Quantcast Fix your TJ's dead gauges (write-up) - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Fix your TJ's dead gauges (write-up)
Old 07-07-2007, 07:26 PM   #31
jeeptrix
Just did this and still no luck. My RPM guage is still dead, and my speedometer guage still keeps sticking constantly until I smack it. I got everything taken apart, and cleaned out, and it's still dead. Anyone have any more advice?
jeeptrix is offline   Reply With Quote
Old 07-22-2007, 10:44 PM   #32
ipitythefool
sorry to jack this thead, but does anyone know of where to go to get the odmeter recalibrated?
thanks
ipitythefool is offline   Reply With Quote
Old 08-30-2007, 04:41 PM   #33
Shinitenshi
could you just swipe them with alcohol?
Recovering from a crash!
1997 Jeep Wrangler SE 4x4
Low output 4 Cylinder Jeep Club Member #0492
Shinitenshi is offline   Reply With Quote
Old 08-30-2007, 05:27 PM   #34
cybernutt86
oh man... thanks a lot. this is exactly what i needed. i just drove the better part of 300 miles without gauges yesterday...
cybernutt86 is offline   Reply With Quote
Old 08-30-2007, 07:56 PM   #35
samuelshoun
x1000 thanks, been having this problem and the fix seemed daunting until i saw your write-up. it looks relatively easy.
who has dielectric grease? autozone? radio shack maybe?
99 TJ, 3" sus lift, 33x12.50 mickey baja MTZ's, MM SE9500C winch .... more in the works ;D
samuelshoun is offline   Reply With Quote
Old 09-26-2007, 01:02 PM   #36
retroflow
Originally Posted by Steelman
I did get my guages fixed. Found the cause of the problem, almost by accident! It's not a great picture, but you can see where the wires had rubbed through and were shorting out (long story). It's right about where the wire turns up to go under the roll bar padding.
I know it's been a while since you posted this information but I think it's quite significant. I for one, wouldn't think to look that far aft of the dashboard for a fault. I can see how this short could effect the dome light and the courtesty lamps, but affecting the instrument cluster and radio is surprising as they're all on different fuses entirely. Theoretically, one fuse going should have stopped the short there without taking out the other ones as well. Your discovery raises all sorts of questions but, in a positive, thought provoking way.
That being said, I'm wondering now how a short like this, or anywhere else could affect other electrical components of the Jeep as well. My problem is different on the face of it (Airbag lamp) but may not be too far away afterall. I haven't blown any fuses to anything yet but, this doesn't mean there isn't a wiring problem. Just that it hasn't blown a fuse. Whatever is wrong hasn't exceeded the amps the fuse is rated for.
retroflow is offline   Reply With Quote
Old 09-26-2007, 01:06 PM   #37
retroflow
My local autoparts stores (AutoZone, Advance, Pep Boys) usually have the little packets of Dielectric grease on a small rack at the checkout counters, along with that same companies other products, like anti-seize grease, etc. Usually costs about .90 cents or something. Ask the counterperson for help.
Old 09-26-2007, 01:34 PM   #38
gUanoTJ
retroflow,
Have you checked the connectors on the clockspring behind the steering wheel. Most likely that is what is causing your problem. This may not be a big deal now, but down the road it may affect many things from somehting as simple as your horn, all the way to issues with rough idle, etc. Do a search for clockspring replacement and see what you can dig up. HTH
gUanoTJ is offline   Reply With Quote
Old 09-26-2007, 01:45 PM   #39
Steelman
IX-X-XIII-XIV-XL-XLIII
Steelman's Avatar
The reason everything had quit working is because this short was blowing the F17 (I'm fairly positive that's the correct fuse number...as you've stated, it's been a while!) fuse under the hood. All is still well.
I've mentioned that particular fuse to a number of other folks, and it has solved issues they were having. For instance, sometime when one installs a new stereo, for whatever reason, this fuse goes, and then they are puzzled as to what the heck happened!
-Bob
'98 Black TJ Sport 4.0L/Auto Trans
-(O|||||||O)-
my rig: http://i9.photobucket.com/albums/a95/steelman_d/Wheelin/DSC06310.jpg
_____________________________________________
Originally Posted by _Trucker View Post
I would rather shoot you in the face than play a guessing game....
Originally Posted by mrblaine
Are you bipolar, passive agressive, or just unable to recognize the dichotomy of your thought processes?
Steelman is online now   Reply With Quote
Old 09-26-2007, 02:55 PM   #40
retroflow
I see...Well, all the fuses I have seen, behind the glovebox and under the hood in the PCC are all good. I keep hoping that I'll find a simple solution and haven't.
Old 02-09-2008, 01:09 PM   #41
RobFromRI
i just did mine this morning, and it now works perfectly! thank you very much!
1999 Jeep Wrangler TJ 4.0 5 Speed Chili Pepper Red
2003 VW GTI 1.8T 6 Speed
Jazz Blue 20th Anniversary Edition #3177 of 4000
RobFromRI is offline   Reply With Quote
Old 02-09-2008, 06:43 PM   #42
JeepCrawlin
Does anyone know wat causes my radio and signal lights to turn off? I always need to play with the ignition key with a slight turn for it to work. Can someone help me with what should i check to correct this problem
JeepCrawlin is offline   Reply With Quote
Old 05-20-2008, 12:42 PM   #43
Maxwell2001TJ
Thanks for the info on how to remove gauge cluster. I will be replacing the conventional light bulbs to LEDs.
Maxwell2001TJ is offline   Reply With Quote
Old 05-23-2008, 08:07 AM   #44
alexr40
Happened to me yesterday. Fixed as write-up specified.
Excellent Write up! two thumbs up
1998 Jeep Wrangler 2.5L Turbo @8psi (haltech)
Locked Front & Rear, 4.56s, 4:1 low range with 2LO.
2.5" RC Lift with 1.25" BL & MML on 33s TSL Boggers with Beadlocks.
Ironman 9500 Winch, ARB Snorkel, Warn Bumpers/rock sliders/gas tank skidplates..
Smittybilt Tube Fenders, Axle tube seals, braided brake lines etc.
alexr40 is offline   Reply With Quote
Old 07-10-2008, 10:08 PM   #45
botayota
Excellent write up, I've had this intermitent instrument cluster thing with my 99TJ for many years, I'll pull the cluster and give this cleaning a try. I also read somewhere that there are some ground screws on the panel that lose contact does anyone know which ground screws these maybe?
Thanks,BY
botayota is offline   Reply With Quote
Glock Forum
