Flasher relay/electrical ground/ HELP! - JeepForum.com
post #1 of 5 Old 10-16-2013, 08:16 PM Thread Starter
Finz0021
Hey all, I have a 98 wrangler with the inline 6. My flasher relay is constantly blinking with the power on. When you turn on the hazards, or a turn signal the clicking returns to its normal clicking rate, but after the signal goes off the clicking picks up to an abnormal fast rate as if i bulb was out.
What ive already tried/done:
Replaced all bulbs
WD-40 the connectors of the flasher relay
Replaced the flasher relay
What can I do next??!
Finz0021 is offline
post #2 of 5 Old 10-16-2013, 08:25 PM
Shark_13
Multifunction switch?...just a guess.
Shark_13 is offline
post #3 of 5 Old 10-16-2013, 08:45 PM
ob269
Try replacing the flasher itself
ob269 is offline
post #4 of 5 Old 10-16-2013, 08:55 PM Thread Starter
Finz0021
I already replaced the flasher. It was an EP26, and the issue didnt change. still a constant fast clicking (i can feel the clicking coming from the flasher)
Finz0021 is offline
post #5 of 5 Old 10-16-2013, 11:39 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
No expert on this & never happened to me but I have read that that will happen when it gets wet & will continue until it drys out then it stops on it's own. I seem to remember hearing that you have had A LOT or rain up there in Boulder recently.
Rubi4MyMrs is online now
blinker , electrical issue , flasher , lights , relay
