Send Message Advertisers Vendors Announcements
Jeep Forum Classifieds JeepSpace Reviews Gallery Blogs Clubs Groups Videos Wiki Links Events Articles
Jeep Home Jeep Forum Jeep Classifieds JeepSpace Jeep Reviews Jeep Gallery Jeep Blogs Jeep Clubs Jeep Groups Jeep Videos Jeep Wiki Jeep Links Jeep Events Jeep Articles
Wild Boar Products Cargo Rack or Front Bumper Giveaway
Go Back   JeepForum.com > Models > Wrangler Forums Group > TJ Technical Forum
Register FAQ Search Today's Posts Mark Forums Read Search Members
Old07-24-2005, 06:37 PM #1
zach1288
Banned
zach1288's Avatar
Send a message via AIM to zach1288
Fix your TJ's dead gauges (write-up)
Here is a quick write-up on how to fix your dead gauges. I had a problem with them dying, and later found out that it was a common problem. The connection's to the gauges can go bad for many reasons.
First thing you have to do is remove this piece of plastic on the top of your dash. There are not any screws just pull up on it, and it should pop right off.
http://img102.imageshack.us/img102/6661/jeep0099ey.jpg
Next remove the screws on each side of the steering wheel as shown in the pictures below.
http://img102.imageshack.us/img102/9093/jeep0103yh.jpg
http://img102.imageshack.us/img102/3545/jeep0111dp.jpg
Then pull off that piece of plastic from under the steering wheel as shown in the picture below.
http://img102.imageshack.us/img102/4557/jeep0120rx.jpg
zach1288 is offline   Reply With Quote
Old07-24-2005, 06:39 PM #2
zach1288
Banned
zach1288's Avatar
Then you have to remove the piece of plastic that covers the gauge cluster. There are two screws on the bottom and three along the top.
http://img102.imageshack.us/img102/3170/jeep0138up.jpg
http://img102.imageshack.us/img102/5017/jeep0145tu.jpg
http://img102.imageshack.us/img102/5059/jeep0161ey.jpg
http://img102.imageshack.us/img102/9629/jeep0174nm.jpg
Old07-24-2005, 06:40 PM #3
zach1288
Banned
zach1288's Avatar
Next you have to remove the gauge cluster. There will be two screws on the top and two screws on the bottom. Once you take the screws off, gently pull the cluster toward you. It will pop off the connectors.
http://img102.imageshack.us/img102/2207/jeep0180pk.jpg
http://img102.imageshack.us/img102/2016/jeep0209zc.jpg
http://img102.imageshack.us/img102/8149/jeep0215vt.jpg
http://img102.imageshack.us/img102/5774/jeep0225un.jpg
http://img102.imageshack.us/img102/2386/jeep0249rm.jpg
Old07-24-2005, 06:41 PM #4
zach1288
Banned
zach1288's Avatar
Last you want to clean the connectors on the back of the cluster and on the connectors in the dash. I cleaned mine with rubbing alcohol and q-tips. You can also bend the wires on the cluster with needle nose pliers. After that put the cluster back on and test it out. If it works put everything back together. If it does not work then try cleaing again. If you still dont have any luck post in my forum or jeepforum.com and someone will help you.
http://img102.imageshack.us/img102/9218/jeep0254zg.jpg
http://img102.imageshack.us/img102/44/jeep0269yd.jpg
Old07-24-2005, 07:03 PM #5
Lefty
Great Guide, good to see what the back of the cluster looks like. Only cluster I've seen is the back to a '65 mustang.
Lefty is offline   Reply With Quote
Old07-24-2005, 10:17 PM #6
BNovak
BNovak's Avatar
Send a message via AIM to BNovak
when you put it back togethor - smear the connectors with dielectric grease. That helps with the water prooffing.
Another tip - since you have the fascia that covers around the guages off, it's a good time to hit it with a couple coats of Fusion paint.
-BN
'97 Forest green. ~6" total lift, 8.8, etc. 36" TSL's, winch. You get the drill.
BNovak is offline   Reply With Quote
Old07-25-2005, 08:13 AM #7
smittystorm
Great write up, thanks for taking the extra time.
98 Gun Metal Blue 4-Banger, 2" Rusty's Offroad Basic Coil Lift, Ramsey 9.5e with Harbor Freight Mounting Plate, 31x10.5 BFG T/A AT, Herculined Tub, Rusty's Offroad Engine/Tranny Skid and Steering Box Skid, Hella 500 lights, Mounted Garmin Legend GPS, and Various other doodads
smittystorm is offline   Reply With Quote
Old07-25-2005, 04:06 PM #8
zach1288
Banned
zach1288's Avatar
No problem, next time i have something wrong with my jeep, i will make another writeup
Old07-30-2005, 10:33 PM #9
smittystorm
Definately keep them coming
Old08-01-2005, 02:36 PM #10
firefitr26
what wires do you twist?
"A certain degree of neurosis is of inestimable value as a drive, especially to a psychologist. " --Sigmund Freud
firefitr26 is offline   Reply With Quote
Old08-01-2005, 02:43 PM #11
Windsor
Mobil 1, not Mobile 1
Windsor's Avatar
Thank you for contributing!
2004 Wrangler Rocky Mountain Edition
BF Goodrich 31x10.50 Mud Terrain KM2
Rusty's 3" front springs and Skyjacker 2" rear spacers
Skyjacker Hydro 7000 shocks and steering stabilizer
JKS Quicker Disconnects
Tuffy glove box, full console
WARN D30 skid & Nth Degree Mobility oil pan skid
WARN front and rear Rock Crawler bumpers, winch plate and grill guard
WARN 9.5ti winch w/ Optima Blue Top D34M - X-Line rope & fairlead
KC Daylighter Slimlights on windshield
IPF H4 w/ FatBoy bulbs
Windsor is offline   Reply With Quote
Old08-01-2005, 05:02 PM #12
BigWaylon
tubework is cool...
BigWaylon's Avatar
you don't twist the wires...
you can slightly twist/tweak the pins on the guage side of the connector, so they'll make better contact with the connectors on the firewall side...
...and ditto the dielectric grease suggestion...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
www.carolinarockshop.com
All the pics I have...including a Table of Contents
BigWaylon is offline   Reply With Quote
Old08-01-2005, 05:26 PM #13
firefitr26
ok, I got it. I will try that, thanks.
Old08-05-2005, 09:59 PM #14
zach1288
Banned
zach1288's Avatar
Could you make this sticky?
Old08-05-2005, 10:12 PM #15
BigWaylon
tubework is cool...
BigWaylon's Avatar
No, but I did add it to the TJ FAQ sticky at the top...we currenty have a "dead link" posted there, but I'm going to add this topic below it...
Greg
Dead gauges jusber15 YJ Technical Forum 4 09-08-2007 10:55 AM
All my gauges are dead? zach1288 TJ Technical Forum 4 07-24-2005 06:06 PM
Gauges Dead? ScreetHoPrez YJ Technical Forum 5 05-09-2005 02:31 PM
Dead Gauges...? nightstalker5.0 YJ Technical Forum 4 12-30-2004 07:36 PM
Dead Gauges, FAQ Link Is Dead omnipseudo TJ Technical Forum 2 05-01-2004 10:05 PM
The time now is 12:32 PM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation.
JeepForum.com is not in any way associated with Jeep or the Chrysler Corp.
