fixing zippers? - JeepForum.com
post #1 of 6 Old 05-31-2006, 02:15 PM Thread Starter
MoJo3494
MoJo3494's Avatar
fixing zippers?
Can you fix the zippers on the soft doors? If so how?
MoJo3494 is offline
post #2 of 6 Old 05-31-2006, 03:05 PM
phydeaux
Are they broke? Or just stuck?
If they're just sticky and hard to pull, you can make them move a lot smoother by rubbing a candle on the teeth. It works great.
'98 TJ Sport, 4.0, 5 spd., 3.73's; 4" RC Series II Lift; 33's, Daily Driver.
Life Member Hummer Recovery Team.
Just
Empty
Every
Pocket
phydeaux is offline
post #3 of 6 Old 05-31-2006, 03:08 PM Thread Starter
MoJo3494
MoJo3494's Avatar
they are broke, the teeth came apart on both ends they wont even move.
MoJo3494 is offline
post #4 of 6 Old 05-31-2006, 03:20 PM
Mach04TJ
Take it to a marine shop. That's where I got mine fixed at. Alot of times boats will use the bigger zippers so usually they have them in stock.
[CENTER]Air Force Jeep Club Member #35
BLACK JEEP CLUB V2.0 MEMBER #54
04 Columbia Edition
CENTER]
Mach04TJ is offline
post #5 of 6 Old 05-31-2006, 03:22 PM
jreuscher
I had the same problem on my back window.
The zipper on my back window was almost impossible to move. Once zipped, the teeth easily came apart. Drove me crazy!
I compared zippers (since there are two on the back window) and I noticed the bad one was slightly wider where the teeth go in. I got a pair of pliers and crunched the opening so it was narrower, and bingo, works great.
2003 Sport
4.0 5-speed manual
Dana 44 rear
4 wheel disc brakes
31 x 10.5 Dayton Timberline A/T, with 15 inch Canyons
jreuscher is offline
post #6 of 6 Old 05-31-2006, 04:30 PM
miguelitojeep97
about how much did you pay to get that done? and they replaced the whole zipper assembly?
1997 TJ 4.0 5 spd. rock track 4:1, 3.5 inch Rock Krawler 5 inch stretch long arm, 35 inch MTRs, Warn 9k, D44/30 locked with 4:88s, Vanco BIG BRAKES!!and more...
miguelitojeep97 is offline
#$(*#$ing zippers jake7893 TJ Wrangler Technical Forum 11 07-18-2009 07:59 AM
How do you get your zippers down? tecumsa Wrangler General Discussion 9 03-19-2009 01:18 PM
zippers vincec TJ Wrangler Technical Forum 6 06-06-2008 08:31 PM
zippers plk457 JK Wrangler Technical Forum 2 04-01-2008 02:06 PM
%&#$ Zippers!! pc451bc TJ Wrangler Technical Forum 17 09-30-2006 02:32 PM
