flex fan - JeepForum.com
post #1 of 5 Old 07-01-2007, 12:54 PM Thread Starter
claytonandson
claytonandson's Avatar
flex fan
has anyone replaced thier stock fan and f/c with a flex fan.what spacer is needed and does it need a reversed blade like on my f-150??
yellow jeep club #343
IAFF /FF's OF WASH. D.C. EMERALD SOCIETY/CHARLES COUNTY RESCUE SQUAD 51
claytonandson is offline
post #2 of 5 Old 07-01-2007, 03:36 PM
dyna
Why? the fan clutch is one of the better inventions if working correctly. Flex fans are noisy, and fuel sucking.
dyna is offline
post #3 of 5 Old 07-01-2007, 08:51 PM
44 NSB
NSB Florida Jeep
44 NSB's Avatar
For a couple of years I've had the #475 flex-a-lite II. The kit supplies everything you need. Included is a nylon shroud. No spacers. The reason I installed it was to employ a kill switch on it for mud / water. It works fine in Florida's heat and humidity. I'm not sure about the reversed blade. There is plenty of room between the fan (which is flat against the radiator) and the motors pulleys.
1997 Red TJ
5 speed w/ NP 231, Nth 4.5" lift, AntiRocks front and rear, skids (tummy tucker, front dif, oil pan, GenRite fuel tank skid, RockJock D-60 4.88, Flex-a-lite fan, Flow Cooler pump, Rhino lined tub, American Eagle Alloys, SS LTB's 34" x 10.5 w/Staun beadlocks, Tuffy console, MileMarker Hydra 12000
44 NSB is offline
post #4 of 5 Old 07-02-2007, 09:04 AM
TJ driver
I installed a Flex-Lite engine fan. I did have to get the reverse rotation for my 4.0L and ran a 2" spacer. It made a big difference and haven't noticed any drop in gas milage. I don't see why it would hurt gas milage, it wieghs a huge amount less than the stock fan. As for me personally, I like the fan noise while under heavy acceleration.
TJ driver is offline
post #5 of 5 Old 07-02-2007, 09:56 AM Thread Starter
claytonandson
its kind of an old school motorhead mod to take off weight and get more cooling.some even claim a little + in hp. thanks for the tip on the reversed blade. wasnt sure.
RE 3.5 - Need more flex?? seabass2020 TJ Wrangler Technical Forum 54 07-16-2009 11:25 AM
Max. Flex vs. Useful Flex and The Anti-rock lupinsea TJ Wrangler Technical Forum 34 10-29-2008 10:03 AM
Need More Flex JamesLouis YJ Wrangler Technical Forum 17 11-08-2006 07:25 PM
flex tjsooley TJ Wrangler Technical Forum 9 03-04-2006 07:10 AM
RE Super flex or Standard flex treypal TJ Wrangler Technical Forum 10 06-21-2005 08:01 PM
