flex - JeepForum.com
post #1 of 10 Old 02-27-2006, 04:57 PM Thread Starter
tjsooley
flex
i want to lift only 2inch these are my options
http://www.offroadoverstock.com/stor...id=&modelyear=
or
http://www.4wd.com/newsite/shop/prod...atid=260&mid=n
i want the most flex for under 300
tjsooley is offline
post #2 of 10 Old 02-27-2006, 06:19 PM
Muddeprived
Muddeprived's Avatar
Think about future plans before deciding. Will you want to go higher later on with longer coil springs? If you do, get the BB so you can always re-use the bb spacers for a little more lift on top of the new kit you get later on. If this is the only lift you will ever put on your jeep ( ) , then go with 4wd's because it comes with 4 coil springs and 4 shocks (that's about it, the picture shows the 3" kit and you don't get all the goodies in that).
Neither is gonna flex more than the other, unless the shocks are longer. Both are 2" kits (actually the spacers are 1.75").
from everyone i've heard using 4wd's springs/shocks, none have ever complained. The dudes at the desk in 4wd's store say they sell more 4wd kits than any other.
2001 XJ Sport 4.5" LA
1999 TJ 2.5L 5spd 2" lift
Muddeprived is offline
post #3 of 10 Old 02-27-2006, 06:20 PM
crawldit
crawldit's Avatar
This is how the RE BB flexes with 31" tires.
I've started out with a BB on all three of my TJ's and then went up from there. You can usually get a good chunk of your money back on resale and it's a great size for getting used to what your rig can do. If you're going to go bigger later like I plan then save some cash and get the RE with spacers. If you're gonna keep it for a long time get the 4WD one with the 2" Coils.
2005 Rubicon :
4.0 Automatic,4.11 gears,4:1 Transfer Case
Teraflex 3" Coils,Rancho 9000x's,35" KM2's,(fenders...what fenders?), Cobra CB, Lowrance Baja 480c GPS,2"Wheel Spacers, Big Daddy Tie Rod,Superior Evolution Shafts.
crawldit is offline
post #4 of 10 Old 02-27-2006, 06:29 PM Thread Starter
tjsooley
can i do the 4wd lift and then later down the line do a 1 inch coil spacer ontop of that
tjsooley is offline
post #5 of 10 Old 02-27-2006, 06:31 PM
MCanavan
If you want a 2-3" coil lift go with OME, maybe a little more than what you want to spend but it's worth it IMO.
MCanavan is offline
post #6 of 10 Old 02-27-2006, 06:32 PM
crawldit
crawldit's Avatar
Yes
2005 Rubicon :
crawldit is offline
post #7 of 10 Old 02-27-2006, 06:40 PM
Muddeprived
Yup. You got a variety of ways to upgrade from the 2" coil kit. Add 1 or 2" spacers...add 1" bl.....or both for even more lift. Just gotta buy the additional parts required for some 3" and most 4" kits such as trackbars, sway links, possible sye/cv if not MML, etc....
post #8 of 10 Old 02-27-2006, 06:42 PM Thread Starter
tjsooley
cool thanks all i am going to go with the 4wd 2inch this summer
tjsooley is offline
post #9 of 10 Old 02-27-2006, 06:58 PM
TJgreg
TJgreg's Avatar
you'd be surprised what 2" and discos can do
Semper Fi
TJgreg is offline
post #10 of 10 Old 03-04-2006, 08:10 AM
davenjeip
davenjeip's Avatar
I'm liking the RE BB as well. For the money, it's awesome and has a great resale value if you ever want to go bigger.
Personally, I think it flexes rather well.
2003 TJ
www.davenjeip.com
davenjeip is offline
RE 3.5 - Need more flex?? seabass2020 TJ Wrangler Technical Forum 54 07-16-2009 12:25 PM
Max. Flex vs. Useful Flex and The Anti-rock lupinsea TJ Wrangler Technical Forum 34 10-29-2008 11:03 AM
Need More Flex JamesLouis YJ Wrangler Technical Forum 17 11-08-2006 08:25 PM
RE Super flex or Standard flex treypal TJ Wrangler Technical Forum 10 06-21-2005 09:01 PM
flex??? 4wheelinfool YJ Wrangler Technical Forum 4 06-15-2004 05:16 PM
