flat fendering tire size - JeepForum.com
post #1 of 16 Old 02-28-2006, 01:02 PM Thread Starter
lonestarrebeltx
1976 FSJ Wagoneer
I have a 2000 Sport with a 2 in BB and i was wondering if i make the front flat fendered would i be able to fit say a 33 in tire, or would the rear still have problems. I am on a very tight budget (0$) so doing the body lift is out. Has anybody flat fendered their wrangler with little or no lift I've been wondering what it would look like
lonestarrebeltx is offline
post #2 of 16 Old 02-28-2006, 01:09 PM
UCTJ
UCTJ's Avatar
Do a search this topic has been covered w/pictures to give you some ideas. Check in the jeep registry section or the photo requested section you may find what your looking for. You might be able to get by on the BB and 33...again you can search that BB and 33 as I am sure its covered, you may get some fender/tire contact by going this route though.
UCTJ is offline
post #3 of 16 Old 02-28-2006, 04:23 PM
txjeepn
So you dont have the money for a 1" body lift, where are you going to pick up 33" tires?
txjeepn is offline
post #4 of 16 Old 02-28-2006, 04:25 PM
txjeepn
Do a google for hockey puck lift, you can do that for $25
txjeepn is offline
post #5 of 16 Old 02-28-2006, 08:40 PM
stretch276
x2
Silver 05TJ RME 6spd
teraflex 3T w/procomp ES9000s
15x8 3.75bs procomp RCs
33x12.5x15 bfg mts
jks quickers
teraflex adj. trackbar
stretch276 is offline
post #6 of 16 Old 02-28-2006, 09:34 PM
BigWaylon
tubework is cool...
BigWaylon's Avatar
are you against cutting the rear?
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
BigWaylon is offline
post #7 of 16 Old 02-28-2006, 10:01 PM
TJVigilante
friend up here has 2" BB 1" BL and runs 35" MTR's (he's measured them at 33-34" OD) and has a really great amount of flex, mostly downtravel.
TJVigilante is offline
post #8 of 16 Old 02-28-2006, 10:10 PM
EaglesSJ
EaglesSJ's Avatar
I have flat fenders details are in my profile and pics are in my sig if you want to see what the combo looks like.
EaglesSJ is offline
post #9 of 16 Old 02-28-2006, 10:31 PM
Tacoma750
I was lead to believe that Flat Fendering doesnt give you any better tire clearance...No?
Tacoma750 is offline
post #10 of 16 Old 02-28-2006, 10:38 PM
BigWaylon
tubework is cool...
BigWaylon's Avatar
if you're hitting your flares now, then you will get tire clearance by flat fendering...
Greg
post #11 of 16 Old 02-28-2006, 11:18 PM
NEWtoTHEjeepLIF
I guess it all really depends on what you are willing to hack right?
I am going a similar route... I have the 2.5"ome(not on yet) When it goes on I will add a body lift (most likely 1.25") and run 33"s for a while. But soon, when I am compatent and feel I have studied up enough I plan to start hacking away at my rig... Front and back... After adding some re-enforcement and changing my rear end, I should be able to shove some 34's in there with totally minimal lift and a really low cog..correct me if I'm wrong.
NEWtoTHEjeepLIF is offline
post #12 of 16 Old 02-28-2006, 11:23 PM
FifteenCents
I had 31x10.50 in this pic, I now have 33x12.50s and they rub at full stuff when the jeep is all twisted up with opposite corners stuffed. I have a 2" BB with 1"BL and 1" MML
The above post is my opinion and I have no facts to prove it... :)~
The ultimate TJ owners only forum
FifteenCents is offline
post #13 of 16 Old 03-01-2006, 10:07 AM
TJeeper
TJeeper's Avatar
It depends on whether or not you take into consideration the flare, and if you are going to be using some sort of tube. If you remove or trim the flare, you will gain an 1", enough for a larger tire size. If you use some sort of tube fender (the exception being TnT's) the tube hangs below the fender and you will gain no clearance.
The best flat fender I have seen is on JU where someone cut the fender, then cut 2" off the hood, and made his tube fender there. Looked like enough room to go up 2 tire sizes (YMMV).
Patrick
TJeeper is offline
post #14 of 16 Old 03-01-2006, 10:27 AM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
several Months ago, Jp magazine had an article or rather several articles on it. They put 35s with no lift, Granted they used a new hood and Cut the rear way out, i think it can be done
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #15 of 16 Old 03-01-2006, 11:01 AM
TJeeper
TJeeper's Avatar
You are thinking about the hood from Campbell Enterprises. You remove the fenders, and the flares are built into the hood. You also have to fab up a way to relocate everything that sits on the fenders. A member of my club had one, I thought it was ugly.
http://www.campbellent.com/HOODS%20A...DY%20PARTS.htm
TJeeper is offline
flat fendering jgillespie YJ Wrangler Technical Forum 16 04-08-2009 09:06 PM
flat fendering before and after devilishred TJ Wrangler Technical Forum 12 04-29-2007 07:27 PM
flat fendering my yj rsoffar YJ Wrangler Technical Forum 4 09-21-2005 10:47 PM
Flat Fendering Rig6891 YJ Wrangler Technical Forum 4 06-20-2004 12:13 PM
Flat Fendering a YJ Mad Man YJ Wrangler Technical Forum 3 02-04-2002 08:03 AM
