#1 | |
Flare Trimming 101
My flares rub a bit and it doesn't do any harm, but it's kind of irritating. That, and I just can't leave things alone
![]() This is a very easy mod and I've seen some other write-ups - but not one with pictures. My plan was to trim 3/4" and maintain the stock lines. Step one: Mark the flare. I used a compass and ran the metal point along the flare edge. ![]() ![]() Step two: Score the flare with a box cutter or exacto knife. I used about 3 passes. The first pass is very light and then progressively deeper on subsequent passes. You can fold the edge of the flare on the third pass to open it up a bit. Be careful! ![]() Step three: Cut the bottom of the flare all the way through. You just need to get it cut about 1-2". ![]() Step four: Continue the final cut while pulling out and down on the piece you're cutting off. I only have 2 hands, so I couldn't hold the parts while taking this picture. ![]() Step five: I dressed up the edges with a sanding sponge. I will probably paint the flares again since the Krylon was flaking off where I cut. It's been about 3.5 years since I painted them. Then again, I might just leave them be. Before: ![]() After: ![]() Did I mention to be careful? I did this while trimming up a tiny piece that nobody would ever see I just can't leave it alone ![]() ![]() Happy Jeepin'. Now I'm all ready to beat on this thing tomorrow
#2 |
TITS
Nice cuttin and good instructions.
#3 | ||
Purple People Eater
hey good job, it looks great. nice write up
My Purple People Eater Build |
#4 |
Sweet writeup. You went pretty easy. I believe I took over a few inches off of mine, right up to where it begins to curve.
My Jeep Is For Sale! |
#5 |
Nice write up. I'm going to do this tomorrow.
Thanks |
#6 |
Well done. I have an extra set of flares and this might just be a good project for them. Good write up too.
#7 |
Demonic Jeep Freak!
#8 |
Nice, clean work (oops on the finger). The step-by-step on the pics is great!
My build thread: http://www.jeepforum.com/forum/f9/rubiconrazorbac-build-thread-792423/ |
#9 | |
Boogie always has to get a post or 2 in on every thread. |
#10 |
Did you sand that down or just leave it?
#11 |
Nice My jeep would probably look an inch taller if i did that.
#12 |
I sanded the edge where it was cut. I just knocked the edges down.
I think what makes it most notable is the lighter edge. What appears to be a grayish/white line is actually the faded color of the flare where the Krylon flaked off. I painted the flares years ago. |
#13 |
looks good,jeeps are like vampires,they like your blood.
#14 |
Trail Proven
I picked up a complete set of flares for $25 today just for this type of project.
Over the mountains and through the woods, across the stream and up the slickrock, down the canyon and over the rocks to nobody's house I go. |
#15 |
Nice write-up. I did this a few months ago. However, after I marked it, I used a plastic cutting wheel on my Dremel instead of the utility knife. I can't typically make deep enough cuts with a utility knife and keep it on track.
- 2001 TJ 2.5L, Smittybilt X2O-8 winch, Spartan locker (D30), tube fenders, custom mini-stinger, 2"BB, 1"BL, 35" STTs on Cragar 15x8 Black Steelies - In-Progress: HP30, D44, dual OX lockers, 4.88, 3.5" suspension - Jeep Build: http://s1186.photobucket.com/albums/z373/JFjeld/Jeep_Build/ |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
