Fixing a rear axle leak - JeepForum.com
post #1 of 6 Old 10-26-2011, 11:42 AM Thread Starter
Roxy2011
Hi all,
I went to the mechanic today... he told me that a rear axle leak cannot be fixed - he says it has to be replaced including the ball bearings and cons. He said that the axle seal cannot be replaced without removing the ball bearings and cons, and by removing these, they automatically get damaged; hence the full thingie needs to be replaced. This will cost $$$.
Is the mechanic taking me for a ride? Can a rear axle leak be fixed keeping the ball bearing and cons intact?
Whats a brake cylinder? He says that too needs to be replaced. Cant it just be fixed?
By the way, shez a 99 TJ soft top with a 2" lift kit.
Thanks
Roxy2011 is offline
post #2 of 6 Old 10-26-2011, 12:02 PM
Benderff
Benderff's Avatar
Is he saying the whole axle assembly needs to be replaced?
Benderff is offline
post #3 of 6 Old 10-26-2011, 12:22 PM
mike481
mike481's Avatar
Originally Posted by Roxy2011 View Post
Hi all,
ball bearings and cons. Is this his terminology or yours?
Is the mechanic taking me for a ride? possibly
Whats a brake cylinder? He says that too needs to be replaced. Cant it just be fixed?He is right about this one. They are cheap and easy to replace
Thanks
If "ball bearings and cons" are his terminology and not yours then never go back to his shop. Where is the axle leaking? It could be the pinion seal or the axle shaft seals. All seals on the axle can be replaced easily by a competent shop with no other damage. The only reason to trash the whole axle is if it's bent and this has ruined the seals and will ruin any new seals you install.
Chuck- A better dog than I could ever deserve
RIP 4-14-2012
mike481 is offline
post #4 of 6 Old 10-28-2011, 09:09 AM Thread Starter
Roxy2011
Yup this was his terminology. He insisted that the ball bearing and cons need to be removed to fix the seal, and u cant remove them without damaging them, so u gonna need to replace the whole thing including the ball bearings and cons.
Thanks for ur inputs, i'll take the Jeep for another opinion. Thanx
Roxy2011 is offline
post #5 of 6 Old 10-28-2011, 09:15 AM
JBTJ
That guy has no clue on what he is saying, get your JEEP and leave now. Any and all leaks can be fixed with no problems. Also the brake cylinder is a piece of cake to replace as well. Although you can get a tool that can hone it out, then replace the seals. I just did it in my JEEP.
JBTJ is offline
post #6 of 6 Old 10-28-2011, 10:07 AM
Robert J. yates
Actually..... to get to the seal on a D44 (don't know if he has one or not) you have to strip the bearing off and press a new one back on with the new seal. Beyond that, you can always pull the entire assembly and use Mopar gray silicone on the axle tube to try and seal the leak without stripping the bearing. It's always a good idea to use RTV there anyways. Not a big deal.... maybe a 1 hour driveway job for the average hobbiest.
Originally Posted by samgm2 View Post
And yes, I am an exceptional scientist and engineer.
Robert J. yates is offline
Rear Axle Leak? Help!! JBStone TJ Wrangler Technical Forum 0 08-10-2008 11:53 AM
Rear axle leak?? snakester14 TJ Wrangler Technical Forum 6 03-21-2008 10:07 AM
Rear Axle Leak PullMeSideways TJ Wrangler Technical Forum 13 04-13-2007 01:32 PM
Fixing rear main seal leak? wessy YJ Wrangler Technical Forum 9 04-12-2007 10:58 AM
LEAK??? Above the rear axle. mpala96 TJ Wrangler Technical Forum 4 11-07-2006 06:35 AM
