Flat skid to replace shovel stock skid?
#31 | ||
#32 |
is the 33 eng. skid 3/16" or 1/4" steel?
Gun Metal Blue Jeep Club Member #99 |
#33 | |
#34 |
the steel skid is 3/6", the aluminum option is 1/4"
with the framing, (i beleive) it acts like at least 1/4"
2008 Wrangler Unlimited X |
#35 | |
#36 | |
they have spacers if you do not want to that, but you get no additional clearance, but no mods. |
#37 |
I went with the 1/4" Teraflex Belly up. But I put on a 1.25" BL and a MML. I also had to have 1" cut out to shorten the exhaust hanger.
![]() My Skidrow engine skid bolted right up. (after drilling new holes) I don't think you can go totally flat when you have a lift. The angles are pretty extreme. I still have slight vibes with this skid with my RE 4.5 lift.
Black Jeep Society
Join here Last edited by mtngoht; 01-10-2008 at 02:57 PM.. |
#38 |
Ok, all good info,... sooo If the skid I eventually end up with requires no BL or modifications, I still think it might be a good idea to install the 1" BL anyway, to help gain a little extra clearance for the exhuast and cat convert. to keep all that heat a bit more away from the floor board. Am I thinking right here or am I just being Anal?
#39 |
Skyjacker makes a relatively inexpensive one, as well.
************* '03 Rubicon - 3" lift, 1" BL, RE LA upgrade, armored, winch, recovery gear... ... all equipment normally needed for Houston traffic |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
