Flex Cast Iron vs Flex Stainless ex Manifold - JeepForum.com
post #1 of 5 Old 01-12-2011, 10:16 AM Thread Starter
JeeporJag
I will be cringing with ever bolt as I take out A previous owner installed a POS Banks exhaust manifold that now cracked. I am soaking the bolts with penetrating oil every night. Other “car” forums say cast iron is better because it won’t crack as easily. I don’t care as much about performance as I do reliability. Both manifolds below have the flex tube on 1 and 6. What is the general consensus of the Jeep forum advantages/disadvantage of cast Iron vs. Stainless?
Crown Exhaust Manifold cast Iron
PART#: 4883385 MFR#: 4883385
$124.29
A1 Auto Exhaust Manifold Stainless Steel
with Gasket Kit from 4.0L 242ci
$126
JeeporJag is offline
post #2 of 5 Old 01-12-2011, 10:25 AM
pcoplin
The tubular steel one is fine. I've used the $65 Ebay ones myself with success, but have heard of those cracking, too. My guess is they all do unless it's the 2-piece factory one, but that can be expensive and custom.
For the price, durability, and even comes with a gasket, I use the Ebay ones.
Ebay manifold
FullStack MotorSports
pcoplin is offline
post #3 of 5 Old 01-12-2011, 05:31 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Get an OEM 2000+ one and have the "Y" pipe made at an exhaust shop...
Knuckelhead is offline
post #4 of 5 Old 01-12-2011, 06:08 PM
alextremetj
alextremetj's Avatar
Do you have any more pics of how your "Y" pipe is routed?
alextremetj is offline
post #5 of 5 Old 01-12-2011, 06:47 PM
Knuckelhead
AFSOC Retired
It was routed the same as an OEM 2000+ "Y" pipe. That one was/is on a 97...
Is my stock exhaust manifold made of cast iron ncmtns YJ Wrangler Technical Forum 1 07-21-2010 06:38 PM
Max. Flex vs. Useful Flex and The Anti-rock lupinsea TJ Wrangler Technical Forum 34 10-29-2008 10:03 AM
Factory Cast Iron or Pacesetter muddyforeman TJ Wrangler Technical Forum 5 07-10-2005 03:20 PM
RE Super flex or Standard flex treypal TJ Wrangler Technical Forum 10 06-21-2005 08:01 PM
Do you have to run a cast iron fork with the Posi-Lok?? condoor YJ Wrangler Technical Forum 3 04-20-2005 10:37 PM
