#1 | |
Flat flares Xenon vs Bushwacker
I'm pretty set on getting a set of the new flat flares that have been coming out. For those of you who own them, any pros and cons on them? Anything you like or dislike on one or the other?
-Dane |
#2 |
Bump. I know you people are out there
-Dane |
#3 |
O rly?
I chose and will again choose Xenon over Bushwacker.
I think the material is better. Bushwacker claims that their material is flexible and will not crack. However, my experience was the opposite. Hence why I went with the Xenon's and I think they're a better product IMO. Either way, if you order them now, or very soon off of 4wd.com you'll get a percentage off of your order and free shipping. So you'll save a lot off of your pricey order. Just thought I would let you know that if you're considering buying them soon. |
#4 |
I have the 4" Xeons flat flares. Don't know a thing about bushwacker though.
I am happy with the xeons.
05 Rubi LJ with a few mods. |
#5 |
Any sort of fading at all??
-Dane |
#6 |
intentionally left blank
I bought the 4" xenons not to long ago. I used the search button and found a ton of info. If you need 6" of coverage I would go with the bushwackers. There two piece mounting system seems like if could handle more abuse. Look for Jerrys thread on them. Any flare you get will fade. You can paint them, or I used Xenons suggestion and used 808 Protectant. It seems to work.
#7 |
I have 6" Bushwackers on my TJ & if your going to be wheeling your JEEP all I can say is GARBAGE!!! I know ppl with other brands, go with anything but bushwacker! I'm planning on front tube fenders 4 2010 8-)
4.0L Swapped =) |
#8 |
they're called bushcrackers for a reason. they crack
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#9 |
Gotta Lift It
I have the Bushwacker flat flares and have not had a problem with them as of yet, it is my understanding the the flat flares are made from a different material then the old flares that are prone to cracking.
Here is the thread all about the Bushwacker flat flares http://www.jeepforum.com/forum/f9/new-bushwacker-flat-flares-installed-they-very-cool-pics-658949/ |
#10 |
I love my 6" Xenon's. Coverage with 35's is great. No fading yet and they have taken alot of abuse. I've laid them hard into trees on both sides buckling the fenders and they have just popped back into shape with no cracks. You do need to use a UV protectant or just paint them. I do think the new Bushwacker flat flares do have a better light setup and mounting system. The lights on my Xenons were a PITA to mount in the fender. Seems like Bushwacker took a great flat fender setup (Xenon) and made it better.
[SIZE="3"][FONT="Comic Sans MS"][URL="http://www.facebook.com/kb9qdi"]K B 9 Q D I[/URL] 06 TJ D30/8.8 Aussied, 4.88's, 35" KM2's Hill Top ORV Harrison,Ohio Terrain Stompers Cincinnati,Ohio [COLOR="Red"]RED JEEP CLUB MEMBER #443[/COLOR][/FONT][/SIZE] |
#11 |
He was asking about bushwacker flat flares, not the pocket flares.
#12 |
consider trimming the stock flares and using the $$ elsewhere
06 Rubicon,BL,OME,35s,Currie,Rokmen,Savvy,UCF TT skids,Tom Woods,winch,brake upgrade,etc On-On! |
#13 | |
Where did I mention pocket flares?
[SIZE="3"][FONT="Comic Sans MS"][URL="http://www.facebook.com/kb9qdi"]K B 9 Q D I[/URL] 06 TJ D30/8.8 Aussied, 4.88's, 35" KM2's Hill Top ORV Harrison,Ohio Terrain Stompers Cincinnati,Ohio [COLOR="Red"]RED JEEP CLUB MEMBER #443[/COLOR][/FONT][/SIZE] Last edited by kb9qdi; 12-31-2009 at 05:56 AM.. |
#14 |
#15 | |
![]() ![]() Also check this out. http://www.jeepforum.com/forum/f9/bushwhacker-flat-fender-install-sb-sliders-891500/ Good luck with it...... |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
