Flat skid to replace shovel stock skid?
| 1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with Full | Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | Spartan Lockers FREE SHIPPING Excellent Prices |
#1 | |
I know there are the belly up/tummy tuck skid plates,(which is what comes up on a search) but what are good choices for just replacing the stock skid with more of a flatter type of surface, any recommendations, especially any that would just bolt up?
Thanks for any feedback and this is for a 04 SWB TJ
2004 TJ Rubi |
#2 |
You know i was wondering the same thing for my LJ 2006 Rubicon.
2006 Rubicon Unlimited Khaki: AUTO, 4:11 D44/D44, REBB /w Mono tubes, Rancho front stabilizer, 31 x 9.5 LT245/75R16 MTRs, Stock 16in Moab Wheels, Olympic Reverse-A-Bars,KC Daylighters on windshield brackets, Garmin Nuvi GPS, Pioneer Sound, 3A fire extinguisher, Line-X interior... www.stevensinger.org <-- Photography website Hello, my name is Steve and I am a Jeepaholic. LJ Owners Member 155 Rubicon Owners Member 123 New Jersey Jeepers Member 44 |
#3 |
If you want a straight bolt-on that doesn't require exhaust mods, a body lift etc, I think the Clayton Offroad skid is probably your best bet. You won't gain much (if any) additional clearance, but you will have a smoother surface that's also much tougher than the stock skid.
#4 |
TnT Customs....has a replacement skid for the stock shovel...bolts right in place with no modifications needed(ie body lift, MML, SYE)....I recently installed one and it's beefy, 1/4" I think, and I gained just about an inch of ground clearance. only issue with install was having to clearance part of the bracketry on the top of the skid because it was contacting the front of the tranny mount, and had to cut down the tranny mount bolts cause they stuck out the bottom of the skid.
#5 |
Does TnT make one for the LJ?
#6 |
got Links?
Gun Metal Blue Jeep Club Member #99 |
#7 |
1/4" flat skid Links also in my sig, as well as matching engine skid. I got a dimensioned drawing on there as well, so you can just take it to your local fab shop.
Jeeprocks86 made a nice one as well. |
#8 | |
#9 | |
Thanks for the replys...
Here is a link to the Clayton skid, looks great but it looks like it is to be used with their long arm lift??: http://www.claytonoffroad.com/index.aspx?sdr=/get.doc.aspx&qs=LD:Products%20Other&l=category&p=a rmor Here is the TnT link, but didn't see any info: http://www.tntcustoms.com/webV5/TJ_HDBellypan.asp Quote:
2004 TJ Rubi |
#10 | |
Skids like this exist for the 97-02: https://rs325.securehostserver.com/~extremem/osCommerce/catalog/product_info.php?cPath=23&products_id=97&osCsid=af 4cefb667a5a1a7702607a1ea643481 But with the Rubi our choices are more limited. The best bet would be Jeep Medic, which lifted the skid 2", but they went out of business and their products were made to order, so thats no longer an option. Probably the next best thing would be the terraflex belly up. A BL is recommended for Rubis though, you could purchase this belly up and then use a Tcase lowering kit or washers to lower it so the belly up is not as extreme. Making the 2 3/8" belly up into a 1 3/8" belly up, which would not cause as much of a change to your driveshaft angle and also making it so you dont needing the 1" BL. You do need to relocate your locker air pumps though with this skid: http://www.4x4groupbuy.com/store/teraflex-belly-skid-plate-but03-p-4698.html
OME ZJ/LJ combo | SwayLOC | 1.25" BL | Nth TT | Riddler diff covers | EMP gastank skid | 33" MTRs | Warn M8000 | Cobra75 and much more... Riddler torture test video Oil Filter Study Useful Axle Info Thread |
#11 | |
#12 |
[QUOTE=Crashnburn80]I do not think such a skid exists for the 03-06 TJ, especially for the Rubicon. Since our Tcase is different we require a Rubi specific skid.
Well.... That is what I was afraid of, but thought something might be out there..... I really like my jeep (it out drives me) but the design of that stock (shovel!) skid plate is horrible....Thanks for the idea on the terraflex, sounds like a good idea.
2004 TJ Rubi |
#13 |
something like a Skid Row Engine/Oil Skid will connect to your stock TC Skid (Shovel) and allow for better moving over obstacles.
The Skid Row skid will also mate-up with the 33 Engineering TC Skid & Nth (AEV) Tummy Tucker if you want to do it in steps (like I did).
2008 Wrangler Unlimited X |
#14 | |
Contact Joe at EndlessMtnFab here: Joe@EndlessMtnFab.com great prices and great service, he'll also be able to help you figure out relocating your air compressor. he's a vendor for many off-road companies and can get pretty much any part you want/need....hope this helps...like I said before, I have this skid on my TJ and it's MUCH better and alot simpler than the stock shovel, with very minor modifications needed to install......no BL/MML/driveshaft or exhaust mods needed... |
#15 |
check out 33 enginering. I have been looking at their skid sinse medic is now gone. It appears to offer the most clearance from what i've read.
2005 red unlimited, 6 speed on 37" pittbulls w/ kmc beadlocks..... Stuff from rokmen, currie and jks |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
