Fix your TJ's dead gauges (write-up) - JeepForum.com
post #1 of 125 Old 07-24-2005, 05:37 PM Thread Starter
zach1288
zach1288's Avatar
Here is a quick write-up on how to fix your dead gauges. I had a problem with them dying, and later found out that it was a common problem. The connection's to the gauges can go bad for many reasons.
First thing you have to do is remove this piece of plastic on the top of your dash. There are not any screws just pull up on it, and it should pop right off.
Next remove the screws on each side of the steering wheel as shown in the pictures below.
Then pull off that piece of plastic from under the steering wheel as shown in the picture below.
zach1288 is offline
post #2 of 125 Old 07-24-2005, 05:39 PM Thread Starter
zach1288
zach1288's Avatar
Then you have to remove the piece of plastic that covers the gauge cluster. There are two screws on the bottom and three along the top.
zach1288 is offline
post #3 of 125 Old 07-24-2005, 05:40 PM Thread Starter
zach1288
zach1288's Avatar
Next you have to remove the gauge cluster. There will be two screws on the top and two screws on the bottom. Once you take the screws off, gently pull the cluster toward you. It will pop off the connectors.
zach1288 is offline
post #4 of 125 Old 07-24-2005, 05:41 PM Thread Starter
zach1288
zach1288's Avatar
Last you want to clean the connectors on the back of the cluster and on the connectors in the dash. I cleaned mine with rubbing alcohol and q-tips. You can also bend the wires on the cluster with needle nose pliers. After that put the cluster back on and test it out. If it works put everything back together. If it does not work then try cleaing again. If you still dont have any luck post in my forum or jeepforum.com and someone will help you.
zach1288 is offline
post #5 of 125 Old 07-24-2005, 06:03 PM
Lefty
Great Guide, good to see what the back of the cluster looks like. Only cluster I've seen is the back to a '65 mustang.
Lefty is offline
post #6 of 125 Old 07-24-2005, 09:17 PM
BNovak
BNovak's Avatar
when you put it back togethor - smear the connectors with dielectric grease. That helps with the water prooffing.
Another tip - since you have the fascia that covers around the guages off, it's a good time to hit it with a couple coats of Fusion paint.
-BN
'97 Forest green. ~6" total lift, 8.8, etc. 36" TSL's, winch. You get the drill.
BNovak is offline
post #7 of 125 Old 07-25-2005, 07:13 AM
smittystorm
Great write up, thanks for taking the extra time.
2005 Silver LJ stock with 31" BFG ATs
Previous: 1998 TJ SE with 2" rusty's suspension lift and 31's
smittystorm is offline
post #8 of 125 Old 07-25-2005, 03:06 PM Thread Starter
zach1288
zach1288's Avatar
No problem, next time i have something wrong with my jeep, i will make another writeup
zach1288 is offline
post #9 of 125 Old 07-30-2005, 09:33 PM
smittystorm
Definately keep them coming
post #10 of 125 Old 08-01-2005, 01:36 PM
firefitr26
2009 JK Wrangler
what wires do you twist?
"A certain degree of neurosis is of inestimable value as a drive, especially to a psychologist. " --Sigmund Freud
firefitr26 is offline
post #11 of 125 Old 08-01-2005, 01:43 PM
Windsor
Mobil 1, not Mobile 1
Windsor's Avatar
Thank you for contributing!
2004 Wrangler Rocky Mountain Edition
BF Goodrich 31x10.50 Mud Terrain KM2
Rusty's 3" front springs and Skyjacker 2" rear spacers
Skyjacker Hydro 7000 shocks and steering stabilizer
JKS Quicker Disconnects
Tuffy glove box, full console
WARN D30 skid & Nth Degree Mobility oil pan skid
WARN front and rear Rock Crawler bumpers, winch plate and grill guard
WARN 9.5ti winch w/ Optima Blue Top D34M - X-Line rope & fairlead
KC Daylighter Slimlights on windshield
IPF H4 w/ FatBoy bulbs
Windsor is offline
post #12 of 125 Old 08-01-2005, 04:02 PM
BigWaylon
tubework is cool...
BigWaylon's Avatar
you don't twist the wires...
you can slightly twist/tweak the pins on the guage side of the connector, so they'll make better contact with the connectors on the firewall side...
...and ditto the dielectric grease suggestion...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
BigWaylon is offline
post #13 of 125 Old 08-01-2005, 04:26 PM
firefitr26
2009 JK Wrangler
ok, I got it. I will try that, thanks.
post #14 of 125 Old 08-05-2005, 08:59 PM Thread Starter
zach1288
zach1288's Avatar
Could you make this sticky?
zach1288 is offline
post #15 of 125 Old 08-05-2005, 09:12 PM
BigWaylon
tubework is cool...
BigWaylon's Avatar
No, but I did add it to the TJ FAQ sticky at the top...we currenty have a "dead link" posted there, but I'm going to add this topic below it...
Greg
Dead gauges jusber15 YJ Wrangler Technical Forum 4 09-08-2007 09:55 AM
LED Dash Gauges Write-up Grewe02 TJ Wrangler Technical Forum 57 02-15-2007 12:24 PM
All my gauges are dead? zach1288 TJ Wrangler Technical Forum 4 07-24-2005 05:06 PM
Gauges Dead? ScreetHoPrez YJ Wrangler Technical Forum 5 05-09-2005 01:31 PM
Dead Gauges, FAQ Link Is Dead omnipseudo TJ Wrangler Technical Forum 2 05-01-2004 09:05 PM
