the two round ones up front for driver/passenger.
I've been meaning to find a larger oval plug that will fit these locations. Has anyone else done this? Then I could actually just hose out my Jeep as I've always wanted to do.
"Laws that forbid the carrying of arms...disarm only those who are neither inclined nor determined to commit crimes...Such laws make things worse for the assaulted and better for the assailants; they serve rather to encourage than to prevent homicides, for an unarmed man may be attacked with greater confidence than an armed man."
--Thomas Jefferson
Scafone is offline
post #4 of 5 Old 01-02-2003, 01:30 PM
Smurfe
Smurfe's Avatar
I remeber reading that you can use a master cylinder gasket in the oval holes, I was in auto parts store a while back and seen in the "Help" display some Chrysler Master Cylinder Gaskets and they looked the right size and shape to me, might give that a look.
Edit: try this link Floor Plug Tips
Smurfe
(O||||O)....and on the 8th day, God drove his CJ....... No animals were harmed in the making of this post.
Smurfe is offline
post #5 of 5 Old 01-02-2003, 03:15 PM
macb
macb's Avatar
larger oval plug
I wonder if they are the same size as the hole in the firewall that the wiring harness comes through the rubber gasket? (driver side below the master cylinder... that gasket can't be to much...
Bob Supplee:
or (405) 799-8977
macb is offline
02-TJ Tub Floor Plugs archimeech TJ Wrangler Technical Forum 13 10-11-2008 05:06 PM
Floor Plugs ss454 YJ Wrangler Technical Forum 16 09-26-2008 01:09 PM
floor plugs 95YJRookie YJ Wrangler Technical Forum 7 07-27-2006 08:40 PM
floor plugs jbars YJ Wrangler Technical Forum 13 08-19-2005 11:00 AM
FLoor Pan Plugs? Nate1975 TJ Wrangler Technical Forum 5 11-05-2003 06:19 PM
