Fix your TJ's dead gauges (write-up)
#46 | |
What is this? Is this a wire attached behind the sterring collumn? If it is, this might answer some of my electrical issues. Thanks. [IMG]
#47 |
My cluster quit on me once. I checked the fuse for it behind the glovebox, and it hadn't blown. I replaced it anyway and I haven't had a problem since.
'97 TJ Sport, 4.0L, AX-15, D30/35, Dayton Timberline AT 31x10.5x15s, Warrior rack, Silverstars, KC HiLites Replacement Fogs, Optima Yellow Top, EBC Greenstuff pads and Centric rotors, 164K '97 Rodeo, '96 Jetta, '02 Cabrio, '03 E46 |
#48 | |||
Disgruntled Jeepforum'er
Location: NY/NJ/PA Tri-State Middletown NY 10941, New York
Seems that the guy is banned and click-free is nice.
So... Quote:
-Ryan Google Voice (or the number Grape calls when drunk): 845-476-8182 Quote:
#49 | ||
Part Deux!!
#50 | ||
Part Trois
#51 | |||
Part Quatre
#52 | |
Gauges have been out for over a year now...last I checked the fuses were fine. Going to try the dash board this weekend. |
#53 |
I have a 98 TJ and have been having intermitten problems with my gauges off & on for the past three years. I had thought it was something else but since reading the writeup about cleaning the back of the dash cluster I thought it would cure the problem! Wrong! I've taken the dash out and cleaned the cluster pins three times now and it makes no difference. I start the jeep and after it runs for a little while the alt gauge pegs out and stays there. If I turn the engine off then on it will correct itself but will peg out again.
Some times the speedometer will freeze up, along with the tachometer and the other gauges then they start working again. All the fuses are good (glove compartment & under the hood) and I haven't noticed any worn wires that are shorting out. Can anyone give me another idea? |
#54 |
I've been having the same problem for almost 2 years now. Like this poster, I've pulled the dash cluster apart twice to clean and tweak. Sometimes it's good for days and other times could happen 2-3 times within one day.
Plus I also noticed that I'm able to get my gauges working immed when this happens by touching the brake pedal. |
#55 | |
But you might also want to get your alternator checked. Mine was about to die, and starting doing crazy things with the gauges for a bit. Replaced the alternator, and they are all fine now. |
#56 |
Thanks for your contribution. It might be a grouding problem. I'm pretty sure the alternator is good. I've checked it and had it checked a few times in the past, while the gauges were dead. Someone on another thread said they held down the trip odometer clear button and turned the ignition to the on position and that checks the gauges. I've done that but I have to take it out driving to check it. It some times takes a few minutes to start its' acting up. I'm heading up to play in the snow for a few days tomorrow so maybe someone will come up with a solution while I'm away. I know, I know but I can always hope.....
#57 |
ya been fightin this problem for over a year now. .sometimes i can clean/sand them file them whatever down clean.. they work for a few weeks then out again.. this last time.. I can not get them back for more than a min or two at best.. all starts with the air bag light coming on first. so i know its coming.. then wacky gauges then out they go. SOMETIMES, turning on the lights will bring them back for a moment. i just drive around with the dash apart and pull the cluster in and out as I drive to check speed/fuel and such.
anyone have any other ideas? any certain ground wires to check? or anything else? |
#58 | |
Right now, I'm looking at replacing the dash cluster with another one to see what happens after 1-2 weeks. |
#59 |
thats what I was thinking...a new dash part
#60 |
The adventure continues.
I did pick up a another dash cluster that has 1,000 miles more than my own and will wait until the mileage is equal for the change. Therefore, "my" mileage will still be acturate. In the meantime, the gauges today went dead again for over 10 minutes. Longest time ever. Upon hitting the horn, which always works the gauges came back to life. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
