Flex pics needed - Currie A/R with 4.5" RE springs, 10" shocks, RE long arms on 35's. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Flex pics needed - Currie A/R with 4.5" RE springs, 10" shocks, RE long arms on 35's.
Price match at JeepHut.com20 Ton Press Brake DIY Builder Kit @ Swag Off RoadFenders for your Jeep at Jeephut.com
Unread 04-25-2010, 10:02 PM   #1
VanBCguy
Long story made short: I've been totally burned by the shop that did my build. I had an issue with the rear lower shock mounts only allowing for 2 9/16ths up travel. I took it back and they put new shock mounts on. They sent me pics to show that I now have 4.5" up travel, but the flex pics they sent are bothering me. I've also taken it out wheeling a few times, the wife and friends have taken pics and it seems as if the Jeep is leaning far too much and that the Currie A/R is almost non existent. I know (well, lets say I'm pretty sure) this isn't a Currie A/R problem. It has to be something else. The Currie is such a simple install. How could anyone bugger that up?
Here's a couple pics of me at flex. Does anyone else have the same build specs. that would allow me to compare the body lean? I have 4.5" RE springs, 10" Fox shocks, adjustable tri-link RE long arms, 35" TrXus MTs, and the Currie A/R. From what I've seen in many pics and read in many write-ups, I should only be losing about 4-5% of articulation as compared to fully disco'd.
What think you guys? Lets see your pics so I have a comparison.
Here's the pics the shop sent me to show they'd put the new mounts on.
From a trip a couple of days after I got it back. Shouldn't the body be sitting flatter?
Flatter like this pic of a TJ with ORO steering like I have (I know it has the Sway-Loc, but still...)? The body has minimal lean. I couldn't achieve this if I did the same thing. I'd be leaning so much I'd probably fall over.
What pics of comparable rigs and ideas do you guys have?
[url=http://www.savvyoffroad.com]Savvy Offroad - The brains behind brilliance[/url]
VanBCguy is offline   Reply With Quote Quick reply to this message
Unread 04-25-2010, 10:33 PM   #2
mrblaine
Wizard of Brakes
mrblaine's Avatar
The rig is not being held up by the rock on the passenger side.
Leaned over somewhat-
Diagonal-
Sneaking up on it.
Messing around with the optional line
And finally, my friend Jon messing around on the same line and only the tires are touching the rocks.
I am Savvy
blackmagicbrakes.com
mrblaine is offline   Reply With Quote Quick reply to this message
Unread 04-25-2010, 11:44 PM   #3
GMC7000
At the risk of feeding your frustration, I have found the off road industry/hobby marked with sloppy work and poor customer service.
GMC7000 is offline   Reply With Quote Quick reply to this message
Unread 04-26-2010, 12:59 AM   #4
Douglas S.
Keep in mind that the Jeep in the last pic (of the OP) is running airbags (ORO AiRock?), not coil springs.
1991 Land Cruiser HDJ81
1987 YJ Laredo
Douglas S. is offline   Reply With Quote Quick reply to this message
Unread 04-26-2010, 02:55 AM   #5
VanBCguy
Already noted. But thank you. It was one of the few pics I had easily handy to show my point.
