Fixing Sag with Spacers - JeepForum.com
post #1 of 7 Old 12-24-2011, 08:19 AM Thread Starter
underliner6
Im getting ready to put on my new warn bumper and warn xd9000i winch. Im worried about my front end sagging from soo much weight. I have 4 inch springs and a 1.25" body lift. Would a 1 inch coil spacers make up for the sagging coils? Can i run a coil spacer and have body lift on my jeep at the same time? Will spacers have any negative effects on my jeep like less spring articulation? Or will the sag from the winch not be too noticeable and i should just leave it be?
Thanks for the help!
-Jim
underliner6 is offline
post #2 of 7 Old 12-24-2011, 08:30 AM
MFERNICO
Fully load up your Jeep and fill the tank. If you're still lower add a set of .75 or 1 inch spacer. No limitations.
MFERNICO is offline
post #3 of 7 Old 12-24-2011, 09:10 AM
Cassafrass
The only real downside to spacers is that they don't provide any additional flex, which replacement springs will, your ride may suffer; but since you just want to make up for the sag from the winch on new springs I wouldn't worry about it. I'm not a fan of spacers. If your stock springs are pretty worn out or sagging. Coil spacers with shocks cost nearly as much as the springs do so if it were up to me I'd prolly get new coils.
Cassafrass is offline
post #4 of 7 Old 12-24-2011, 09:21 AM
MFERNICO
Well the OPs problem is leveling out an existing 4inch lift not adding a lift. I agree you don't gain articulation but that's not the point in leveling. Read the OP before offering advice on a different topic altogether, BB vs 2 inch coils.
MFERNICO is offline
post #5 of 7 Old 12-24-2011, 09:28 AM
OR-TJ
yes you can add a 1 inch spacer to level it out. I have the exact same set up as you, 4in coils and 1.25 BL and I am planning on getting a winch soon and I will be adding a 1in spacer. So your good!
OR-TJ is offline
post #6 of 7 Old 12-24-2011, 09:54 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
4" lift, 1.25" BL and 1" spacers up front that I installed on my brother's Jeep.Heavy front bumper and winch.No problems.
TheBoogieman is offline
post #7 of 7 Old 12-24-2011, 09:59 AM Thread Starter
underliner6
Awesome guys! Thanks for the help, i appreciate it!
bumper , coil spacers , sag , winch
Fixing 4wd. Please Help JC_Sahara TJ Wrangler Technical Forum 4 09-24-2010 11:22 AM
11" wide tires; spacers or no spacers? Hilldweller JK Wrangler Technical Forum 19 07-01-2008 05:38 AM
need help fixing this please. Atticus_6147 YJ Wrangler Technical Forum 2 03-12-2008 05:48 PM
Fixing a 91 LlamaJeep YJ Wrangler Technical Forum 3 01-29-2007 03:33 PM
Help fixing D35 Please EvilSpock TJ Wrangler Technical Forum 8 01-14-2007 07:58 PM
